Hey Scott! Remember the Medium Retrace mod?
Posted: Wed Oct 24, 2012 3:00 am    Post subject: Hey Scott! Remember the Medium Retrace mod?
Guys
This would give more useful width in what is now short retrace on a Marquee. If my computer hadn't blown up two years ago I'd post it myself......
Posted: Wed Oct 24, 2012 7:34 pm    Post subject:
this is something that's done to the HDM?
Posted: Wed Oct 24, 2012 7:43 pm    Post subject:
Yes
Providing Scott gets back to us Smile
I had the info in an e.mail and it was lost in a crash.
Posted: Wed Oct 24, 2012 7:56 pm    Post subject:
I think there was some info on the marquee thread where dennis and Scott were going over the Cree fet mod. Changing a few caps would alter the width of the raster. I remember scott saying to be careful with the cap value. I wonder if that might be related?
Posted: Thu Oct 25, 2012 7:37 pm    Post subject:
Guys
I was hoping Scott would visit us here, he has the info for this.
htguy1
Posted: Fri Oct 26, 2012 4:31 am    Post subject:
Calling Scott! Come back and help us!
tse
Posted: Fri Oct 26, 2012 1:26 pm    Post subject:
The retrace caps (C4, 5, 6, 7, 10, and 11) values can be increased to increase the flyback time. This will decrease the "write" time which makes the active video time cover more of the raster. Probably the best thing to do is just parallel the caps that are already there with 1nF 1000V polypropylene parts. If the raster "wraps" around the caps are too big if still too much unused raster add slightly higher value or more of the 1nF parts. Increasing the cap value decreases the flyback voltage so there is little danger in properly adding caps of reasonable value. I have included a Mathcad file that calculates the the voltages and cap values.
Good Luck,
Scott
 Filesize:  45.37 KB
 Viewed:  7526 Time(s)
Thomas Jefferson
Posted: Fri Oct 26, 2012 2:04 pm    Post subject:
So Scott
This affects both short and long retrace?
tse
Posted: Fri Oct 26, 2012 3:06 pm    Post subject:
Both long and short will increase but the long will increase less than short.
Scott
Thomas Jefferson
Posted: Fri Oct 26, 2012 4:09 pm    Post subject:
Thats looks like the formula in the Marquee thread regarding those Cree fets. Is it the same?
dvh99
Posted: Fri Oct 26, 2012 4:22 pm    Post subject:
yes it is.
on long retrace i think an extra cap is switched on with a relay an put in parallel with the caps across the fets.
Posted: Fri Oct 26, 2012 4:59 pm    Post subject:
Guys
I have some caps ordered for testing, let me get back to you in a week or so........
Posted: Fri Oct 26, 2012 5:01 pm    Post subject:
I knew i was right ! Wink
tse
Posted: Fri Oct 26, 2012 5:15 pm    Post subject:
Yep.
Scott
Thomas Jefferson
thewolfman
Posted: Fri Oct 26, 2012 9:43 pm    Post subject:
deleted
dturco
Posted: Fri Oct 26, 2012 9:59 pm    Post subject:
Good Luck,
Scott
Scott, in about two years I'll be able to do this. But right now, it makes no sense at all. How can a voltage or re-trace length be 10 to sixth power negative? Or is that just to show how small it is in length in relation to the fictional start point of 1 meter?
You don't have to answer, I just wondering out loud, as I have yet to tackle my math requirements starting at Algebra...
101 Shocked
http://www.hulu.com/firefly
Posted: Fri Oct 26, 2012 10:34 pm    Post subject:
dturco wrote:
Good Luck,
Scott
101 Shocked
When the power is negative it goes fractional. 10 to the 6th power negative would be 1/1000000 or 0.000001
dturco
Posted: Fri Oct 26, 2012 11:23 pm    Post subject:
I get its a fraction of something, just like when I'm doing microscope work the object is really small. But the size is always related to the starting point of 1 meter.
Down 10 to the 6 negative as 6um, as a measurement or 1 millionth of a meter. I get that because I can see it in the scope but as pure math... I freeze.
Posted: Fri Oct 26, 2012 11:31 pm    Post subject:
It's fractional to where it is being applied. If it's time it is fraction of a second. If it's voltage it's fraction of a volt. If it's cap value it's fraction of a farad. If it's resistance it is a fraction of an ohm...... shall I continue?
dturco
Posted: Fri Oct 26, 2012 11:35 pm    Post subject:
Ahhh, the starting point is known; because of the application. Got it.
Thumbs Up
