NEC 9PG, my cheap setup
fuchs
Posted: Fri Nov 30, 2012 10:48 pm    Post subject:
okay, so I got this ISF-calibrated Epson TW-620 for free, but with a broken lamp.
So for the fun of it, I've ordered a new lamp. So far, so good.
After the initial 3LCD, native 16:9 ratio, no-convergence, 15-minute alignment, 1600 ANSI lumen output joys, it was movietime!
God, 2 meters wide, 1600 lumens of output brightness!
... then I noticed something was odd.
Dirty Harry's face was purple. The movie looked like it was shot on Super8.
Captain Picard's face was greenish. The Enterprise was floating in fog, not in space.
And this feeling that those 1600 lumens didn't really look like 1600 actually.
It felt even more dim than my NEC 9PG, which seems rated at only 800 lm.
As my projection surface is limited in height but not width, I'm now planning on setting up the NEC in 16:9.
The extra width was about the only thing I really liked about the LCD-projector Rolling Eyes
.. I actually expected more of this. Neutral
onkel fuchs' cheapskate cinema
NEC plain 9PG
Posted: Sat Dec 01, 2012 3:48 am    Post subject:
Yeah mate, 1600 lumens, but 400:1 contrast ratio... Compared to your PG 15,000:1 contrast ratio...
PeeGee9er
Posted: Tue Dec 11, 2012 1:09 pm    Post subject:
That 9PG looks quite familiar Smile
fuchs
Posted: Tue Dec 11, 2012 5:16 pm    Post subject:
I'm sure it looks just like a whole lot of other 9PG's Very Happy Exclamation
Or do you know anything about this machine's history ?
edit: hey it's you!
I've eventually hit a sweet spot in the memory banks at 1152x864@72Hz. It will recognise this resolution and for some reason, that specific resolution has no convergence drift during warm-up either. Strange but true!
It's been running for quite a few months now without any problems or adjustments.
NEC plain 9PG
fuchs
Posted: Thu Apr 11, 2013 8:48 pm    Post subject:
Okay, so I liked the extra width but not the LCD projector.
During christmas sale, I got me a 7' (2m) electric screen Very Happy
Projecting on the wall was nice to begin with, but I didn't really have any space to go any wider.
It was a good time to try and re-set CPC/Astig, and re-set the image on the centers of the tubes.
I think I understand the importance of the CPCs better now. It seems related to focus at higher light intensities, kinda determining the 'landing zone' of the higher intensity signals.
I don't like working so close to high-voltage, but it was worth it. Less pixel smear when turning up the contrast.
I've now set it up in 720p @ 72Hz. I've reduced the H-porch settings by about 100 pixels, so I can use about the maximum width the projector will allow on the tubes. I figured that the extra heat generated on the sides would be compensated with the lower height of the (widescreen) picture compared to 4:3.
I haven't finished point convergence yet, but I'm pretty happy with the results so far.
 Filesize:  175.63 KB
 Viewed:  6316 Time(s)
 Filesize:  179.86 KB
 Viewed:  6322 Time(s)
 Filesize:  145.88 KB
 Viewed:  6317 Time(s)
 Filesize:  130.59 KB
 Viewed:  6558 Time(s)
 Filesize:  98.91 KB
NEC plain 9PG
Posted: Thu Apr 11, 2013 9:01 pm    Post subject:
Hey, that looks pretty good! How is your syncing problem?
I have to adjust focus and astigmatism on my boss' 9PG, now it is soft like an ES machine, but it has been recently recapped and the whole unit has about 800hrs in it... I have a 6PG xtra and I really like it, but never saw a good PG plain in action, and am really curious about it.
Posted: Fri Apr 12, 2013 2:07 am    Post subject:
Bleed those tubes Onkel!!
fuchs
Posted: Fri Apr 12, 2013 9:39 am    Post subject:
I don't think I'll try to repair it. I did find a good workaround though; it really seems to love certain H-freq's.
So I've 'padded' the 720p VGA signal with extra (useless) vertical resolution until I got somewhere in the 64.x kHz.
It will recognise it okay. Another plus is that I didn't have to use as much squeeze in the V-Amplitude.
Ofcourse I am losing some bandwidth.
If you're wondering why I probably won't repair this projector, I've attached a picture of a 75%-white-projection.
The picture is more-or-less accurate, including the hotspot. It's just not worth it.
This is actually not so noticable in watching movies, so I'm happy with it as-is.
Maybe I'll move the projector back a little.
Well .... mine is pretty soft too. Only the red tube is sharp to the point that you can see individual pixels in 720p.
I don't mind. The challenge of course, is to get the most out of it Wink
How is your Xtra? I'm equally curious about the performance of the newer NEC brothers.
Good thinking. I've contacted the previous owner about this, he has already done it a few years ago.
Do you think the bleeding should be repeated every so-many years?
 Filesize:  61.81 KB
 Viewed:  6507 Time(s)
NEC plain 9PG
Jeremy112
Posted: Fri Apr 12, 2013 2:11 pm    Post subject:
Yes!! I had not done this to my NEC XG when I first purchased it, it was because of the pressure in the liquid chamber of the tube that cracked my green CRT, and the glycol leaked inside the tube (thankfully). I immediately shut the projector off, took the lens off, & sure enough, half the glycol was in the tube face & there was a nice internal crack on the phosphor face of the CRT.
So DO bleed those CRTs!! They will save you time & money. Its pretty straight forward to do, there is a topic on the site under advanced procedures on the top of the site.
