| Posted: Sun Oct 07, 2012 2:43 pm Post subject: NEC PG xtra LC ? |
Okay, my brain won't stop when it is about tuning up my PG xtra.
I have an XG tubeset with lenses and LC hardware in sight, and I am thinking about modifying my PG chassis to accept the XG LC tube hardware. To my understanding the PG xtra tube shell is very-very similar (if not the same) to XG AC's tube shell, and given the fact there was AC and LC type of XG they should have some similarities as well. I didn't find any valuable information about XG AC->LC conversion not to mention PG xtra AC -> LC. Can Someone light me up in XG AC-> LC conversion, or can tell about the XG AC - PG X tube shells' differences?
| Posted: Sun Oct 07, 2012 9:49 pm Post subject: |
As far as i know the tubes all have the same face on them. They are all P16s.
| Posted: Mon Oct 08, 2012 5:35 am Post subject: |
But the two big black screw have the same base width on both type? Probably I'll have to change the red and blue tube, because not sure if the longer XG tubes will fit in my. PG
| Posted: Mon Oct 08, 2012 12:02 pm Post subject: |
The LC housings wont mount up to the AC mounts though either as far as i know, when i looked inside the LC XG the mount is different. Im not sure by how much or if they will bolt straight into an AC XG, i havent looked close enough to know for sure.
digitalayon
| Posted: Mon Oct 08, 2012 8:03 pm Post subject: |
This would be a non-starter for me.....I'm all for modding but this goes beyond!!! But if you like a challenge....mod away!!!
| Posted: Tue Oct 09, 2012 12:00 am Post subject: |
You give up very easily then by the sound of that.
| Posted: Tue Oct 09, 2012 10:21 am Post subject: |
Well I thought I could do it with some drilling and a bit machine work. But now it seems to be a bit more difficult.
So here are pictures what I gathered:
This is my PG xtra's face shot, note the small gaps between the tubes:
This an XG AC, found on e-bay, note the wide gaps between the tubes:
This is SpankyHam's XG LC, note the smaller gap between the tubes than XG AC:
Also if I am right the XG LC tube assembly is 177mm wide while my PG tube assembly is only 173mm wide, but the maximal inner width of the PG xtra chassis is 53cm so I am afraid they won't fit easily in.
| Posted: Tue Oct 09, 2012 12:49 pm Post subject: |
I had a feeling the chambers were wider, itll take abit of cutting, but you may still get them in between the plastic sides, if you cut out the right areas and modify the mounting points youll be right, id move the tubes further forward in the set, maybe leave the green back further. This will mean a slight difference in tube face usage, but green will be larger which is ok cause it would mean itll wear more in sync with the blue.
Big job, but certainly not imposible for a man of you abilities.
digitalayon
| Posted: Tue Oct 09, 2012 4:39 pm Post subject: |
I just think it would be easier to re-tube the XG.
| Posted: Tue Oct 09, 2012 5:19 pm Post subject: |
Well, maybe but, nowhere near a burnt tubed XG. Anyway an XG is bigger and louder than a PG, and my PG just fits right in it's place on the floor, don't want any bigger pj at the moment. Also I think the PG xtras are far underrated, so I want to show everyone what can be done with these sets.
digitalayon
| Posted: Fri Oct 12, 2012 11:12 am Post subject: |
I am listening....I have a 933 runco....same as an extra....you have my attention. What is your plan? I would not mess with the AC stuff. I would leave that alone. What I would be doing is finding ways to increase bandwidth and moome type additions or modded cards for adding hdmi or dvi. I think that would be more usefull.
| Posted: Fri Oct 12, 2012 11:42 am Post subject: |
To be honest the bandwidth of the PG xtra is not bad at all, however I think I've found a way to increase the bandwidth of the machine, it is described here:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=32262.html
The above mentioned CXA1209P is clearly the bottleneck regarding bandwidth, it should be replaced with the CXA1299P (if I could find one! ) or bypassed with an other part, there are countless similar RGB predrivers in the 150-180MHz range usually found in 17"-21" CRT monitors, but none of those are pin to pin compatible with the CXA, so massive rewiring would be neccesary but that is not a wise idea when we dealing with high frequency.
