g-90 focus yoke on marquee
Posted: Thu Apr 05, 2012 2:20 am    Post subject:
mr_ro_co wrote:
There is a wire color change from the G90 yoke connectors, where a green/blue pair connects to a white/orange (the static focus coil). My schematic is for the actual wiring colors that connect to the coils in the yoke. If you have any confusion over this, drill out the rivets that hold the plastic shell of the G90 yoke together so that you can see exactly how the wires go into the yoke. Cut off the Sony connectors, and separate out all the color pairs per my diagram. The confusing part is how the wires go into the inner bobbin for the (2) 6 pole and (2) 4 pole stig coils. But between my photo, diagram and a multimeter, you can measure DCR and should be able to figure it out.
Also, Scott emphasized the following:
The polarity of the dynamic and static windings are important. If the sides are way out or the top is way out of focus try reversing the polarity of the dynamic (sides) or static (top and bottom). Stigs really don't matter as they can adjust in both directions.
And:
It is good to ground one end of unused windings as they will pick up a static charge when HV goes up or down and can arc to important stuff, like you.
zGman also recommended using the grounding the unused coils.
Best regards,
Steve
Steve, Please add this to the frankenyoke thread for continuity for those looking into using the G90 frankenyokes.
The pics are the most important
mr_ro_co
Posted: Thu Apr 05, 2012 5:17 am    Post subject:
And:
Best regards,
Steve
Absolutely, very good point - this should redirect to update the frankenyoke thread. I'm relatively confident I will be able to get these yokes in my VV1 this weekend. I was gonna use the weekend to replace caps on new boards that got damaged in shipping, but that can wait! I'll take copious photos and will document the coil polarity, overall yoke positioning, etc.
Thanks!
Steve
andreas
Posted: Thu Apr 05, 2012 8:46 am    Post subject:
god morning! i have opened the housings and picked out the pairs. The color change is from orange/white to yellow/green. Acording to the scedual in the thread from mr steve that would be the static focus wires. Can i conect these to the static focus marquee wires and then do the same for the dynamic focus and so on. Do i even need to mesure the ohms? what i will do is to leave the 6pol wiring anone because the marquee doe not have them.
 Filename:  IMG_0265.JPG
 Filesize:  388.45 KB
 Downloaded:  480 Time(s)
andreas
Posted: Thu Apr 05, 2012 10:11 am    Post subject:
this must be it then. The ones that coming out of the coil in pairs are nor actually the right pairs then acording to your picture? the static focus must be the white/orange that turns to green/yellow. then there are opne more pair of green/yellow. Then there are two pairs of blue/red that is to be used as well. can i conect them and try if it works and then change if the wiribg is wrong? or would that destroy the PJ?
thanks again
 Filename:  IMG_0267.JPG
 Filesize:  371.68 KB
 Downloaded:  454 Time(s)
mr_ro_co
Posted: Thu Apr 05, 2012 3:04 pm    Post subject:
thanks again
Andreas,
That's what I said before. The inner bobbin is tricky because the wire pair groupings are not the actual pairs going to each of the four coils on that bobbin. Two of the coils on that inner yoke go unused.
These two drawings are from the Frankeyokes thread. Wink Wink Study them closely. One shows the exact wire identification to each coil in the yoke. The other shows the coil equivalence to the Marquee yoke. All of the information you are seeking is in these drawings. All your other questions must be answered by your experimentation.
If you want to be absolutely sure your pairs are correct, get a mulitmeter and measure their DCR and ensure it matches my drawing.
Per Scott, you may need to experiment with polarity of the dynamic and static coil connections. You will know this if the image is badly out of wack. The actual wiring of this needs to be identified and documented. The stig coil connections are not dependent on polarity.
You may need to rotate the yoke about the tube neck to get the image centered. This is unknown.
You may also need to reverse the orientation of the entire yoke. This is also unknown.
Unless you make a wiring error that shorts something out, the Marquee electronics should have no problem driving these yokes and there should be no risk of damaging the tubes.
Best,
Steve
 Filesize:  190.78 KB
 Viewed:  9258 Time(s)
 Filesize:  166.04 KB
Posted: Thu Apr 05, 2012 4:02 pm    Post subject:
you guys need a LCR meter to measure inductance. I found it invaluable for winding the Barkenstien Coils.
