What Colorimeter are You Using
Goto page Previous  1, 2, 3
Alaric
Posted: Fri Dec 22, 2006 6:22 pm    Post subject:
Hi There,
Has anyone played with the HCFR software. I downloaded it last night and it looks potentialy good.....However there are 4 settings for the Spyder2 - standard, LCD, CRT, PROJ and do you have the baffle/fliter on or off and the sensor facing screen or PJ.
CRT could be direct view, LCD is wrong, Standard i'm unsure, PROJ sounds interesting ?
Alas while the software has an english option, the help is french....It seems intuative if you know a bit about calibrating, if your a newb, start reading or learning french !
With Calman i use it as advised for a CRT Projector with thier CRT Front setting, the baffle off and in reflective mode, so i measure off the screen.
When i tried last night, i couldn't get sensible readings from it, but in CalMan i have a fairly straight grey scale.
Ta,
Lee
Posted: Tue Jan 02, 2007 11:54 pm    Post subject:
JustGreg wrote:
Bruce 09 wrote:
I use the philips Colorimeter, it is specific for CRT's , But I have used it on a couple friends digital before
http://www.testequipmentdepot.com/philips/colortruth/pm563900.htm
http://www.testequipmentdepot.com/philips/colortruth/pm563925.htm
I Have them both the three headed sensor is meant to measure three points for white field uniformity, but I use the three head sensor directly over the crt lenses and adjust the three colours all at once.
Doing Greyscale at the projector or right at the screen on my screen yeild very similar results .
Bruce
$7K for a rarely used tool for a hobby all over what is probably a sub $5K projector?????? Shocked And you have two of the things??? Huh. Unless you're doing ISF, or are the idle rich, hire a pro to set it up. There. I jsut saved you money. Feel free to send me just 50% of what I just saved you and we'll call it even. Mr. Green
And you would be extremely naive to think that he paid that much for it. He probably paid less for it than most here spent on their Spyders. I found one for around $200 about six months ago, but didn't pull the trigger. I wish I had.
Bruce 09
Posted: Wed Jan 03, 2007 12:26 am    Post subject:
Yes I got a pretty good deal.
You should have bought that one Eric .
Bruce
Posted: Wed Jan 03, 2007 1:34 am    Post subject:
Bruce
Probably, but fortunately these things will continue to get better and cheaper. Of course, I may not need one where I am going. Smile
Who is this Eric? Razz
SYC
Posted: Wed Jan 03, 2007 4:53 am    Post subject:
Is there any procedure using HCFR with Spyder2 to calibrate a CRT FP? It is a little difficult to find one on A site.
SYC
dbaisey
Posted: Wed Jan 03, 2007 11:05 pm    Post subject:
Progressive Labs CA-1. Thanks to Marc for calibration against the Phillips. Doug
Frank D
Posted: Fri Jun 06, 2008 6:05 am    Post subject:
Was it easy to access the CA-1 files inside the unit to calibrate it? Or was it calibrated by some other method?
dbaisey
Posted: Fri Jun 06, 2008 2:54 pm    Post subject:
Frank,
It was more on the probe end from salt build up on the filters (moisture) Comparisons were from his broadcast monitor. Doug
Posted: Fri Jun 06, 2008 6:44 pm    Post subject:
See the sticky right in this forum called "GREYSCALE & COLOUR CALIBRATION FOR DUMMIES"
CRT_Ben
Posted: Fri Jun 06, 2008 6:53 pm    Post subject:
I had the same reaction, Kal, but before you take too much umbrage take a look at the timestamp of his post: Tue Jan 02, 2007 11:53 pm Wink
Page 3 of 3