On the other hand I think the best thing which has ever been invented for CRT projection is the liquid coupling, it really makes difference.
| Posted: Fri Oct 12, 2012 12:30 pm Post subject: |
Adding DVI or HDMI is pointless on a PG, its factory fitted with RGB-HV. Use an external HDMI - RGB device.
| Posted: Fri Oct 12, 2012 12:32 pm Post subject: |
| CasetheCorvetteman wrote: | | Adding DVI or HDMI is pointless on a PG, its factory fitted with RGB-HV. Use an external HDMI - RGB device. |
Or fit a HD Fury inside the box
| Posted: Fri Oct 12, 2012 12:40 pm Post subject: |
Yeah either device will do.
Digitalayon, did you not recently say you believe HD-145 lenses are a simular answer to LC, questioned the advantage to going with LC and claimed there to be misinformed guidance within the thread? Im just trying to understand this here cause you appear to have a differing stance in each thread. Maybe im reading itvwrong and youre trying to steer Gjaky away from the major step up to LC?
| Posted: Fri Oct 12, 2012 1:03 pm Post subject: |
| CasetheCorvetteman wrote: | Yeah either device will do.
Digitalayon, did you not recently say you believe HD-145 lenses are a simular answer to LC, questioned the advantage to going with LC and claimed there to be misinformed guidance within the thread? Im just trying to understand this here cause you appear to have a differing stance in each thread. Maybe im reading itvwrong and youre trying to steer Gjaky away from the major step up to LC? |
I think he wants his Runco 933 modded as well, but he is more interested in only electronic upgrade than optical upgrade as well.
digitalayon
| Posted: Fri Oct 12, 2012 3:25 pm Post subject: |
| gjaky wrote: | | CasetheCorvetteman wrote: | Yeah either device will do.
I think he wants his Runco 933 modded as well, but he is more interested in only electronic upgrade than optical upgrade as well. |
I believe the HD-145's ARE FREAKING AWESOME!!! What I meant in the other thread about misinformation was that comment about tanks being available for a 1208. I had never heard of that configuration. I have for a 1209 but not a 1208. And as for modding my 933 electronically, yeah I maybe interested in having some fun. But I am suggesting to this would be modder to mod in areas where real differences can be made. Not in lens mods where he already has something nice. Now what he can do is take the green from the XTRA and put it in his XG...he can start there and then all he needs is a blue and I think he's golden. However in terms of noise, I think it would be easier to get creative on fans in his XG than it is to mod the optics. My 933 is a freak'n wind tunnel. I do not think the XG is any louder from the ones I heard in the past. In terms of size... a couple of inches is not a bother to me but that is just me.
| Posted: Fri Oct 12, 2012 3:39 pm Post subject: |
While HD-145 is really great lens when it comes to resolution, but any LC lens beat is when it comes to contrast, personyally I appreciate more the contrast ratio than the pure resolution. Not to mention HD-18, and HD-134 lenses are just as good as HD-145
I don't have an NEC XG I only have access for three tubes in XG LC mount with lenses, and no, I haven't purchased them yet, just thinking on it... maybe it would worth the effort.
Anyway 8" LC barco also can be done with original barco LC chambers... my friend has one spare set 8" LC chamber with scheimpflug adjustments.
digitalayon
| Posted: Fri Oct 12, 2012 7:45 pm Post subject: |
OK now you are making sense......I did not know you were not getting the whole projector. And the Barco tanks probably came from a Cine8 or Onyx model since they do fit the 1208. Good call on the contrast ratio over the resolution though. But perhaps you will find a way to have your cake and eat it too.