Andreas, doing a little coloring I see in that one pic Wink
nashou
dvh99
Posted: Thu Apr 05, 2012 4:06 pm    Post subject:
mike mentioned once some components on the fgm needed another value for these yokes to work properly.
this won`t be necessary if you wind the yokes to get the same inductance as the marquee coils though i`m not 100% sure.
andreas
Posted: Thu Apr 05, 2012 5:04 pm    Post subject:
thanks again for the good picture. The red lines are great i can see what is what now. A friend will come later with a multimeter so i can messure that the conections are the right ones. I just bind them together and start to hook all up now.
andreas
Posted: Thu Apr 05, 2012 5:06 pm    Post subject:
hehehe, yeh the lion king is the best=) the cables that is left alone, can i just put some tejp over the naked part?
andreas
Posted: Thu Apr 05, 2012 5:32 pm    Post subject:
my wiring! i will plug it in and try if it works=) lets hope for a miracle
 Filename:  IMG_0268.JPG
 Filesize:  384.24 KB
 Downloaded:  524 Time(s)
andreas
Posted: Thu Apr 05, 2012 6:09 pm    Post subject:
oh, the cpc magnets sits realy far back! should i cut of some of the plastic on the g-90 yoke to get the magnets more far upwards?? Confused
 Filename:  IMG_0269.JPG
 Filesize:  467.6 KB
 Downloaded:  444 Time(s)
Posted: Thu Apr 05, 2012 6:27 pm    Post subject:
What would be ideal would be to find a way to use some Variable control voltage that the Sony's CPC magnets use. I believe the CPC magnets are built into the sony Focus Coil. In the G90 there are no manual adjustments for focus, it is all done via remote.
I Was thinking of some how using the un used portions of the marquee that have a variable remote function for the CPC but there are not enough of them to use, for example, tint,detail, volume etc. Unless a separate amp board with the correct voltages and some sort of remote code could be built to utilize the G90 CPC magnets in the focus coil assembly. Too costly and too much time to do i would think.
you could remove the plastic housing and wrap the magnet structure in Rubber tape. I did that for a barco coil set while i was making changes in the windings. it freed up space for the CPC's.
andreas
Posted: Thu Apr 05, 2012 6:33 pm    Post subject:
aha, so the sony yoke can be put on without its housing and just tejp=) i was thinking of cuting the edge of and glue them. like the picture below:
 Filesize:  169.58 KB
 Viewed:  8505 Time(s)
Posted: Thu Apr 05, 2012 7:22 pm    Post subject:
You can cut that section off but dont have to glue it. The CPC clamps will hold it in place. Also adding a strip of medical tape length wise on the tube will help hold it in place as you slide it over.
andreas
Posted: Thu Apr 05, 2012 10:55 pm    Post subject:
Hello! Ive turned the PJ on and it works, but it does not work that good yet.... one thing is that the picture is leaning. The other and probably more dificult to fix is that the focus is not that good, specially not in the center. The good thing is that i can adjust astig all over the zones as original on the marquee! I figure that the astig conection is the corect then.
if i turn the overall focus up 100 it is defocusing but when ramping under 50 nothing more hapens, its like its out of range for where it would be sharpest. Do you think it has to do with the conections ive made? AND corner focus does not seem to do much. the center focus afects the cornes greatly and the corners are actually the shapest. When doing the rgb focus the range rans out when going down to about 20(same for all colors). now its time to sleep
thanks again for all help ive got from you all!
sorry for posting this in the wrong thread before,its geting late. by the way i did cut that section of so i could get the yokes more close to the tupe face.
mr_ro_co
Posted: Fri Apr 06, 2012 12:34 am    Post subject:
Athanasios,
The Sony CPCs are a separate yoke (I have them). The G90 focus yoke has 6 coils: (2) focus coils and (4) stig coils. The two 6-pole stig coils go unused in the Marquee.
Yes, I anticipated not using the plastic housing at all like you suggested, instead using tape.
