EyeOne Display 3 vs. PRO (w ChromaPure Standard)
Posted: Wed Dec 14, 2011 5:27 pm    Post subject:
The thread is here:
http://www.avsforum.com/avs-vb/showthread.php?t=1373556
Tom's findings are especially interesting to read since he backs them up with hard facts.
i1Pro's great if you don't plan on doing low light gamma measures or contrast ratio measurements (since the i1Pro gets kinda wonky at below ~30 IRE on most displays).
WTS
Posted: Thu Dec 15, 2011 12:57 am    Post subject:
The i1pro gets wonky below 30ire, that can't be right, there goes your blacks. Is that still the case for the newer versions of the i1pro? Going wonky below 20ire, okay I could live with a little inaccuracy below 20 but starting at 30 can't be good.
It was also mentioned I thnk by both of those guys that if you buy the D3 just replace it every 2 or 3 years. What! Just replace it every 2 or 3 years, geez I don't think so. I think the i1pro would be cheaper then in the long run and live with the slightly off numbers in the low end. Just how far off is it?
I suppose if I got a i1pro I could always take it over to Michael Chen's house and compare it to his new Jeti ( I think that's what it is called), I think he said he paid over 10k for it so it should be fairly accurate. I think once you get the low end calibrated to a ref unit then it should be good for a long time, at least according to Derek who said he has cal'd over 100 units and never had one that didn't meet spec.
Spanky, this years or was it last years new Epson can't be any more problematic than the new or old RS40/45. At least Epson has a great return/service policy, I wouldn't exactly say JVC does or I should say I don't get that feeling from reading alot of the complaints from JVC owners. The thing about Epson is if the model has lots of problems I would think they would just replace it with the newset model as I've heard them doing that for customers.
I aslo agree with you on just how accurate does it really need to be. Hell I've been using the HCFR probe and it seemed to have dialed in the greyscale on my 1200 pro fairly nice or at least it looked damn good to me. And I know it was off because I had Michael Chen do a check comparing it to his mega buck ref probe.
Walter
Posted: Thu Dec 15, 2011 2:14 am    Post subject:
I found it depends on what program you use with the i1 pro.
HCFR was pretty stable
Chromapure was a bit more stable
CalMan least stable of all even if setting the low light handler to an appropriate .
The latest version of CalMan states they added more stability to the i1 pro but I have not used it yet to say for sure.
But having said all that it doesnt matter if you profile the D3 to it.
WTS
Posted: Thu Dec 15, 2011 2:50 am    Post subject:
As I understand it you can only use one probe with the chromapure, unless of course you pay extra for 2 probe usage. Not sure why that is, I don't understand the logic behind that one other than makes Tom more money. What should it matter how many different probes you want to use on any given software.
Using a probe like the i1pro is it necessary to use a program like Chromapure over HCFR to get the most out of the probe?
Walter
Posted: Thu Dec 15, 2011 3:13 am    Post subject:
Chromapure has more tools and its more up to date with how it calculates the data from the probes.
Also Chromapure has support for the D3. HCFR has not been updated for a long long time.
But for some reason I always turn to CalMan to calibrate my blend.
WTS
Posted: Thu Dec 15, 2011 3:24 am    Post subject:
Yeah I haven't seen an update from HCFR for long time. But it was a nice program for the price and I used it alot.
So Calman isn't the most stable with the i1pro yet it is the one you use most often, hmmm. It must be just easier to use then compared to the others.
Walter
Posted: Thu Dec 15, 2011 3:39 am    Post subject:
I wouldn't say easier, but it just "feels" right if that makes sense. Also as I said before if you profile your tri to the i1 Pro the instability in the low end is a mute point.
Posted: Thu Dec 15, 2011 2:26 pm    Post subject:
IRE is all relative. 20 IRE on one machine may be twice as bright as 20 on another. It's a percentage. I simply use 30 to indicate that you can still do a full greyscale calibration with the i1Pro but if you want to do really low light gamma work or measure contrast ratio (which requires you to measure basically 0 IRE), you pretty much can't with the i1Pro.
Look closely at how much it costs to operate ChromaPure vs the other products for what you want to do. ChromaPure is usually less expensive. ChromaPure also does not charge yearly for ongoing maintenance & support.
