| Posted: Tue Feb 26, 2013 11:18 pm Post subject: |
Hey, we've turned you into a RTR slut. Betcha can't have just one!
I personally don't like the older Akais like that one, or the M8/M9. Too much to go wrong with them at this point. Seemed that anything pre 1975 or so also didn't have the glass heads (I could be off a year or two) and if not, they are as susceptible to wear as other decks. I always have issues getting decent high end frequency response as well, as a bunch of those older decks were designed for the older non back coated tapes.
Just my $.02, curious what Jeremy says...
| Posted: Wed Feb 27, 2013 12:29 am Post subject: |
Hmm, he want's 100 bucks. I have read some good things on them but I'll see what the other guys also have to say.
there is a GX-280 for 250.
here is the add, I like what comes with it.
AKAI GX-280D 3-Head 7" Reel To Reel Stereo Tape Recorder. Very good condition, good working. Comes with 7 Maxell 35-90 reels, new, still wrapped and 3 metal reels.
| Posted: Wed Feb 27, 2013 1:04 am Post subject: |
Better... still a bit old, but the Akai metal reels (if they are Akai and straight, not bent) are worth $30-40 each on eBay... Keep one, sell the others. That brings the price of the deck in line.
Jeremy112
| Posted: Wed Feb 27, 2013 3:43 pm Post subject: |
| Curt Palme wrote: | Hey, we've turned you into a RTR slut. Betcha can't have just one!
Just my $.02, curious what Jeremy says... |
I can't comment on how the older akais sound. Honestly if it was me (and it was cheep) I would buy it. My old suitcase sony R2Rs don't have glass heads, but they are all 60s machines. Curt you're right, a lot can go wrong with these older units. Purely for the fact that the older pre 70s units are mainly mechanical driven, and the grease stiffens up so bad that its hard as a rock. On top of that the rubber idler tire and pinch roller im sure are starting to get hard, brittle, and probably shiny to the point that they won't grip much anymore (this is an issue in a Sony TC-530 I have here which needs a new idler to play at the correct speeds)
All in all though, the older units can still sound quite incredible. I restored 2 Sony TC-105 R2R units last summer, and albeit the built in amplifier and speakers couldn't do the machine justice, but if you wan't high's these old units can reproduce them beautifully. They are a bit less pronounced on the low frequency end, but given that they were mono units it wasn't really an issue. I would guess most of those got used for voice recordings, even though they play at 7.5ips and sound just as good for musical usage.
I also have to say, granted these old suitcase things I have lying around arent glass head units, but if you take care of your machine, and the tape, your heads should last many many years and sound incredible. These old sonys all have quite usable heads yet (can't remember what they are comprised of at the moment). In fact, a few of these look like they've barely seen a year of use, they just sat most of their lifetime.
In the end though, if you are looking for a "high end" unit, that akai is not probably going to be what you want. If you like Akai, the GX747 or even the 646 (I believe its that for the lower end one) would be super units. Just try to find something with a direct drive system for the reels and capstan, they are very very reliable, usually if the pinch rollers are good, they are still usable even after years of sitting (such as my revox).
Glass heads are nice, but there is a lot to a R2R to make it a nice unit, not just how well the heads hold up and their frequency capabilities. Theres all sorts of things on a R2R that you may and/or may not want. But like I said, the main thing is the drive system, the less mechanical it is, the more reliable it will be for you.
I wouldn't hesitate to check out a couple of the higher end sony's either. My experience with these 60s units turned out to be quite positive so I would suspect Sony kept with the flow of things for their high end models.
Jeremy112
| Posted: Wed Feb 27, 2013 3:49 pm Post subject: |
| Nashou66 wrote: | Hmm, he want's 100 bucks. I have read some good things on them but I'll see what the other guys also have to say.
Nashou |
Thats a good deal for the 280, brand new tape (and its maxell, it wont shed on you or filth up the tape path,) 3 METAL reels (good deal there those are worth about $30-65 each if they have boxes, then more toward the higher end)
3 Head unit, Play, record, Erase, so Im sure its not an auto reverse, though that isnt very important, just more of a convenience.
Heres the specs:
Track system: 4-track, 4/2 channel compatible
Tape speed: 3-3/4 x 7-1/2 ips
Reel capacity: 7"
Wow and flutter: less than 0.10%
Frequency response: 30 to 23,000Hz
Distortion: 0.8%
Signal to noise ratio: 55dB
Dimensions: 17.4 x 20.2 x 10"
Weight: 49.5 lbs
Frequency response is great on the high end, bit lacking on the low, still not bad for the age of the unit, and it even looks like a cool model. Its not the best, but the price sounds right and would be a super start to R2R!! The new sealed tape and metal reels are worth most of that $250 the guy is asking
| Posted: Wed Feb 27, 2013 3:53 pm Post subject: |
Yep, that more or less sums it up. Granted, not everything is related to glass heads, but with the Akais, it's the one thing you can count on to be OK in the machine. IN all the Akais I've worked on (probably 200+ at this point), I've had one glass head with an open winding. I've had lots of non glass heads worn to the point where they were throwaway.
So really, RTRs are like CRTs. Each one has a unique characteristic, and for 100% functionality, bet on having to spend time and sometimes money to get them running. Sony is known for their crappy grease, and if a pinch roller engaging mechanism is seized as is common now, it can be a real bitch to free it up.
Teacs are known for belts that turn to a massive sticky mess, taking at least an hour to clean up if the belt has thrown itself all over the chassis. Yuck!
