NAD T-754 no audio output
dturco
Posted: Fri Jul 13, 2012 3:14 pm    Post subject:
macgyver655 wrote:
Do you have test leads with the hook clips? http://www.ebay.com/itm/1-pcs-Small-Test-Hook-Clip-to-Banana-Plug-for-Multimeter-Test-Lead-Cable-100cm-/251016735649?pt=LH_DefaultDomain_0&hash=item3a71c36ba1
No. Just the straight pin type.
http://www.hulu.com/firefly
Those foil covered ribbon cables disconnect from that main board, correct?
dturco
Posted: Fri Jul 13, 2012 3:20 pm    Post subject:
Yes they do. They are held in place by a clamp on the end? Its like a guide more than a clamp? But yes they can be removed.
Posted: Fri Jul 13, 2012 3:22 pm    Post subject:
Then get a set of those hook clip test leads and we can continue. Of course the link I posted is from China so is there a local electronics store near you?
Posted: Fri Jul 13, 2012 3:27 pm    Post subject:
Ratshack has some if there is one near you. http://www.radioshack.com/product/index.jsp?productId=2062624
Or make your own..... http://www.radioshack.com/product/index.jsp?productId=2062232
Posted: Fri Jul 13, 2012 3:29 pm    Post subject:
I dont like the adapters though. They are to long for most cases when assembled... http://www.radioshack.com/product/index.jsp?productId=2062221
Posted: Fri Jul 13, 2012 3:30 pm    Post subject:
The kit is ok if you want more of an assortment.. http://www.radioshack.com/product/index.jsp?productId=11931581#
dturco
Posted: Fri Jul 13, 2012 3:46 pm    Post subject:
Will any of these from Sears work?
http://www.sears.com/shc/s/tools-electricians-tools-lighting-multi-meters/s-1021185?keyword=multimeter+leads&viewItems=25&autoRedirect=true&redirectType=CAT_REC_PRED
Posted: Fri Jul 13, 2012 4:05 pm    Post subject:
Yes, either one of these should be fine.
http://www.sears.com/extech-electronic-test-lead-kit/p-03416265000P?prdNo=2
http://www.sears.com/craftsman-test-lead-kit-with-storage-pouch/p-03482399000P?prdNo=1
dturco
Posted: Fri Jul 13, 2012 5:04 pm    Post subject:
I'm going to Sears. I'll post when I have the test leads.
dturco
Posted: Fri Jul 13, 2012 8:38 pm    Post subject:
I'm back. I bought the Sears pouch one.
Posted: Fri Jul 13, 2012 8:44 pm    Post subject:
Very good. I've been looking at your second image and it looks like if you disconnect the foil ribbon nearest the heatsink you should be able to use those hook clip leads to the legs of those regulators. Then lay the wires down and reconnect the foil ribbon and test the voltage. 1 at a time naturally.
dturco
Posted: Fri Jul 13, 2012 9:08 pm    Post subject:
Man there is still sh*t blocking the way
Posted: Fri Jul 13, 2012 9:20 pm    Post subject:
You can bend those orange disk caps away from the regulators to give you some more room.
dturco
Posted: Fri Jul 13, 2012 9:35 pm    Post subject:
I have. C-733> 0.501 > VDC.
Are we getting anywhere?
Posted: Fri Jul 13, 2012 9:42 pm    Post subject:
You should be connecting to the regulator legs, which are the U numbers. Go back to my image to show what legs to connect to.
dturco
Posted: Fri Jul 13, 2012 9:45 pm    Post subject:
My mistake I read the board wrong. The C-733 is the little orange thing in front of the U-707 the leads are attached to. The reading is the same power on or off.
U-707> 0.501 > VDC.
U-705> 0.643 power on> 0.653 power off.
U-703> 179.5 power on> 87.1 power off
Posted: Fri Jul 13, 2012 10:30 pm    Post subject:
Something is not right. And where is U733?
dturco
Posted: Fri Jul 13, 2012 10:37 pm    Post subject:
Doah U-707 Embarassed
Posted: Fri Jul 13, 2012 10:38 pm    Post subject:
Lets just do 1 first. U707. Pos clip lead on the right outer leg and the neg lead on the center leg. DMM on DC. Power on, whats the voltage?
Page 3 of 5