Steve
mr_ro_co
Posted: Fri Apr 06, 2012 12:37 am    Post subject:
Sounds like you need to experiment more with the static and dynamic coil polarity and the over all yoke orientation.
Others have used these successfully, so it's just a matter of finding the same conditions they used.
Steve
Posted: Fri Apr 06, 2012 3:29 pm    Post subject:
This thread is continued on the frankenyolk thread for topic consistency.
Here are the beginning posts where this one ends:
http://www.curtpalme.com/forum/viewtopic.php?p=340415#340415
htguy1
Posted: Tue Oct 23, 2012 4:34 am    Post subject:
So where are we on all this? have people gotten these to work pretty well or is this still a mod in need of reworking?
GOd bless...
Mark
Posted: Fri Jul 01, 2016 3:00 am    Post subject:
Tag, to bring this topic back up to where I can find it easily!
To update this topic, I have decided that the best way to deal with "other" focus yokes in a Marquee is to attempt to
make them more electrically compatible with the Marquee's systems by modifying the electronics to drive them more as they were intended to be driven in their donor projectors.
In some cases this isn't going to be possible. The G90, for example, runs the focus yokes at about double the available voltage on the Marquee focus module. Boosting the supply voltage to the Marquee FGM from 24 to 50 volts would be a huge project.
The Marquee FGM's highest input voltages are +/- 24 volts while the G90 runs its focus boards at +/- 50 volts.
Interestingly, the Barco 909's focus board is fed by only 19 volts. I see not more than 12 volts in the focus generator circuit supplies.
The basic idea for adapting the drive electronics to work with the magnetics is simply this: The Marquee focus system works on a resonant LCR circuit, with the dynamic focus coil being the L in that circuit. Capacitors on the focus board are switched in combinations to provide resonance in the appropriate scan rate frequency range.
In order to use a focus yoke with a different inductance and have it work efficiently, it will be necessary to alter the values
of the switched resonance capacitors on the FGM. But only if the values of the focus yoke coil inductance varies by a significant amount. I'd say that you need a 10 percent difference in coil value in order to have a real need to alter capacitor values to
bring the system back into resonance.
I was glad to find this thread, for many reasons, one of which is that I don't have to open up the magnetic stack in a G90 focus coil to determine what's what. There is always a slight risk of breaking either a ferrite or alnico ring when you attempt to open one up, and I think that doing so can negatively affect the magnetic alignment as well, no matter how carefully you reassembly the parts and line up your witness lines that you (hopefully) applied with a permanent marker.
For connectors, I got the right ones from salvaged wiring harnesses out of a scrapped G90. Short of fabricating all new adapter cables, this is the best way I've come up with to cable up a G90 yoke to the Marquee chassis. Ask Curt or Craig, they might have some extras hanging around.
FYI, the connector type used on the G90 yokes is the JST SM series. I leave identifying the exact parts for you as an exercise for your creativity and resourcefulness. You will need both 5 and 8 contact versions.
The connectors used on all Marquee magnetics cables are Molex KK series. Available at Mouser Electronics.
As for the electronic CPC rings on a G90, those are only driven by DC voltages provided by the 12 channel DC supply on the G90 DF board. Rail voltages are only +/-6 volts.
Actually coming up with a system to drive the G90's electronic CPC rings would be the simplest of any possible project if
you wanted to add functional magnetics to a Marquee that were unique to a different projector. Not saying it would be an afternoon's work, but it's functionally only a dozen variable DC sources at low voltage. It could be done with a DC power supply and a handful of trim pots.
The G90 focus yokes also internally carry their own 4 and 6 pole electronic astigmators. But those require active drive signals.
We can use EITHER ONE with the Marquee, but we can't use both at once as we don't have enough astig outputs.
However, for test purposes, we COULD "borrow" the astig circuit from red or blue and use it to drive the 6 pole circuit, while using the astig from green to drive the 4 pole circuit, which would leave one CRT without astig control of any kind.
So think about that: Green has 4 pole astig, and uses blue's astig circuit to drive the 6 pole astig winding. Red uses its own 4 pole astig circuit, blue, which has the LEAST effect on picture sharpness, runs without electronic astig.
I'll be trying that.
Page 2 of 3
