Don't forget to bleed your tubes.
nuttall_chris
Posted: Tue Dec 05, 2006 1:45 am    Post subject: Don't forget to bleed your tubes.
I took the opportunity while having my projector off the ceiling to do some upgrades to bleed the tubes on my Marquee 8500.
When I removed the screw, the coolant literally sprayed out. Shocked
It looks like I did this just in time.
Don't be lazy....bleed your tubes.
Chris.
Joust
TV/Projector: Marquee 8501LC
Posted: Tue Dec 05, 2006 1:51 am    Post subject:
I'll do mine too. maybe its a blessing that it is not tinted Wink
the guys would laugh at you at work with pink and green spritz all over you.
nuttall_chris
Posted: Tue Dec 05, 2006 1:53 am    Post subject:
Maybe I could convince them that it's the latest fashion 8)
Joust
Posted: Tue Dec 05, 2006 1:58 am    Post subject:
you probably could. Most at that place are still wearing shorts with white socks and sandals.
Even though we got 4" of freezing rain on Friday and this mornign it was as cold as a witches titty. Confused
In case you don't know, Chris and I work at the same co. in the same office complex but have still not even met each other. Embarassed
nuttall_chris
Posted: Tue Dec 05, 2006 2:46 am    Post subject:
Barry, once I have my beast put back together and on the ceiling you are more than welcome to come over and check out my setup. Mr. Green
Chris.
Posted: Tue Dec 05, 2006 3:13 am    Post subject:
We need another Ottawa HT meet! You missed the last one Chris! (It was at my place).
nuttall_chris
Posted: Tue Dec 05, 2006 12:33 pm    Post subject:
I'd love to see your projector in operation Kal, I have never seen an LC projector.
Chris.
Posted: Tue Dec 05, 2006 3:25 pm    Post subject:
Maybe the meet should be at my house again then. Smile
Though I'd like to have something more to show the other guys... nothing else new (other than new Paradigm Signature speakers which I haven't had the chance to really dial in 100% right).
Posted: Tue Dec 05, 2006 3:32 pm    Post subject:
I've never yet heard of the front glass on a 180DMB or DVB breaking. The seal
that keeps the coolant in place is extremely thick and water adsorption through it is virtually zero.
CJ
picree
Posted: Wed Dec 06, 2006 4:43 am    Post subject:
Why do they build pressure?
MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
jask
Posted: Wed Dec 06, 2006 4:50 am    Post subject:
The coolant in the chamber picks up moisture from the air over time and expands in volume
Joust
Posted: Wed Dec 06, 2006 5:02 am    Post subject:
CJ
Cool, I'd like to put that particualar worry out of my head but....
If thats the case, then why would Chris's tube spray like that?
I saw pics somewhere of the front glass broken. Not sure what type of tube it was.
nuttall_chris
Posted: Wed Dec 06, 2006 12:44 pm    Post subject:
Maybe the glass on my tubes would have been fine for a long time but it only took about 20 minutes to drain them while I had my projector pulled apart for some other mods. Well worth my time.
SYC
Posted: Wed Dec 06, 2006 2:55 pm    Post subject:
Do I have to remove the deflection coil, the focus coil, and astig magnets like the movie shows?
SYC
nuttall_chris
Posted: Wed Dec 06, 2006 3:41 pm    Post subject:
SYC
No you don't have to remove the magnetics.
Chris.
SYC
Posted: Wed Dec 06, 2006 9:25 pm    Post subject:
[/quote]
Chris.[/quote]
Only the magnetics don't have to be remove? Or all of them?
SYC
Posted: Wed Dec 06, 2006 10:06 pm    Post subject:
He's lying, everyone knows everyone else in Canada.
Smile
jask
Posted: Thu Dec 07, 2006 2:33 am    Post subject:
Smile
yup its true Very Happy
and... on Thursday nights (Wednesday in Newfoundland) we all get together, play hockey,drink beer and build Inukshuk http://www.thecanadianencyclopedia.com/index.cfm?PgNm=ArchivedFeatures&Params=A29
out of empty cases of beer...
nuttall_chris
Posted: Thu Dec 07, 2006 2:46 am    Post subject:
[quote="SYC
SYC[/quote]
As long as you can access the screw on the side of the tube to drain the glycol, everying else can stay on the tube. All the magnets and coils can remain on the tube the only thing you will have to remove is the neck card.
But be careful not to get glycol on any of the magnets or coils as I believe it can cause damage.
Chris
Fujifrontier
Posted: Sat Oct 20, 2007 3:09 am    Post subject:
Am I correct in assuming that if you don't move any of the magnetics, the only thing you'll have to do is the grayscale adjustment and the digital convergence, after you put the tube back in?
