What about an oppo 83 ?
Posted: Wed May 02, 2012 1:48 pm    Post subject:
Jeff,
I think you are using a Moome internal card now? Or an HDF3 or HDF2? If you have any of these, go into the Oppo video setup menu and set the video output to YCbCr422. I suggest leaving deep color off, but some people like it.
In any event, YCbCr422 will provide 10-bit color and give better color definition than the default which is usually YCbCr444 or maybe RGB.
Enjoy,
jeffslife
Posted: Wed May 02, 2012 1:59 pm    Post subject:
Craig, I got the new moome card and do have the oppo set at 422, I have the deep color on right now I like the way it looks in the darker scenes, but I think it makes the reds too bright (just a little)
Thanks for the heads up
We are ALL job creators !
Posted: Wed May 02, 2012 2:22 pm    Post subject:
I didn't know it was possible to output deep color in 422 color space, is that something new on the 93.?
Last i tested it was possible to have deep color on with 422 but it just output 8bit.
Kurt
jeffslife
Posted: Wed May 02, 2012 2:47 pm    Post subject:
Options are off,off dithered,30 bit,30 bit dithered, 36 bit and it will allow any to be on while on 422.
What is dithered ?
edit, these are settings on the oppo not the moome.
Posted: Wed May 02, 2012 4:33 pm    Post subject:
Hey, Craig... How is YCbCr422 superior to YCbCr444 in this context? The source (BD) is 4:2:0 (10-bit?), right? Is the point just keeping the signal in a 10-bit color space? (422 is 10-bit and 444 is 8-bit?)
HaydnG90
Posted: Wed May 02, 2012 4:55 pm    Post subject:
What player are you comparing the Oppo to, Jeff?
Did you A-B with the same disk, or are you just going from memory?
Your comments are kind of tantalizing because I've been getting along fine with my PS3 since I started watching BD... But, I keep reading lots of great comments on the 83 and it makes me want to upgrade... I just don't want to spend the money!
Glad you like it.
Do it! You'll wonder why you never did it sooner. I know that was my reaction. The OPPO's are really slick units.
Posted: Wed May 02, 2012 5:03 pm    Post subject:
Here is some good stuff to read..
http://en.wikipedia.org/wiki/Chroma_subsampling
So for what i know, the color space don't really have anything to do with how many bit 8-10-12 or whatever, its the way the colors are put on top of the resolution. 422 like we get out of all players,its not pixel to pixel color resolution.
But selecting lets say 444 or RGB you make the player upscale your colors. Thats not very often a big hit done in a normal player.
So from what i have experienced, is that if you don't mess to much around with converting in the player, normally it will look better.
I always output 422 from my payer, into my scaler, and from there i output RGB, always made the best pq so far.
Deep color is not native in any disc i have heard about, so outputting 10-12 bit will not really help much, like you just change it, and risk messing it up.
So in my opinion deep color should not exist in any player or whatever, its just something invented for the demand of new features, and only makes a lot off confusion and worse pictures quality.
What i often notice is that if you don't see a difference in the picture sharpness and the colors, try look some fast motion.. often it will not look very smooth, like the processor in the player will not be able to calculate fast enough..
And something else.. Hope they put RGB color space on the disc before they start making 4K resolution..
I'm sure Craig can do a more prof, and technical correct answer..
Posted: Wed May 02, 2012 9:52 pm    Post subject:
It's been a couple years since I have looked at the math, but YCbCr422 pretty much retains all the information as found on the disc. Honestly, I have A/B'ed 422 10-bit and 444 8-bit and I can't see much difference. The biggest difference is jumping up from RBG 8-bit to either YCbCr422 10-bit or YCbCr444 8-bit. But if you have the option for YCbCr422 10-bit from BD, than it is the best possible option with the best possible video quality without adding or taking anything away.
Of course, all this is for BD and does not necessarily apply to other video sources.
Posted: Wed May 02, 2012 10:03 pm    Post subject:
stridsvognen wrote:
So for what i know, the color space don't really have anything to do with how many bit 8-10-12 or whatever, its the way the colors are put on top of the resolution...
Well, for BD the source is 4:2:0 8-bit, but for other sources you may find other color spaces and bit rates.
Exactly.
