Fan noise reduction
Goto page 1, 2, 3  Next
Posted: Sat Mar 17, 2012 10:31 pm    Post subject: Fan noise reduction
If you run two fans back to back at half the speed do you get the same air flow as one fan at full speed. I have been experimenting and it seems to work but I don't have any way to measure air flow. This does reduce fan noise significantly.
Posted: Sat Mar 17, 2012 11:16 pm    Post subject:
No, you dont. You get the same flow youd get with one fan at half speed. If you want to reduce the noise and increase the air flow, you need to use larger fans.
Im assuming by back to back you really mean front to back, as in one fan pushing air into the next, and not both fans pushing toward each other.
Posted: Sat Mar 17, 2012 11:30 pm    Post subject:
Yes front to back so both are moving air in the same direction. I don't see why two fans at half speed don't move the same as one at full speed after all if you have two fans at full speed you would move twice as much air so why would this not be true for two at half speed?
Posted: Sun Mar 18, 2012 12:04 am    Post subject:
Well they wont, they are moving the same air arent they. If they were side by side they would move more air, but the blades are still pushing the same air through the same space at the same speed. Same air flow as a single half speed fan or very close to it. More resistance and more energy used at the same time.
Its very logical really. If you put one water pump straight into another water pump and turn them on half way do you get double the water flow? No. Youd be lucky to get half the water flow.
Posted: Sun Mar 18, 2012 12:24 am    Post subject:
Sure the same space is being used but you are assuming that that space is at it max with one fan. I have seen many server cooling systems built this way. If you don't get any improvement then why do that. Perhaps someone has equipment to measure air flow.
Posted: Sun Mar 18, 2012 2:59 am    Post subject:
That is to ensure continued air flow in the event of failure, not to increase it.
You dont need an air flow meter to use your common logic. Same space, same speed, same number of parallel blades in the same config, same air flow. The 2nd fan is doing NOTHING MORE than moving the EXACT SAME AIR the first fan has allready moved. I dont understand how you could expect it to do anything MORE than that.
In order to move MORE air, you need MORE diameter, MORE rotational speed, MORE fan blades or blades at a greater angle, or MORE fans in parallel. Fans in series is just a waste of fans. ( in terms of their physical configuration, not their electrical connection )
But ill tell ya what, lets not take my word for it without testing it, why dont you join up 5 of them, then see if you get more air flow than 1, if your theory is correct youll get 5 times the air flow, which will be easy to see. Good luck with that Wink
Test it on the bench and let us know what you find.
Posted: Sun Mar 18, 2012 3:36 am    Post subject:
Testing is why I put the question. Not to get an argument. How's this for logic. 1 fan at half speed moves x volume of air if you have two side by side you have 2 x or the same volume as one fan at twice the speed. What you're saying is if you place one behind the other then the air output of one fan disappears. I find that illogical.
Posted: Sun Mar 18, 2012 3:58 am    Post subject:
Dont know what you expected when you ask a question, and then get an answer only to argue the point i make. Why ask a question at all if youre allready set to believe what you want to believe? Ive explained it in my terms, and you dont seem to want to hear it, you seem to be after confirmation on your own theory.
You can find it illogical as you like, until you or someone else can prove without a shaddow of a doubt that youll double the air flow with such an unorthodox method, then ill stick behind my theory.
You have one fan pushing air into the 2nd fan, x amount of air goes in, x amount comes out. The 2nd fan does not create new air, it simply moves what has ALREADY been moved by fan one.
So it can be said:The output from fan 2 is equal to the input from fan 1. That is so plain and simple i dont think i can put it any other way.
What i dont understand is why you think it could possibly work any other way?? What goes into fan 2 HAS TO have allready passed through fan 1 doesnt it.
Explain your theory to me.
Posted: Sun Mar 18, 2012 6:05 am    Post subject:
I guess you have not convinced me the theory is wrong. You fail to realise that the total blade area of the fan is now double the single fan. Please explain how double blade area produces no additional air flow?
So the second fan adds to air flow because it adds to the surface area of the blades.
You are looking at this as two separate fans I am saying they become one assembly and with double the blade area there is double the air flow through the whole assembly and that means twice as much air enters the assembly again because there is double the blade area.
Anyway as mentioned explain how double the blade area produces no addiional airflow? You said to produce more flow you need a larger fan well that has been created by the additional blade area.
Posted: Sun Mar 18, 2012 6:32 am    Post subject:
And you fail to relise that the blades are moving the EXACT SAME AIR.
Same blade area, because the blades are not on the same plane!!
Forget it, you continue with your theory!! Let someone else have a shot Laughing
HK-Steve
Posted: Sun Mar 18, 2012 6:59 am    Post subject:
The only thing you increase is the static pressure by adding another fan in front of the first fan,
More fan blade area to push the air harder through the chassis. Not more air, just the pressure of that air.
Cheers
Posted: Sun Mar 18, 2012 7:26 am    Post subject:
Thats about what ive been trying to say Steve yes...
Boilermaker
Posted: Sun Mar 18, 2012 11:46 am    Post subject:
You will not get the results that you desire. To find out exactly what you will get, I suggest you look at the fan curves for the fans that you have which will be available at their website. The curves will show the exact relationship between volume and pressure and you can then determine the results.
There are also pump curves available, but water behave differently from air as it cannot be compressed like air.
Try this: Turn on your home vacuum cleaner and put your hand over the nozzle so no air can flow. Did the fan speed up or slow down? Why? Did the current draw from the fan motor increase or decrease? Why? Answers - Look at the fan curves for any typical squirrel-cage fan and you will see.
Bob
Posted: Mon Mar 19, 2012 3:19 am    Post subject:
Bob
Yep, i know that Bob Wink It is a reasonably suitable example on why not to run in series though.
Bob
Fan speeds up due to reduction in air flow, current draw is reduced due to reduction of load and increase in back EMF.
kabuby77
Posted: Mon Mar 19, 2012 7:48 am    Post subject:
Right, You see this into cpu heatsink where the fins offer a high resistance so they use a fan in the front and another on the back.
Boilermaker
Posted: Mon Mar 19, 2012 1:58 pm    Post subject:
You da man! Actually da Corvette Man.
Posted: Tue Mar 20, 2012 6:36 am    Post subject:
Laughing Cheers mate!! Im actually an electrician, so i know abit about current flow Wink
Posted: Wed Mar 21, 2012 3:34 am    Post subject:
So what about this? Thumbs Up
"Series vs. Parallel Fan Configurations
To compensate for the impedance of the system, either one fan or a combination of fans--in series or parallel--are used. Figure 2 illustrates a series fan configuration and its relation to the impedance of a system. The effect of this configuration doubles the amount of system impedance the fans can overcome for a given flow rate. For high impedance systems, a series fan configuration would be optimal since this configuration is able to deliver higher airflow rates. "
Fan Configuration and Airflow Impedance Lab Manual Part 1 ME146.doc
 Filename:  Fan Configuration and Airflow Impedance Lab Manual Part 1 ME146.doc
 Filesize:  403 KB
 Downloaded:  14799 Time(s)
rosenbush
Posted: Wed Mar 21, 2012 6:09 am    Post subject:
The Fig 2 clearly shows two fan in serie will deliver the same airflow as one.
If you're getting new fans, anyway, for the serial experiment, get fans with same CFM and less decibels and replace the original ones.
Posted: Wed Mar 21, 2012 6:37 am    Post subject:
Yep, it does... Which is what ive been saying since the start of the thread... Laughing Laughing
Anyway KM, i think you should just drop this sh** and come over for a cold beer mate Very Happy
Page 1 of 3