Still, like CRTs, they're a lot of fun, and finding a stash of old tapes on CL or eBay can be interesting, listening to what others thought was worth putting on tape. I've found some interesting stuff on them... including a bunch 60s-80s music. Groovy, man!
Jeremy112
| Posted: Wed Feb 27, 2013 4:05 pm Post subject: |
| Curt Palme wrote: | | So really, RTRs are like CRTs. Each one has a unique characteristic, and for 100% functionality, bet on having to spend time and sometimes money to get them running. Sony is known for their crappy grease, and if a pinch roller engaging mechanism is seized as is common now, it can be a real bitch to free it up. |
You're spot on curt. They WILL cost you money if they need to be gone through, but it is worth it when they are done. a R2R that operates like new is a true blast to spend your time with. And you are dead right about the pinch rollers having issues on Sony R2R units. Can't say for the direct drive models, never came across one from sony. But the pinch roller assembly can literally take hours to free up on these old suitcase units. Usually they are a good place to start since the whole unit is useless until the pinch roller can engage.
I use IBM grease on these as well as some other lubricants that don't harden over time (supposedly). But in 30 years from now, I doub't I'll have to deal with any of these old machines. I'm sure they are becoming sparse with the issues they have after sitting around for decades.
in reality though, a good sony mechanical unit thats been gully gone through can fetch as much money as a decent direct drive unit. I think because of the design, the age, its what gets some R2R collectors I'm sure. Even I have a soft spot for a few of these mechanical wonders, makes me feel like I'm back in the 60s
Jeremy112
| Posted: Wed Feb 27, 2013 4:06 pm Post subject: |
| Nashou66 wrote: | So, umm, umm is 100 bucks cheap? Or should I ask 75?
Nashou |
Can't really go wrong on a R2R for $100... though you COULD try $75 and see if he takes it, always more fun when you save a bit more $$
| Posted: Wed Feb 27, 2013 5:06 pm Post subject: |
Cheap! Good score, the metal reels are worth more than that empty.
| Posted: Wed Feb 27, 2013 5:18 pm Post subject: |
Thats why I bid on them. I also got a few pre recorded tapes ove the past few days. I love big band so I got a Benny Goodman Tape All Time Greates hits for 7 bucks, a Nat King Coles best off for 10 and A Rod Stewart Every Picture tells a story for 15.
My Pioneer comes in tomorrow, same time as my Nat King Cole. But I'll have no take yup reel yet.
Jeremy112
| Posted: Wed Feb 27, 2013 7:10 pm Post subject: |
| Nashou66 wrote: | Thats why I bid on them. I also got a few pre recorded tapes ove the past few days. I love big band so I got a Benny Goodman Tape All Time Greates hits for 7 bucks, a Nat King Coles best off for 10 and A Rod Stewart Every Picture tells a story for 15.
Athanasios |
You shoulda bought some of my records, I had about 300+ big band albums I sold cheap to a guy local who wanted them, I figured it was better than giving them to good will :-\
| Posted: Thu Feb 28, 2013 10:17 pm Post subject: |
Well the Pioneer 1011L is here and she made the trip in great shape!!! And those 4 Ampex and AudioTape reels got delivered too!!
So now I'll let her warm up to room temp before plugging her in.
Some pics I uploaded. It was well packed I think professionally because the box was stapled shut as well.
PS: any of you guys have a manual on PDF? I can get one for 6 bucks but I'd rather save the money if I can
for more media!1
Looks in great shape huh guys?
| Description: |
| Filesize: |
106.63 KB |
| Viewed: |
8600 Time(s) |
| Description: |
| Filesize: |
105.7 KB |
| Viewed: |
8600 Time(s) |
| Description: |
| Filesize: |
104.92 KB |
| Viewed: |
8600 Time(s) |
| Description: |
| Filesize: |
109.72 KB |
| Viewed: |
8600 Time(s) |
| Description: |
| Filesize: |
110.74 KB |
| Viewed: |
8600 Time(s) |
| Posted: Fri Mar 01, 2013 12:27 am Post subject: |
Nicely done, both on your end for getting a very low hour machine, and for the seller for packing well. NICE NICE NICE!
| Posted: Fri Mar 01, 2013 12:32 am Post subject: |
| Curt Palme wrote: | | Nicely done, both on your end for getting a very low hour machine, and for the seller for packing well. NICE NICE NICE! |
Oh and those two ampex tapes were still sealed in the plastic bag. The AudioTape ones were open but not sure if recorded on. I have to wait for a take up reel. Unless I unscrew one of these and carefully take the tape pancake out
and use that.
No hurry for now. Just glad I got a nice unit for under 150 shipped.
| Posted: Fri Mar 01, 2013 1:21 am Post subject: |
Beware that the glue/binder on the tape will deteriorate even if the tape has never been used. Read up on baking tapes, as I'm sure you'll need it with at least one. I think more than 1 of those tapes is light brown though, right? If so, those may not need baking, but any backcoated ones probably will.
I also read on a forum last week about applying some kind of car wax to tape via a cloth. Sounded wacky to me, but a few audiophiles swore by it to cure tape shedding. At this point, try anything to prevent shedding.
zaphod
| Posted: Fri Mar 01, 2013 3:59 am Post subject: |
NICE DECK!! good score.
I read on tapeheads.net about using NuTone car wax. dunno if i hate my tape heads that much