Depending on your scaler, you may want to try outputting YCbCr422 from it and to the projector. Assuming you are currently sending RGB 8-bit, YCbCr will allow more color information to reach the DAC's resulting in better color transition (more colors defined).
Pretty much deep color is useless on BD. The only sources that you may commonly encounter that can really use deep color are some HD video cameras. So if you are making your own movies or screening movies or the like you could possibly benefit from deep color if the source actually supports it.
Well, we can dream I guess Wink I question if we will ever even see a 4k optical format or not though. The industry is pumping 4k, but I fear it may be dead on arrival, at least as far as sources are concerned... I hope not...
Last edited by CIR Engineering on Wed May 02, 2012 10:23 pm; edited 1 time in total
Posted: Wed May 02, 2012 10:10 pm    Post subject:
Craig, 420 10 bit yes, but with 8 bit color graduation right.. So the 10 bit is not a deep color but a Pixel bit depth, Or did i get something wrong here.?
Posted: Wed May 02, 2012 10:24 pm    Post subject:
Sorry, my mind is mush. I just got done calibrating another TITAN 3D projector and I am fried. BD is 420 8-bit, not 10-bit.
Posted: Wed May 02, 2012 10:32 pm    Post subject:
Your the lucky one.. like i have limited resources, ill have to wait for better days to play with stuff like that. Laughing
Is it possible to make you rank the 3 top BD players ? I'm stuck with my OPPO 83, cant find anything better. But ill recommend the 93 for anyone buying new.
Posted: Thu May 03, 2012 2:03 pm    Post subject:
Honestly I feel the Oppo players are the best players at any price. Oppo sent me a test BDP-83 unit about six months before it was released. In just a few days I knew it was the best player I had ever used and I started recommending that clients wait for it's release.
I continued to recommend the BDP-83 until the BDP-93 was released at which point I started recommending both the 83 and 93. Oppo had sent me a beta BDP-93 about nine months before its release so I knew it was also solid. When the 93 came out, I biased towards the 93 because the 83 actually started selling used for more than the 93 cost new.
If you need higher quality analog outputs there is of course the BDP-85 and BDP-95 and I recommend those as well for higher end clients who use the player with analog audio.
In many ways I like the 83 based player better than the 93 based player mostly due to its faster boot time. But really both players get a top spot for 2D video. If you need 3D than only the 93/95 can do that.
If a client wants to spend more on the player I always point them to the scandal a couple years back with Oppo and Lexicon. Lexicon contracted with Oppo to take a BDP-83 and change the FW to say Lexicon instead of Oppo and then put the BDP-83 in a fancy Lexicon case. This was evidently worth $3000.00 more than the BDP-83 Wink
http://www.audioholics.com/reviews/transports/high-definition-dvd-players-hd-dvd-blu-ray/lexicon-bd-30-blu-ray-oppo-clone
If clients want to spend less I usually suggest just buying the very cheapest BD player that they can find which also supports YCbCr 422.
And really those are my recommendations on BD players. I've done plenty of work with the high end Pioneers which are ok, but cost more than the Oppo and are maybe just as good (maybe). And the high end Denon players a really expensive and no where near as good as the Oppo players.
Posted: Thu May 03, 2012 2:41 pm    Post subject:
My latest test was the Cambridge AZUR 651, its same as oppo93, just different front and remote.
I found it to be loading faster than my OPPO 83, and loved the 93 not using a fan, who annoyed me in both the 95 and 83..
For sound ill never use analog out on any blu ray player, they all sounds terrible, but guess that depends of peoples references.
What i noticed with the new 93 and 95 is that they have much higher ground potential, around 2x the 83..
So a player i would love to try is the THETA who is a 83 with good old trafo ps.
I'm allergic to switch mode power supply, and all the noise they send out. Unfortunate its not possible to find much video equipment whos not with SMPS.
My reason for me not keeping the oppo 93 is that i think the 2D picture looks a bit hard and artificial. I cant get the same depth in the picture. The 93 gives me a wow thats detailed feeling for 2 min, after that it annoys me.
I would have kept the Cambridge 651 if it didn't have the firmware bug, that don't alow it to output 720P and 1080i component out on BD movies.
Still would love if someone could test that feature on the OPPO 93 and see if its the same problem.
