gjsmo
| Posted: Sat Jul 07, 2012 2:29 pm Post subject: |
| gjaky wrote: | | macgyver655 wrote: | | I think you'd be better off shutting down those tubes and running it till it shuts down and see if it spits out a code. The code may tell you more. |
The picture mute function is just right for this, get an error code, and just then dig deeper. |
Yes, but to my knowledge this only mutes the picture to be displayed, not the menus. It certainly doesn't turn off the tubes, you can still see the edges of the raster. As it is, I'm going to be shutting down the tubes to try to fix the H Deflection board, so if it ends up giving me an error code, I'll certainly post it.
| Posted: Sat Jul 07, 2012 2:40 pm Post subject: |
| gjaky wrote: |
Fark no!! Definately not, you can still get a spot burn cause if it switches sources or loses sync with a source it will turn off the pic mute!!
| gjsmo wrote: |
Yes, but to my knowledge this only mutes the picture to be displayed, not the menus. It certainly doesn't turn off the tubes, you can still see the edges of the raster. |
All true yes, as well as my previous comment above.
| Posted: Sat Jul 07, 2012 3:00 pm Post subject: |
Correct, don't use the mute function. That only mutes the video signal, not the signal and power from the tubes. A deflection fail will still burn the tubes as the raster collapses.
