4K with two 9 inchers ?
ElTopo
Posted: Mon Feb 20, 2012 2:44 pm    Post subject: 4K with two 9 inchers ?
anyone tried that already ?
ElTopo
Barco Cine 9 the one and only
Posted: Mon Feb 20, 2012 3:02 pm    Post subject:
It is going to be kind of hard to get a good image, since the horizontal resolution is 3840.
Posted: Mon Feb 20, 2012 3:31 pm    Post subject:
According to Wiki digital cinema is 3996x2160. The Marquee is 2048x1536. so with a scaler you could get close blending two. You'll lose a bit in the horizontal. But i bet it still look awesome. If i had 4 K capable PC id give it a try on my 8500's.
it have to be a smaller blend zone of 100 compared to my 188 i use now for 1920. so 2048-50 or 1998 to each PJ.
barclay66
Posted: Mon Feb 20, 2012 3:46 pm    Post subject:
4K is the quadruple amount of pixels instead of the double (as the naming would suggest). So -in general- I would think that two 9-inchers wouldn't be sufficient. A blend of four 9-inchers (each of them doing around 999 x 540) would of course work. Even four good 8 inch EM focused LC sets could work well. The processor for splitting the 4K signal into four quadrants could be the cost driving factor here...
Regards,
barclay66
Posted: Mon Feb 20, 2012 4:09 pm    Post subject:
4k DCI is 4096 x 2160, guys.
The vertical res (2160)... Yes, you'd be using 33% more tube face than normal 16:9, but the resolution is double 1080p. To put it in persecutive, full-raster 2160p would be the same line density as running 1620p compressed raster (as we do with 1080p).
Horizontal... Athanasios... I think you meant to add 50 pixels, not subtract... So, 2098 to each projector for a 100 pixel blend zone. Of course, that would only be a 3.5-inche blend zone on a 12' wide screen - which is tiny. Double that would still be small, but much better, but then you're running 2148 to each projector. The pixel clock at 2148x2160 is over 222Mhz - throw in some porches and things are going to be what, 250mhz? I think it's going to be getting pretty soft at that resolution - especially on anything but a 909 or modded Ultra with a really good video chain.
I'd still like to see it, though... Somebody get to work on it, will you? Wink
Posted: Mon Feb 20, 2012 4:25 pm    Post subject:
Your right. I was thinking QuadHD. Of course, no one knows what consumer 4k will be, if any. At this point, there is only one consumer 4k pj. I think most of those people who are in love with it are the owners who just dropped $20k on it. For CRT, it is kind of moot until there is 4k or QHD source.
Posted: Mon Feb 20, 2012 4:39 pm    Post subject:
Well the peaking circuit in the marquee's i have allow for up to 240mhz pixel clock so I can get close. the Tv-ones can handle it as well. But do we really need full resolving power? many here like not being able to see scan lines so if get a little soft to some it wont matter. I being one of them.
And adding two more blend units is no problem for me I have more Marquees too. so a quad blend could possibly seen in the future . Wink
jbmeyer13
Posted: Mon Feb 20, 2012 5:59 pm    Post subject:
You need to get those 9" LC tubes in your blend first Smile
So what would you do, put 2 on the floor for the bottom 2 quadrants and leave 2 on the ceiling?
Or go rear projection and you wouldn't need any keystone. Can't imagine what a 13' rear projection screen would cost Shocked
kabuby77
Posted: Mon Feb 20, 2012 7:43 pm    Post subject:
You must use a blend with 2 Barco cine 9.
Posted: Tue Feb 21, 2012 2:23 am    Post subject:
Man I wish I had more time to come hang out. Would be fun to go through your stash and experiment Smile
Posted: Tue Feb 21, 2012 7:04 am    Post subject:
Why not with Barco 912s?
ElTopo
Posted: Tue Feb 21, 2012 9:00 am    Post subject:
The TV one C2-2350A should support up to 2048x2048 on the analog output.
ElTopo
kabuby77
Posted: Tue Feb 21, 2012 11:30 am    Post subject:
yes, into our dreams perhaps Mr. Green .
Enjoy this blend with 2 909: http://www.avmagazine.it/forum/13-videoproiettori-crt-e-new-tech/195144-problema-tubo-barco-909-spento?p=3089503#post3089503
ElTopo
Posted: Tue Feb 21, 2012 11:55 am    Post subject:
I only see the 2 projectors but no blend.
ElTopo
Posted: Tue Feb 21, 2012 1:06 pm    Post subject:
VDC brochure says:
Features include:
Greater than 2048 x 1536 pixel resolution !
ElTopo
Posted: Tue Feb 21, 2012 1:07 pm    Post subject:
Well with 2 x 909-ers it would be better for sure:
3250 x 2560 max resolution !
kabuby77
Posted: Tue Feb 21, 2012 7:20 pm    Post subject:
YESS, the guy is asking how to repair a neckboard Wink
Decibel
Posted: Wed Feb 22, 2012 8:40 am    Post subject:
Yes, the owner said that is a blending system.
16:10 at 3200p
You can see a particular position of deflection yokes Shocked
Domenico (Barco fan!)
kabuby77
Posted: Wed Feb 22, 2012 9:02 am    Post subject:
16:10 at 3200p
notice that 4k is only 2048p! Mr. Green
CRT is always ahead Cool
Posted: Thu Feb 23, 2012 12:51 am    Post subject:
There must be a lot of wasted phosphore with that orientation. How large can the image be?
