Marquee HV dropping out with no arcing
Goto page Previous  1, 2, 3
Posted: Thu Oct 18, 2012 2:51 am    Post subject:
Ben with the thomas tubes the focus coil and deflection coil placement is crucial to good focus. Also if your HV supply is not the 34.9kv model they will to get good focus. a robust power supply provides the best focus for the thomas tubes. At least that is my theory. I think a slightly higher voltage of maybe needed, maybe a 100 or 20 more volts. I wanted to try to crank up a HVPS but was afraid to try it. One reason is I don't have a scope probe able to handle that much juice to get a safe reading
I know when i firsr was testing them I had a M8000 HVPS in my test bed and focus really sucked, i thn read some where that most newer tubes need the higher output HVPS. Sure enough they focused much better. Check your HVPS to see what voltage it is.
CRT_Ben
Posted: Thu Oct 18, 2012 3:12 am    Post subject:
Hey Nash,
Long story short, I'm wondering if the tubes I got from CJ are different somehow from Antoine's tubes. Both my HVPS are the 34.9KV model, and at some point years ago I did try moving the focus coil up and down the tube, to little avail. I also used frankenyokes for awhile - they improved the focus, but still not nearly enough. The deflection coil is snug against the bell of the tube, as I assume putting it farther back would be dangerous.
Posted: Thu Oct 18, 2012 3:19 am    Post subject:
Ohhh, ok. Yeah the other tubes just might be the same tube antoine had but just heavily used. From chips comments on how long the phosphor is lasting i bet its the guns wearing out sooner , which usually doesn't happen in that order.
ok have you cleaned your connections on the CLM chips and daughter boards recently?
But from your explanation of the problem it seams lie a VNB issue or the VIM. It sounds like a spot kill circuit problem. Id loose HV in bright scenes sometimes and other times the image would jsut blank out where it shut the 85 voltage to 0.
Pain in the ass to find that out. You have ti run the PJ with each one VNB off at a time to find the bad VNB.
CRT_Ben
Posted: Thu Oct 18, 2012 4:30 pm    Post subject:
Regarding the CJ Thomas tube, I have no explanation, but I don't think the gun is worn out - get this: I have to run the G2 around 43 (!) to make the raster disappear on this tube. Forty three!! I've never had a stock panasonic tube with G2 values less than the mid 60s. Maybe the Marquee electronics aren't quite right for the tube and it's being overdriven somehow, causing soft focus. One last complaint about the tube - the phosphor grain is UGLY. When getting the optical focus just right, it looks like you threw sand on the screen. I'll be glad not to be stuck using this particular tube, it may well be different than Antoine's, I don't know. Someday when I have too much time on my hands (ha), I'll hook up one of Antoine's tubes bare, just to see how they are. With sunglasses on it's easy to see what's truly sharp even on the face of the tube, without a lens.
Regarding my current issue, I think I reseated (pressed down on) the socketed chips on the CLM and daughter board a month or so back when having my first green tube issue, but I can try again. I have a spare CLM but the projector does not power up with it, so it's faulty somehow.
It does really seem like a spotkill problem, but I thought I had isolated the green tube by this testing:
Blue disconnected, running Green and Red: Problem occurred within 30 minutes
Red disconnected, running Green and Blue: Problem occurred within 30 minutes
Green disconnected, running Red and Blue: No issue (over ~90 minutes of running)
So, I had previously swapped the green VNB for a spare, then swapped all VNBs for spares, then swapped the green tube and the VNB again because I had to use my modified VNB. I think I need to continue running Red + Blue to see if the problem happens over several hours.
Regarding the spotkill on the VIM, is it for each color individually or is for all three colors at once? If individual, perhaps with the green tube disconnected, the issue doesn't come into play. I did swap the VIM but I can try swapping back to see if that has any effect.
Posted: Thu Oct 18, 2012 6:01 pm    Post subject:
Each color has it's own over current spot kill circuit.
With the New tubes from Antoine just looking at the phosphor on the tube itself it is the smoothest i have seen on any tube.
CRT_Ben
Posted: Thu Nov 15, 2012 10:17 pm    Post subject:
A quick note to provide closure to this thread - I can't stand when I have an issue, find an old thread exactly about what I'm looking for, and then the thread trails off with no resolution.
Unfortunately this time there was no positive resolution: I couldn't fix the issue. Every single part (other than cables such as G2 and VIM RCAs) in the projector was swapped with exception of the following: convergence board, astig board, CLM, motherboard, backplane, red tube, blue tube. I have to vent a little here because I've set up so many of my friends and family with CRT projectors, but I kept my very best tubes and chassis, put them together, mount it, build a hushbox, and this happens. I've set up two Sony 12xx projectors for others, as well as a Marquee 8000 and another 8500, and they (knock on wood, I don't WANT them to fail), have run flawlessly for everyone else. Obviously it's bad luck and not design, but it sure feels like a kick in the teeth. It figures, eh? After countless hours sunk into this machine I cut my losses; see my post in the Gray Forum.
Posted: Fri Nov 16, 2012 10:39 am    Post subject:
Say Ben
Before you pull the plug here, why not ask Mike Parker to look this over?
CRT_Ben
Posted: Fri Nov 16, 2012 4:35 pm    Post subject:
Tim in Phoenix wrote:
Say Ben
Hey Tim,
That is a good thought, and I appreciate your past and continued assistance. I have met Mike at one of William's home theater meets in the past, so I would have had a pinky toe in the door to ask him for help, which of course would be paid for.
That said, my new machine is in, and B-stock is non-returnable. Right now I'm looking at parting out the machine as well as my backup chassis. It's a little dicey, as something is not working right, yet all parts swapped in and out seem to work perfectly fine.
Let me know if you want dibs on anything; I will have two sets of R&G (the real green) C-elements as well as the mint set of 9" tubes, among everything else. I'm not going to ask top dollar for any of this as I'd like to just liquidate and move on, and I'd also like to see someone else get the parts they need.
Ben
haireez
Posted: Fri Nov 16, 2012 5:14 pm    Post subject:
Hi Ben,
2 weeks ago, I had a big headached as to why my Vision 1 was unable to fire up. I had changed almost every boards from my 2nd set of Vision 1 including the motherboard but still couldn't fire up my projector. Embarassed
The only board that was not change is the backplane. Just before I decided to teardown everything apart to replace my spare backplane, I check every cable connectors to ensure no loose cable but still unsuccessful. Crying or Very sad
However, my vision 1 start firing immediately after I start to push up the HVPS cable connector that connect to the backplane. When you released, it stop firing. Therefore, I decided to lightly bent the connector downward and again it start to fire and till now, I do not have any issue with my Vision 1. Wink
Maybe you could try this method and hopefully, your Marquee had the same problem as mine.
GOOD LUCK!!! Laughing Laughing Laughing
 Filesize:  183.94 KB
 Viewed:  2523 Time(s)
2 White Vision 1
Page 3 of 3