Using your example of a lower end colorimeter and the i1Pro like you're considering. Here's your software cost:
ChromaPure Standard: $180
Extra licence for the second meter: $90
Total cost: $270
CalMAN DIY: $199
Spectroradiometer Add-on: $149
Total cost: $348
If you want to add auto-calibrate later on, for ChromaPure it's $139, for CalMAN it's $199.
Want to go pro/commercial in the future? With ChromaPure it's a $799 upgrade, with CalMAN it's $2295.
Like everything, look closely at the total cost and what you get with it when comparing packages. Make sure you're comparing apples with apples too. Looking at adding a pattern source or other hardware control in the future? See if it's included or is an extra cost. If purchasing hardware, check if the meter's locked modified in any way which may not allow you to use it with other software. Does that matter to you? This includes how meter calibration/adjustment/enhancement is done. Look at your current needs & future needs. And so on.
There's no right or wrong answer. Everyone has different needs.
Ron W
Posted: Thu Dec 15, 2011 4:11 pm    Post subject:
Total cost: $270
CalMAN DIY: $199
Total cost: $348
It is interesting to note that although I use Chromapure almost exclusively for any calibration, I also have the latest Calman 4. In reference to the Display 3 meter, unlike Chromapure, if you activate the Display 3 with the Calman software, there is a light in the meter that turns on and shines above and below it. Quite distracting and not particularly good if you are using it as a contact meter. Tom Huffman advised it was just a particular characteristic of the individual software.
Posted: Thu Dec 15, 2011 4:38 pm    Post subject:
I use both to double check and i never see the light on during calibration in Calman only at initial connection with the software
, that is once the connection is made.
And Guys I got lucky with CalMan and Chromapure. I ended up getting both in the Pro version at a much lower cost during
the early release of both. CalMan cost me 700 for the pro version.
Posted: Thu Dec 15, 2011 4:39 pm    Post subject:
On the flip side, Calman does offer the retail version of the D3. For those that care, $469 allows you to not only do your displays but your monitors as well.
WTS
Posted: Fri Dec 16, 2011 12:45 am    Post subject:
DOn't get me wrong, I don't have a problem with the pricing set out for the packages. I just don't understand why the extra charge to use it with 2 meters. But it is what it is.
Walter
Posted: Fri Dec 16, 2011 1:50 pm    Post subject:
It's more work and costs more money to support 10 meters than (say) 2 meters. The way the meters are read and the data analyzed need to be programmed, and the software developer may have to pay the manufacturer for the drivers as well.
Either everyone who uses the software pays for part of the cost of having to support those 10 meters, or you charge customers for what they actually use.
WTS
Posted: Fri Dec 16, 2011 1:53 pm    Post subject:
Yes I suppose you are right, doing the actual software tables for each probe would be time consuming for sure. I retract what I said before.
Walter
Posted: Fri Dec 16, 2011 2:00 pm    Post subject:
Supporting more probe types means more ongoing support as well, not to mention having to own each of the probes and know the ins and outs of each, test each, and so on. Time is money even if the meters and licensing was free (which they aren't).
Posted: Mon Dec 19, 2011 1:10 pm    Post subject:
Ok, before I get to the point of d/l the software and starting a calibration next week, is there a recommended hardware platform and operating system environment to be doing this in? In the basement where the projectors are there is a Windows 7 Professional computer, and I can carry in a Vista (God help me) laptop, but would it be better to have an XP platform to do this on?
I may just go out and buy a new, but seriously inexpensive PC to dedicate to the HT just for calibrations.
WTS
Posted: Mon Dec 19, 2011 2:17 pm    Post subject:
Kal,
What are the prices for the i1pro and the i1D3 without software?
Walter
Posted: Mon Dec 19, 2011 2:31 pm    Post subject:
Not really. Microsoft Windows XP, Vista, or Windows 7 will all work. Certainly don't use an older OS just for ChromaPure. There's no difference/benefit.
Posted: Mon Dec 19, 2011 3:04 pm    Post subject:
WTS wrote:
Kal,
We only sell bare meters to existing ChromaPure users. Any existing ChromaPure users can email us at ChromaPure@CurtPalme.com for pricing.
