Silver04cavy
| Posted: Sun Feb 03, 2013 7:41 pm Post subject: New to CRT and need some help please with 1208 |
Ok so I am new to CRT projectors and not up to speed with all the abbreviations yet. I have recently aquired a Barco 1208/s for cheap. The problem is that the green over powers everything else. I do not get black it looks green and the green flickers and has a problem that I can only describe as the "V-hold" on the old VHS is off and needs adjusted. I have searched and searched and can not find a solution. It happens when trying to do the set up and the focus and also on video source. Thank you in advance for answering.
Silver04cavy
| Posted: Sun Feb 03, 2013 7:49 pm Post subject: |
I have my Samsung Blu-ray player connected through the RGB output. I know I need to have the sync cables connected too but just wanted to see if the green was still there. Sure enough it is. Even when I turn the unit on there isn't really a "black" it has a really green tint to it.
Silver04cavy
| Posted: Sun Feb 03, 2013 8:00 pm Post subject: |
You are more than likely right. I'm not sure which way it really is. Started to get annoyed an had to walk away. But it also does the same on "S-video" also. I know I need the coder deal just wanted to see if there was a picture. But would that make everything green even with nothing connected? When looking at the tubes the green is blinding and the blue an red you can look into without hurting your eyes.
Silver04cavy
| Posted: Sun Feb 03, 2013 8:14 pm Post subject: |
I have the set up tips all printed out and have read them a couple times. As at as adding to the topic not really sure how to go about doing that but thank you for your help.
MikeEby
Silver04cavy
| Posted: Sun Feb 03, 2013 9:00 pm Post subject: |
Thanks Mike but the thing is I want to use it to watch football games and play my playstation on. Using a transcodes isn't a problem. The problem is my green is over powering the other colors even on the start up screen an sometimes it starts to flicker almost like a strobe light.
Silver04cavy
| Posted: Sun Feb 03, 2013 9:03 pm Post subject: |
How do I adjust or inspect the G2?
MikeEby
| Posted: Sun Feb 03, 2013 9:11 pm Post subject: |
Don't adjust anything until you have a stable signal. I know with my RPTV when have a YPbPr signal connected to an RGBHV input you will get an image but it will be very green. Try S-Video as as source the scan lines will be huge but you can see if the colors are about right.
Silver04cavy
| Posted: Sun Feb 03, 2013 9:19 pm Post subject: |
| Nashou66 wrote: | http://www.curtpalme.com/docs/Barco1208_Black_Balance_Adjustment.pdf
Skip the high voltage part and go to G2+ Diagnostics.
Athanasios |
So to make sure I understand it right. I need to jump the 2 pins that are out the top and turn the little flat head screw?
Silver04cavy
| Posted: Sun Feb 03, 2013 9:21 pm Post subject: |
| MikeEby wrote: | Don't adjust anything until you have a stable signal. I know with my RPTV when have a YPbPr signal connected to an RGBHV input you will get an image but it will be very green. Try S-Video as as source the scan lines will be huge but you can see if the colors are about right.
Mike |
Thats the problem, everything is green. Even with no input connected even the menu options and start up screen has a big time green "shade" I guess I want to call it.
MikeEby
| Posted: Sun Feb 03, 2013 9:25 pm Post subject: |
| Silver04cavy wrote: | | MikeEby wrote: | Don't adjust anything until you have a stable signal. I know with my RPTV when have a YPbPr signal connected to an RGBHV input you will get an image but it will be very green. Try S-Video as as source the scan lines will be huge but you can see if the colors are about right.
Mike |
Thats the problem, everything is green. Even with no input connected even the menu options and start up screen has a big time green "shade" I guess I want to call it. |
The menu on a Barco are green if I remember correctly from my old BG800 days. Is the screen green or just the text from the menus?
| Posted: Sun Feb 03, 2013 9:26 pm Post subject: |
| Silver04cavy wrote: | | Nashou66 wrote: | http://www.curtpalme.com/docs/Barco1208_Black_Balance_Adjustment.pdf
Athanasios |
So to make sure I understand it right. I need to jump the 2 pins that are out the top and turn the little flat head screw? |
Like I said, I do not own a Barco so I have never done this. But the procedure is very specific on what to do. And to really do it correctly you need to adjust the 1020V first. But this is very High voltage and dangerous for someone
who I have no idea ho much electronic knowledge they have. You probably could get away with not adjusting that voltage to make sure its 1020 volts.
I'd wait for some one else who has done this before chimes in. You'll need a Volt meter that can read that high in the first place.
Silver04cavy
| Posted: Sun Feb 03, 2013 9:34 pm Post subject: |
| MikeEby wrote: | | Silver04cavy wrote: | | MikeEby wrote: | Don't adjust anything until you have a stable signal. I know with my RPTV when have a YPbPr signal connected to an RGBHV input you will get an image but it will be very green. Try S-Video as as source the scan lines will be huge but you can see if the colors are about right.
Mike |
Mike |
It is everything that is green. I will try and upload a picture. Not sure if it would be very helpful at all. There is no black its all green.