Worth doing before it busts, especially if it leaks all over the circuit boards.
Posted: Fri Apr 12, 2013 7:47 pm    Post subject:
It's sad, you really loosing precious bandwidth with pushing the 720P in to the 64kHz range, there will be no drawback of squeezing the vertical height. You should really take the time to repair that board. Maybe your board only need readjustment, if you have an oscilloscope, and can handle it, I could help you what to measure and how.
Otherwise, guys are literally throwing away NEC PGs, so you can get better working DEF boards next to nothing.
I think my PG xtra is pretty sharp, with a careful setup the scanlines are just touching at 720P, an other thing that I've noticed the PG xtra has smoother menu control, adjustments are finer, and have more convergence options (independent focus on all edges, independent keystone on all edges, dynamic astigmatism...)
Posted: Fri Apr 12, 2013 9:27 pm    Post subject:
You should bleed if there is no bubbles and you dont know when it was last bled, a few years ago by previous owner doesnt mean anything if there is no bubbles.
In terms of sharpness, the 9PG i have is very sharp, on 1080i the middle is almost as sharp as my XG, however the edges are not. For 2 reasons, its not as sophisticated electronics wize ( although still more so than almost any other projector in its day ), and its got HD-6 lenses instead of HD-144s. If yours isnt ultra sharp, you need to work on the focus, which youre going to get a chance to do after you bleed.
When doing alignment, make sure all images are centered and line up in the center of the screen WITH THE LID SHUT!!! Dont use static to get them lined up, its really not that hard to do this right.
To get the lens focus perfect, display a white screen, totally defocus electronically with focus pots on DEF board, then use binoculars to see the screen and turn lens barrel til you see the phosphor grain snap into view. Do the outer the same way, and make sure youve got the flapping rings the right way up, there is a little arrow on them, hopefully youve got a full set of the right ones Wink
Set all focus settings to zero before doing astig, then before you do focus pots, turn off blue defocus, set center focus to -10 on all 3, focus with pot til razor sharp in the center group of Hs. Do the outers using the menus, but the center should stay on minus 10, cause that is where you set it before. Last thing you do is turn blue defocus back on.
I have not touched the convergence on my 9PG in over 12 months now and its pretty much right where i left it, no good reason it should move if you do this right Wink
fuchs
Posted: Fri Apr 12, 2013 9:55 pm    Post subject:
oh ... wait a minute ... focus ...
I've completely forgotten about Center and Edge focus after adjusting the magnets.
[fast forward 30 minutes]
Well the Edge focus went from -18 to +80 but the edge-sharpness has improved a lot, wow.
Especially in the green and blue. I'll be back! Very Happy
NEC plain 9PG
Posted: Sat Apr 13, 2013 2:05 pm    Post subject:
Sounds like you jumped the gun abit here Wink
Dont play around too much, the tubes have to come out yet!!
fuchs
Posted: Sat Apr 13, 2013 2:45 pm    Post subject:
Yes, well ... I did, indeed. I just had to watch something to check out the extra sharpness.
Reading the "Bleeding CRT" pages and watching the videos now.
I plead err ... innocent... Wink
I just figured out that swapping cracked tubes would be even more work than bleeding them.
Thanks Case/Jeremy for pointing out the consequences.
As for the electronics... I'll just leave it for now, maybe some DEF/SYS boards turn up somewhere soon.
NEC plain 9PG
fuchs
Posted: Sat Apr 13, 2013 10:41 pm    Post subject:
I really, really, hate you guys Exclamation
I'd rather have had the illusion that everything was just fine. Wink
There are indeed no bubbles in any of the tubes.
Thanks for the extensive how-to, Curt.
You've probably heard that before.
 Filesize:  229.26 KB
 Viewed:  6402 Time(s)
NEC plain 9PG
Posted: Sun Apr 14, 2013 2:08 am    Post subject:
Bet youd have hated us even more if no one told you to bleed them and one broke, spilling glycol into the guts of your fine machine!! Laughing
fuchs
Posted: Tue Apr 16, 2013 4:06 pm    Post subject:
Well, I can't hate you for telling the truth, of course.
It felt more like a rite of passage, unscrewing tight phillips-screws at the end of a thin glass tube neck.
And again, almost stripping the tight red tube's bleed screws.
And buying a syringe without trying to look like a junkie Mr. Green
The bleeding was not spectacular, the glycol just slowly came out a bit.
I've found some new screws to put back in. Do I clean with alcohol or something like that?
 Filesize:  77.63 KB
 Viewed:  6345 Time(s)
NEC plain 9PG
Posted: Tue Apr 16, 2013 4:20 pm    Post subject:
The screws must made from some stainless material, as glycol is highly corrosive.
I found it easier to leave all the magnetics where they are, and pull the plugs instead.
fuchs
Posted: Tue Apr 16, 2013 10:01 pm    Post subject:
oh. Two more things I didn't think of. Thanks.
As a matter of fact, I just may try to put on the magnetics before putting the tubes back in, sounds like a good idea
Are the magnetics under high voltage? I'd have to probably turn them with the set on to get the picture lined up mechanically.
NEC plain 9PG
Posted: Wed Apr 17, 2013 5:08 am    Post subject:
Just dont touch the conductors and youll be fine. Its pretty easy Wink
Make sure you null all settings before you adjust magnetics. I always leave them in the set with a plain PG, personal preference.
I havent ever replaced screws that hold in the coolant before
Page 3 of 4
