fefrank
| Posted: Tue Aug 07, 2012 7:27 pm Post subject: Eisenmann Barco 1208 s2 mod |
I have been meaning to ask around here about eisenmann's barco hdmi on-board card. It's kind of sad that momme doesn't have one for barcos. I want to know if is worth the 700 dollars to update my 1208 barco to that. I checked my tubes, green is pretty much done for and blue is almost there, i'll say between a 5-6 in the scale for blue, green is about 4-5 in the scale oretty burned out. Red is fine.
HaydnG90
| Posted: Tue Aug 07, 2012 7:59 pm Post subject: |
With tubes in that state, unless you plan to retube I wouldn't spend that much on a pj upgrade. Look for a Fury II and you'll have HDMI connectivity.
| Posted: Tue Aug 07, 2012 8:14 pm Post subject: |
A fury one should also work just fine. Will your 1208 sync to both negative and positive sync on inputs 3 and 5 ?
digitalayon
| Posted: Tue Aug 07, 2012 10:02 pm Post subject: |
Felix....retube her, put in the HD-145's you are getting from me, and get the fury 3 or moome box
fefrank
| Posted: Tue Aug 07, 2012 11:22 pm Post subject: |
Thanks digital, Yes I guess it all comes down to that. I will re-tube her, but I've heard that the hd fury will not have the same razor sharp image than an on board circuit hdmi?
Phoenixed
| Posted: Wed Aug 08, 2012 3:03 am Post subject: |
Will YOU be able to truly see the difference is the real question?
| Posted: Wed Aug 08, 2012 3:17 am Post subject: |
| Phoenixed wrote: | | Will YOU be able to truly see the difference is the real question? |
Most likely no .
Put the savings toward the newer tubes...
RaWsHaRk
| Posted: Wed Aug 08, 2012 12:48 pm Post subject: |
| fefrank wrote: | | Thanks digital, Yes I guess it all comes down to that. I will re-tube her, but I've heard that the hd fury will not have the same razor sharp image than an on board circuit hdmi? |
yes I am sure Eisemann will say that. perhaps its even true but difference is smaller than 99% of ppl will see. and the Fury you can always plug in to another projector, or even tv. and its easier to sell if you need to, not many ppl will shell a lot of dough for that hdmi-card these days.
_________________ Electrohome Marquee 7500.
| Posted: Wed Aug 08, 2012 5:24 pm Post subject: |
Eisemann makes a lot of claims or should I say clams on his HDMI board. Now back to my negative or positive sync on input three and five question...
If you can find a fury 3 it outputs both pos and neg sync with a switch. Not sure about the Fury 2.
digitalayon
| Posted: Wed Aug 08, 2012 5:28 pm Post subject: |
| Tom.W wrote: | Eisemann makes a lot of claims or should I say clams on his HDMI board. Now back to my negative or positive sync on input three and five question...
If you can find a fury 3 it outputs both pos and neg sync with a switch. Not sure about the Fury 2. |
why so hard to find a 3?
Everyone is still using them!
digitalayon
| Posted: Wed Aug 08, 2012 11:31 pm Post subject: |
That was my point...you can still buy them....just not second hand!!
fefrank
| Posted: Fri Aug 10, 2012 6:52 pm Post subject: |
Thanks everyone for the wonderful input in this, now the question is. Who has pt18-205 tubes for sale? VDC is charging me a fortune to retubes these babies. So who has something for sale? I need a green one and a blue one. I need a green one the most.
Phoenixed
| Posted: Fri Aug 10, 2012 7:33 pm Post subject: |
Define "fortune".
fefrank
| Posted: Fri Aug 10, 2012 10:00 pm Post subject: |
A fortune, meaning more than i can afford right now.... Hey! do you have some you want to sell to me ? how much ?
| Posted: Fri Aug 10, 2012 10:18 pm Post subject: |
PT-205 are VERY hard to find. I have a brand new 180DVB (stock Barco tube) that I'd sell for $500 incl shipping.
Phoenixed
| Posted: Fri Aug 10, 2012 11:46 pm Post subject: |
I was really just curious as to the cost reutbing.
fefrank
| Posted: Sat Aug 11, 2012 1:54 am Post subject: |
they told me it was 1100 dollars to re tube each tube since they are high resolution tubes. Too much money for me. Curt are those high resolution tubes? are they goign to be a step down of the pt18-205s?
| Posted: Sat Aug 11, 2012 4:06 am Post subject: |
I'll let others comment on how big the difference is. The 180 tubes are the stock tubes that came with almost all 1208/808 sets. You sure wont' get twice the difference between the stock and high resolution tubes, but I do think the beam spot is tighter on the P series tubes. How big a difference, I'll let others comment...
