My Marquee is an Oscilloscope
Posted: Sat Oct 20, 2012 12:15 pm    Post subject:
HK-Steve wrote:
Well, I cleaned all the connections and plugs on the Convergence, stig, and vertical,
Still shaking.
Did you try Disconnecting conv and stig?
Posted: Sat Oct 20, 2012 12:24 pm    Post subject:
HK-Steve wrote:
Also, changed red for green, still shaking, but red only
By this do you mean the H-def coils only, or the other corresponding coils as well?
If the shaking comes from the green plug from HDM, then you narrowed down the source pretty much. As Curt already said the H-def is basically the same for all threee tubes, only the last stage is individual for each tubes. Maybe a bad contact in the relay?
