My new JVC digital projector (DLA-X75R/DLA-RS56)
Goto page Previous  1, 2, 3 ... , 14, 15, 16  Next
Posted: Mon Aug 07, 2017 6:53 pm    Post subject:
Oh ya, that's crucial. That's why proper color filtering is so important -- otherwise the gamut of the projector doesn't match the standard.
jbltecnicspro
Posted: Mon Aug 07, 2017 11:11 pm    Post subject:
cmjohnson wrote:
I think the size of the gamut is not as important as it is to have the gamut of the display match the gamut of the source so color reproduction is accurate.
You would be correct, and this is why my opinion is what it is. When the studios inevitably hit rec 2020, that will leave a lot of people who were suckered in by "futureproofing" with HDR in the dust, because their devices technically won't be able to do it.
I wouldn't be surprised if we see something like we did with HD. We'll see "HDR" and then "Full HDR" when the rec 2020 devices come out. Very Happy
Posted: Sat Sep 30, 2017 2:47 am    Post subject:
Looking again. Might be able to score a local RS45 for a good price. I haven't heard anything bad about that projector so I think I'm gonna jump on it. Anything I should be cautious or aware of?
Jeremy112
Posted: Sat Sep 30, 2017 3:01 am    Post subject:
The only thing I've seen that is "common" to JVC projectors when it comes to issues; the ballasts seem to fail in them (not that model specifically, just the RS PJ's in general). Otherwise, they're fairly solid machines. I think you'd be happy with the performance from it as long as it stays working Thumbs Up
jbltecnicspro
Posted: Sat Sep 30, 2017 2:13 pm    Post subject:
The only complaint I've seen specific to RS-45 is that the lamps dim pretty quickly after 1000 hours of usage. But I don't know how true this is. I would imagine that if you do some looking around you could probably find the bare bulbs for not too much.
Posted: Sat Sep 30, 2017 3:47 pm    Post subject:
Does anyone know if ballasts can be bought from JVC? I haven't got a clue..
Posted: Sat Sep 30, 2017 4:03 pm    Post subject:
Google "jvc projector ballast" turns up lots of possibilities, including
https://encompass.com/item/10154451/JVC/QAL1305-001/Ballast_Pwb
http://www.pacparts.com/part.cfm?sku=964TDO8072-778
The second one works for the RS-50, 55, 60, 65, and others. But it also works for X-series projectors, including the X30, which I think is the same as the RS-45. I'm not sure why JVC has two equivalent lines with different model numbers.
jbltecnicspro
Posted: Sat Sep 30, 2017 5:30 pm    Post subject:
Say Gary, maybe I missed this earlier but what are you using now? I was honestly thinking about picking up an RS-1, of all things for our theater room. They should be inexpensive enough.
Posted: Sat Sep 30, 2017 5:38 pm    Post subject:
I still have an 8500 that has never worked right. RS1's are pretty cheap bit that's an older generation. RS45 is plenty old too, but the made a lot of improvements around then. I don't know how the RS1 compares.
jbltecnicspro
Posted: Sat Sep 30, 2017 5:44 pm    Post subject:
Gotcha. To clarify - I'm not suggesting you get an RS-1. My reasons for wanting one (at least I think I do! Very Happy) are my own. My living situation is changing. We're moving in with my in-laws to help care for a terminally ill member of our family. There will be lots of kids, so having a cheaper RS-1 would be better in the case that something happens to it. Very Happy I won't feel so bad about it being damaged versus an RS-56 or something like that. And their image quality is still above and beyond any entry-level DLP or LCD.
Posted: Sun Oct 01, 2017 3:24 am    Post subject:
Yup, an RS-1 should be significantly better than that.
Well I've just cut a deal for an RS-45 WITH SPARE NEW BULB, ceiling mount plate, 3D emitter & 2 pr glasses, original packing, etc -- for $850.
Pretty hard to turn that down. Very Happy
Posted: Tue Oct 03, 2017 2:49 am    Post subject:
Not a bad deal. You should get plenty of use out of it.
jbltecnicspro
Posted: Tue Oct 03, 2017 11:52 pm    Post subject:
Congrats. Take pics! Smile Put it on the screenshot thread and lie about it not being a CRT. Very Happy
Posted: Wed Oct 04, 2017 2:50 am    Post subject:
Can't do it for a while. I'm out of town for a couple more weeks. Then I have to clear out the HT -- it was about the only place I could stack stuff when I was remodeling the rest of the house. You'd have trouble seeing the screen from the seats the way it is now!
Posted: Sat Oct 21, 2017 11:36 pm    Post subject:
Got back a few days ago, cleared out enough junk to see the screen, and did a quick setup.
And damn, that thing kicks my 8500's patootie. Which you would hope, considering the 8500 never worked right, but it's nice to finally have a great image in there!!
jbltecnicspro
Posted: Sun Oct 22, 2017 1:00 am    Post subject:
Good deal - and congratulations!
Posted: Sun Oct 22, 2017 2:24 am    Post subject:
Enjoy the RS-45 Gary!
Posted: Fri Nov 10, 2017 12:03 am    Post subject:
Very strange problem with my RS-45:
I plugged in a cheap BR player, and it worked fine -- until it started sending 1080p24. Then the projector appeared to stretch the image vertically about 2x, so things that should have been in the center of the screen were at the bottom, and the bottom-half content wrapped around and overlaid the top-half content.
I got a better player and plugged it into the other HDMI input, and that worked OK. At first I thought it was the player, but then I swapped players / inputs, and it turns out both players fail on HDMI1. Both work on HDMI2.
I asked the previous owner if he knew of any oddness with HDMI1, and he was confused -- he said all he EVER used was HDMI1, and he never had a problem.
Any guesses what might cause this, and guesses if it is a simple fix? It's not fatal, because I only need one input, but it would be nice to have a "spare" in case HDMI2 died...
Posted: Fri Nov 10, 2017 12:26 am    Post subject:
Is there any internal scaling settings on the projector Gary? Sub menus perhapse?
Posted: Fri Nov 10, 2017 4:34 am    Post subject:
Beats me, since I don't know what you're looking for. The only mention of "scale" is talking about video scale (bright/dark).
You can look at the manual here: http://www.projectorcentral.com/pdf/projector_manual_6515.pdf
Page 15 of 16
