Porch setting on Vision HDQ
Posted: Fri Feb 10, 2012 6:54 pm    Post subject:
Here you go Justin. from our phone conversation.
dvh99
Posted: Fri Feb 10, 2012 10:29 pm    Post subject:
i see now what the problem is.
the front porch as indicated on the lumagen is actually the backporch.
still 482 is much too high and wasted bandwidth.
Posted: Fri Feb 10, 2012 11:09 pm    Post subject:
Dennis lower the Total vertical geometry to 860 and Active to 817.
jbmeyer13
Posted: Sat Feb 11, 2012 1:40 am    Post subject:
Nash-
Is this what it should look like for 2.35/2.40?
The settings are as follows;
VTOT 860
VACT 817
VSYNC 11
VFRN 5
HTOT 2538
VACT 1920
VSYNC 105
VFRN 210
Back porch should be 303
dvh99
Posted: Sat Feb 11, 2012 2:28 am    Post subject:
all series are in 16:9.
besides that, i don`t mind black bars.
and please lower your front porch settings, 56 is more then enough.
i have zero ringing and could lower the front and backporch a bit and still have no ringing.
Posted: Sat Feb 11, 2012 2:50 am    Post subject:
jbmeyer13 wrote:
Nash-
VTOT 860
VACT 817
VSYNC 11
VFRN 5
HTOT 2538
VACT 1920
VSYNC 105
VFRN 210
No, that is still 1.78. Look at my pic here then yours, notice yours still shows
above and below the 2.39:1 line, it shouldn't.
Not sure why the Lumie is still allowing the portion above and below the 2.39 to scan?
I forgot to see what my aspect was set to, what is your at? if its 1.78 change it to 2.35 if its 2.35 change it to 1.78.
that might be it.
Id have to be home to check the rest of the settings. There must be one your missing. I'm still at the diner, be another hour
or so.
jbmeyer13
Posted: Sat Feb 11, 2012 7:34 pm    Post subject:
Dialed in to the max...1920 x 817/72hz Mr. Green Mr. Green Mr. Green
Phoenixed
Posted: Sat Feb 11, 2012 7:50 pm    Post subject:
JB What were your settings for 1080p60 if you don't mind my asking?
Planar PD-8150/Runco LS-5
Posted: Sat Feb 11, 2012 8:16 pm    Post subject:
Looks Great Justin!!!
jbmeyer13
Posted: Sat Feb 11, 2012 9:26 pm    Post subject:
For 1080p/60 I only used the factory defaults. I might have been able to get rid of the ringing but I decided to drop to 1080p/48 so I wouldn't have to muck with the porch settings so much. I'll be revisiting that shortly and if I find a setting that works I'll post it.
The picture above is 1920 x 817/72 hz.
Phoenixed
Posted: Sat Feb 11, 2012 11:35 pm    Post subject:
I don't have the ringing you do err did, however I can't fully resolve 1080p60 lossing like 2.5% of the image. So I just need to messs with the porch settings. Thanks for your help.
jbmeyer13
Posted: Mon Feb 13, 2012 6:54 pm    Post subject:
I now have 1080p/48 (1.78/1.85), 800p/72 (2.35/2.40) for Blu-ray dialed in and 1080p/48 for HD cable (might try 1080i/96..). Any thoughts on timing for the following output resolutions for SD DVD;
1) 1440 x 960p/72hz for 1.78/1.85AR
2) 1440 x 720p/72hz for 2.35/2.40AR
I need a starting point for H/V TOT, H/V SYNC and H/V FRN; any thoughts?
AVphile
Posted: Thu Apr 05, 2012 5:58 am    Post subject:
What's all this talk about ringing? Is it being introduced by the display or the Lumagen? Is it not a simple matter of transferring one's display timings from Powerstrip (for example) to the Lumagen? I did just that with my Anthem/Sigma VXP and it results in a fine image with nothing I would call "ringing".
AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
AVphile
Posted: Thu Apr 05, 2012 6:04 am    Post subject:
1440x810 is 16:9
I run this because it is exactly 3/4 the res of standard 1920x1080 and I figure that would be an easy clean conversion for the proc.
 Filesize:  31.03 KB
 Viewed:  12031 Time(s)
jbmeyer13
Posted: Thu Apr 05, 2012 2:11 pm    Post subject:
The HDM ringing is an artifact in the PJ resulting from running higher resolutions like 1080p; the beam doesn’t have the time to settle. By adjusting the porch settings, it’s possible to increase the overall size of the raster while keeping the viewable image the same size. This effectively shifts the ringing out of the viewable image.
The ringing was not an issue with DVD’s scaled to a resolution like 1440 x 960p. I ended up letting the BD player output 1080i/1080p for DVD. When using a SD DVD player into the Lumagen the image looked way too soft; regardless of resolution.
AVphile
Posted: Tue Apr 24, 2012 4:07 pm    Post subject:
Thanks for the explanation.
Why does everyone run 1440x960? Do you then have to reduce vertical height to get the correct AR? If so do you do that in the PJ or VP?
Posted: Tue Apr 24, 2012 6:14 pm    Post subject:
2x480p
You andjust geometry in the projector. If you do it with the VP you won't be running 1140x960 anymore Wink
studio
Posted: Sat Apr 28, 2012 1:08 pm    Post subject:
Would like some help if you guy would?
Have ringing issues see screenshot https://www.curtpalme.com/forum_archived/viewtopic.php@t=30547.html
Using a PS3 to VP50 w/1.09FW to Fury 3 to Barco 1209s. Not really sure how high or best resolution to run?? Porch setting etc??
Phoenixed
Posted: Sat Apr 28, 2012 4:46 pm    Post subject:
What resolution gives your ringing? 1080p 960p 720p
Posted: Sat Apr 28, 2012 5:14 pm    Post subject:
DVDO processors always ring when they scale because they are pieces of sh*t.
Page 5 of 6
