NEC PG (10PGplus) Point Convergence Board failure
Goto page Previous  1, 2, 3
Zolzar
Posted: Fri Jun 14, 2013 6:25 pm    Post subject:
I have an excel spreadsheet that lists most of the caps and the quantities you will need. I will post it over the weekend. Unless you screw up a value after its pulled you won't need a manual. If you do make that kind of mistake I have a set of prints and can look up what you need if necessary.
John
the big E
Posted: Sat Jun 15, 2013 3:45 am    Post subject:
John
If I had that I might try and repair my video output board myself(had a friend do the others in house as I have been busy lately and I ain't lifting the set till I get ready to use it)I will be getting some free time soon so I told him I could try and do the board myself(the menus and display info is all that shows and the red tube picture twitches and shakes not sure if its a connection or not yet but will be pulling the video output board soon as I know it has to have a leaking cap or two if not something else bad on it)
But the set powers up and locks onto a signal via rgb (not sure if the video inputs work yet as i didn't get to test them before the video output died) but there is three boards at the back of the set so I am guessing it has the video board in the set
crt king of black
Posted: Sat Jun 15, 2013 7:28 am    Post subject:
It should have the video board. If not ive got some here if you really want one.
Posted: Sat Jun 15, 2013 7:36 am    Post subject:
Or more like the GAIN CTL board, because video input and test patterns come from the same way and switched on the gain ctl.
Posted: Sat Jun 15, 2013 7:41 am    Post subject:
My 9PG has been very reliable for the last 5,000 hours or so, it threw a system board but apart from that its never missed a beat really.
the big E
Posted: Sat Jun 15, 2013 12:55 pm    Post subject:
I think my set has one in it already as there is three boards at the back of the set(I know one is the video output board)
I know it has a leaking cap but I haven't checked the gain board or video input board(the later looks ok but I can't get it out of the set to check and see but since it worked before I lost video and the grids I don't think its my problem)
crt king of black
Posted: Sat Jun 15, 2013 1:04 pm    Post subject:
They will almost certainly be leaking if they are original, if they arent, they will be soon. There is no escape, its just how it is.
the big E
Posted: Sat Jun 15, 2013 1:06 pm    Post subject:
Form looking at the board it looks like there aren't many on those boards so it should be easy to do
crt king of black
Posted: Sat Jun 15, 2013 3:49 pm    Post subject:
not many compared to what? Laughing
the big E
Posted: Sat Jun 15, 2013 7:43 pm    Post subject:
I meant there is not many that I can see the video board(not the output board) has quite a bit on it on it so it looks like I may see what curt charges to redo them as the others have been redone already(since my friend won't do them)
crt king of black
Page 3 of 3
