Denon AVR 5805 - No power - I'm finished with repairs :D
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 12, 13, 14  Next
Jeremy112
Posted: Thu Jan 26, 2012 12:10 am    Post subject:
Mac, that did something, it now reads 6.00vdc on pins 3 and 4
Posted: Thu Jan 26, 2012 12:12 am    Post subject:
Ok, give me a sec..
Posted: Thu Jan 26, 2012 12:14 am    Post subject:
Put D402 back in and verify the DC is back down.
Did you test that diode?
Jeremy112
Posted: Thu Jan 26, 2012 12:26 am    Post subject:
I tested the diode and it was fine, it read 590 one way and open the other.
With D402 in place pins 3 and 4 read 2.40 vdc again
Posted: Thu Jan 26, 2012 12:32 am    Post subject:
Ok, we're getting closer so dont get frustrated.
How hard is it to remove RR446 and RR421? They should be in that same vicinity. If not to hard then remove them and test your DC again.
Jeremy112
Posted: Thu Jan 26, 2012 12:36 am    Post subject:
If its one of the black micro wafer things then I dont know which 2 those are,... I will keep looking
Jeremy112
Posted: Thu Jan 26, 2012 12:38 am    Post subject:
Hold on, I found RR446, its a regular resistor thank god, but I cannot locate RR421...
Posted: Thu Jan 26, 2012 12:39 am    Post subject:
They are both resistors. RR446 is a 1 watt so it should be to small. RR421 maybe smaller though.
Posted: Thu Jan 26, 2012 12:40 am    Post subject:
Just try that one first then. Remove it and test your DC
Jeremy112
Posted: Thu Jan 26, 2012 1:07 am    Post subject:
Ok, sorry it took so long, that board is not easy to get out and back in, it still reads 2.4vdc on pins 3 and 4
Posted: Thu Jan 26, 2012 1:10 am    Post subject:
well we're at a cross road again. We need to remove that RR421 to see which way to go.
Jeremy112
Posted: Thu Jan 26, 2012 1:14 am    Post subject:
Ill remove it if I can find it, lol that will be a task!
Posted: Thu Jan 26, 2012 1:18 am    Post subject:
It is directly connected to 1 leg of the RR446 that you have removed. It's also directly connected to RR424 and TR420
Jeremy112
Posted: Thu Jan 26, 2012 1:21 am    Post subject:
Found it! its located on the other side, its one of them wafer deals, ill be able to remove it
Posted: Thu Jan 26, 2012 1:24 am    Post subject:
Any bets that this thread will go longer than the 'joke of the day' one? Smile
Posted: Thu Jan 26, 2012 1:25 am    Post subject:
Actually we are nearing a conclusion. Our space is very small right now. Very Happy
Jeremy112
Posted: Thu Jan 26, 2012 1:33 am    Post subject:
Still reads 2.40 vdc on pins 3 and 4
Posted: Thu Jan 26, 2012 1:38 am    Post subject:
Ok, couple things for you to do. Near that CPU there should be an 8 pin header which is just a connector with pins to connect something to. Make sure none of the pins are bent or touching, if there are pins sticking up.
Then locate 2 electrolytic caps. C507 and C498. Remove them and test your DC. Should be near the CPU
Jeremy112
I find that hard to beleive at this stage Razz
You DAMN right its small, and tight too!! Very Happy
Jeremy112
Posted: Thu Jan 26, 2012 1:51 am    Post subject:
Okay, it reads 2.45vdc now with the 2 electrolytics removed
Page 6 of 14
