Don't forget to bleed your tubes.
nuttall_chris
Posted: Sat Oct 20, 2007 3:20 am    Post subject:
I don't see why you would need to do a grayscale adjustment after bleeding the glycol but yes you would need to redo convergence.
Chris.
Posted: Sat Oct 20, 2007 3:59 am    Post subject:
Well I just drained the tubes on my 8000 to put in colored glycol that I had from a Barco 801s. When I put the tubes back in the projector I had to redo mechanical convergance (swinging red and blue tubes) and that was about it, the digital convergance and other setting fell right back into place.
However if you did it the right way and left the tube mounts attached to the upper and lower mounting plates and then simply removed the tubes (from the mountings) I believe you could put it back together and not have to really fix any settings
Erik
jask
Posted: Sat Oct 20, 2007 11:52 pm    Post subject:
Fujifrontier wrote:
Am I correct in assuming that if you don't move any of the magnetics, the only thing you'll have to do is the grayscale adjustment and the digital convergence, after you put the tube back in?
same tubes,back into the same machine?... probably not,
but if you are doing all that work are you sure your magnetic focus is 100%?
