What am I doing wrong here? Marquee 8500
Posted: Mon Jan 28, 2013 12:32 am    Post subject: What am I doing wrong here? Marquee 8500
I normally don't post schematics, but here's the video output stage of a standard 2035-02 VIM. I've got two here with identical problems- very low output on red on one, green on the other. THe other two channels are fine.
I've narrowed the issue down to the AD835 video output amp. Signal is fine going in, very little coming out. I ordered two new (very expensive, I might add) amps from China, so I put one in. Same problem. I'm not putting in the other one, as I don't buy that two amps would have the same issue. Voltages in and out are fine. I've paralleled the control pins between chips, to see if the red connection will bring down the blue for example, or if paralleling them will bring the red back. Nope, not unless I parallel the chip output, then the red comes on full with the blue output working fine.
So what the heck am I missing?
 Filesize:  173.84 KB
 Viewed:  5526 Time(s)
Posted: Mon Jan 28, 2013 12:39 am    Post subject:
You are missing the point that VIMs are so cheep they are not worth fixing!
Posted: Mon Jan 28, 2013 12:52 am    Post subject:
Scope pin 8 of each amp and see if there is a significant difference in the bad color one.
Posted: Mon Jan 28, 2013 1:52 am    Post subject:
Curt when I got my long bows I shorted an AD835 out by taking a pic of the board on a rug. I know stupid. I ordered one from Mouser and it was bad. Confirmed by swapping chips. They sent me another one for free. That one worked.
Posted: Mon Jan 28, 2013 3:10 pm    Post subject:
Wow, that's the first time I've heard about taking out a chip while it's in circuit. They're supposed to be impervious to static zaps when installed.
Mac, yes, the input to the AD chip is fine, identical to the others, the output is almost non-existent compared to the others. I'm leaving this alone for the day, have Ultra focus boards to repair, but will try again either tonight or tomorrow. I think changing the chip again, maybe with one from a scrap board I have here will determine if the chip is bad.
Posted: Mon Jan 28, 2013 3:28 pm    Post subject:
Pin 8 is not your input signal, it is your gain control signal. Pin 1 would be your input signal. If you have been testing and comparing pin 8's then I would suggest testing and comparing pin 1's
Posted: Mon Jan 28, 2013 3:35 pm    Post subject:
Sorry, wasn't looking at the schematic. What I need to try and do is lift pin 8 rather than short it to an adjacent chip, and jumper the raw pin over. I'll get on this... later today.
Posted: Mon Jan 28, 2013 3:38 pm    Post subject:
Are these dip's or sop's?
Posted: Mon Jan 28, 2013 5:45 pm    Post subject:
DIPs
and the tech working on it is apparently a DIP-S.
Mr. Green
Posted: Mon Jan 28, 2013 5:53 pm    Post subject:
Then surely you must have some DIP sockets there. Pop 1 or 2 in and make it easier on yourself.... Laughing
Posted: Mon Jan 28, 2013 7:47 pm    Post subject:
Well that solves that one! Finally got annoyed with the two boards staring at me, and I swapped AD835 chips from one board to another. Sure enough, both chips from China were DOA.
Tech, not so suspect any more. The chips from China... DIE DIE DIE!!!
Smile
Posted: Mon Jan 28, 2013 7:50 pm    Post subject:
Smile
How about that. Did you get them from 1 of our usual suppliers or off Ebay?
Posted: Mon Jan 28, 2013 7:53 pm    Post subject:
ebay. High volume seller with very good feedback, so I was surprised. I wonder if the ID was stamped on backwards? Might try installing the chips backwards...
http://www.ebay.com/itm/120932107098?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Posted: Mon Jan 28, 2013 8:00 pm    Post subject:
Or sure, blow up something else now. Laughing Do you want me to check availability with some of my suppliers?
Posted: Mon Jan 28, 2013 8:01 pm    Post subject:
Sure, Digikey wants $20.00.!!!
Posted: Mon Jan 28, 2013 8:12 pm    Post subject:
I actually need one too. I cannibalized an 02p VIM to replace the Longbows AD835.I lost the replacement that Mouser sent me.I couldn't wait for the shipment and used a spare 02p. I think it was more than 20 bucks when I looked for
one.
You Know I have a board that Dennis made to convert a 02p to a 03p since the 03p has the higher bandwidth AD834. I should try to
get that working.
Posted: Mon Jan 28, 2013 8:15 pm    Post subject:
Request sent. I'll keep you updated.......
Posted: Tue Jan 29, 2013 2:31 am    Post subject:
I have received a couple quotes back and the lowest so far is 11.30 each on a quantity order. New and original.
Posted: Tue Jan 29, 2013 2:56 am    Post subject:
Cool. I only need about 5. As Tim said, spare VIMs are plentiful, and at $14 a chip landed, not to mention the $30 I spent on bad ones, it's hardly worth it..
Posted: Tue Jan 29, 2013 4:32 pm    Post subject:
I got some more quotes in this morning and we are down to around 7.70 each for new ex stock. But you may have to buy a minimum or 10.
