Silver04cavy
| Posted: Fri Feb 15, 2013 3:29 am Post subject: |
One other thing : I screwed up and its a 1208/2 not a 1208/s. I'm not sure if that would make a difference or not at this point
Silver04cavy
| Posted: Fri Feb 15, 2013 4:58 am Post subject: |
Could it be possible that I have one of my color wires not plugged into the right input on the back of the pj even tho they are going to the same letters off the back of the processor? All of my greens are blue and all my blues are green an yellow is magenta. That is the colors off my laptop running into the processor through a VGA cord to port 5 if that helps.
Silver04cavy
| Posted: Fri Feb 15, 2013 5:04 am Post subject: |
As you can see its supposed to be yellow. If the picture is bad I will try adding more tomorrow. I have to shrink it on my phone. Do not have my sync cable from work with me
| Description: |
| Filesize: |
381.34 KB |
| Viewed: |
4750 Time(s) |
| Posted: Fri Feb 15, 2013 5:17 am Post subject: |
| Silver04cavy wrote: | | Could it be possible that I have one of my color wires not plugged into the right input on the back of the pj even tho they are going to the same letters off the back of the processor? All of my greens are blue and all my blues are green an yellow is magenta. That is the colors off my laptop running into the processor through a VGA cord to port 5 if that helps. |
Yep very possible. Try switching them around. Maybe the cable was made wrong
Silver04cavy
| Posted: Sat Feb 16, 2013 3:00 am Post subject: |
| AnalogRocks wrote: | | Silver04cavy wrote: | | Could it be possible that I have one of my color wires not plugged into the right input on the back of the pj even tho they are going to the same letters off the back of the processor? All of my greens are blue and all my blues are green an yellow is magenta. That is the colors off my laptop running into the processor through a VGA cord to port 5 if that helps. |
Yep very possible. Try switching them around. Maybe the cable was made wrong |
I feel stupid now. My green and blue cables were switched around backward.
Now my next problem is my HDMI to VGA vonverter does no produce any images to the projector. I plugged it into my LCD projector and it works there, my hdmi cable works from my laptop to my tv so the cord works. My processor is set to negative sync and works on all other video sources. What could my problem be now
| Posted: Sat Feb 16, 2013 5:41 am Post subject: |
Which converter do you have?
Silver04cavy
| Posted: Sat Feb 16, 2013 5:46 am Post subject: |
It's some POS that I bought online which I thought would do the job but after looking are online I am about 99.9% sure that it does not have HDCP stripping abilities and that is what is causing my problems. It looks like a white HDfury and the box looks the same but I assure you it does not work on my Barco,
| Posted: Sat Feb 16, 2013 3:12 pm Post subject: |
Yup, guaranteed that's the issue.
Silver04cavy
| Posted: Sat Feb 16, 2013 3:54 pm Post subject: |
So that being the case, is there any other converts with hdcp stripping that will work
| Posted: Sat Feb 16, 2013 3:56 pm Post subject: |
Yes, the best one out there is the external box at www.moomecard.com
Silver04cavy
| Posted: Sat Feb 16, 2013 7:02 pm Post subject: |
Is there a "used for sale" section that I am missing somewhere?
| Posted: Sat Feb 16, 2013 8:20 pm Post subject: |
It's gonna be pretty hard to find a used external Moome box I think, but feel free to post.
| Posted: Sat Feb 16, 2013 8:26 pm Post subject: |
HDFury2 and a gammaX would work for you too.
