haireez
| Posted: Fri May 09, 2014 4:49 pm Post subject: |
Hi Tim,
Just confirm that the P14 is exactly at 6.5vdc. I'ved swapped red & blue neckboard but still the red did not fire up. It's confirmed that the problem lies with the hvps but just not sure which component is failing. As mentioned, i did try to swapped with my unstable hvps and all tube managed to fire up.
_________________ 2 White Vision 1
| Posted: Fri May 09, 2014 7:28 pm Post subject: |
Hello
Do not assume you have another HVPS problem
6.50 vdc on the filaments is a bit high and could have weakened the red tube
Do you measure G2 okay at the red neckboard? 450 to 550 volts dc is needed
How many hours on this machine? UTIL, 9 , 0901, 6, 3 Include Standby hours as the filament is full on during Standby
Look into the red lens and see if there is an image very faint
tschaeikaei
Joined: 08 Apr 2013 Posts: 490 Location: Germany/Saarland
| Posted: Fri May 09, 2014 8:52 pm Post subject: |
Hey Tim,
don't know if this is with every Marquee, but on my 8500 Ultras, filament is down to 4V in Standby.
Just because you said "full on"
Regards, Julian
_________________ Marquee 9500U edgeblend P43 | NEC 9PG
| Posted: Fri May 09, 2014 11:02 pm Post subject: |
| tschaeikaei wrote: | Hey Tim,
Regards, Julian |
Hello
Don't confuse Ready/Off with Standby
The four power states are
Unplugged No Power
Plugged into Mains (Ready but Off).......Filament 4v
Standby (On with Picture Muted)........Filament 6.35v
Fully On and viewable........Filament 6.35v
The last two states are a problem where the filament voltage creeps up
haireez
| Posted: Sat May 10, 2014 5:16 am Post subject: |
Hi Tim,
I've measured the red G2 value is 135 vdc but after 30 seconds, it drop to 65 vdc. I've adjusted the p14 value and now it's 6.31vdc.
After adjusting p14 to 6.31vdc the red tube still does not fire up.
By the way, the hours of use is:
With CRTs ON: 33416
In Standby: 15760
Total: 49176
barclay66
| Posted: Sat May 10, 2014 10:01 am Post subject: |
Wow, that's a lot of hours!
Hey, I might be able to help You with this in person. I'm now sitting at Changi Apt and waiting for my flight to Germany. But on the 20th I will be back for another three weeks. I even could bring some (small) spare parts with me. Maybe You could try the following (if the cables are long enough): Try to swap the red and green G2 cables at the neck boards. If now the green tube stays dark, the problem definately lies within the G2 circuit inside the HVPS...
Regards,
barclay66
haireez
| Posted: Sat May 10, 2014 10:19 am Post subject: |
Hi Barclay,
That would be wonderful. If you're in Singapore, please call my mobile number when you're here.
Looking forward to meet CRT user from other country.
barclay66
| Posted: Sat May 10, 2014 10:53 am Post subject: |
Cool,
I've saved Your phone number and will call You then. I will send You a PM with my contact details in Singapore. You might want to edit Your post as to not give away personal details in public...
Regards,
barclay66
barclay66
| Posted: Sun May 11, 2014 4:26 am Post subject: |
Yeah!
CRT worldwide united!
| Posted: Sun May 11, 2014 11:10 am Post subject: |
| barclay66 wrote: | Yeah!
CRT worldwide united! |
Sounds like a soccer team.
haireez
haireez
| Posted: Wed Jun 04, 2014 4:18 pm Post subject: |
Another photo to share for my mini home theater room. Glad the projector is working now.
| Description: |
| Me (Singapore), Barclay66 (Germany) & my brother-in law (Singapore) WE ARE CRT FAMILY!!! Even our T-shirt is Blue, Green & Red. |
| Filesize: |
73.95 KB |
| Viewed: |
3867 Time(s) |
barclay66
| Posted: Wed Jun 04, 2014 4:33 pm Post subject: |
It was my pleasure and I had a great time!
I couldn't hope even seeing a soldering iron during my stay in Singapore and now that: Having one in hand and getting it to work productively. Thank You for the opportunity and the nice welcome! I really felt at home...
Regards,
barclay66
