Bodi79
| Posted: Sun Nov 13, 2011 12:43 pm Post subject: Marquee 8500LC .. trouble again.. no picture |
Hi to all !
Hope itīs okay that i started a new thread , cause for every other user i guess itīs more useful this way.
My Issue:
Something really stupid happened yesterday to me and i really need your help.
After a 10hr run , the bnc cable for RED fell of the Connector cause I tripped (stupid me).
It seem to shorted somehow and the Marquee 8500LC shutdown.
I waited a few minutes checked if the VIM was still seated correctly and started up the Marquee again.
Sadly i donīt get any menu on the screen , or anything from the signal lines.
Got no errorleds on.. and the tubes glow.
Maybe a resistor on the VIM Bad?
Any suggestion what i could check?
Thanx again
Ronald
P.S.: I found a older thread were a other user had to change the HVPS Fuse... i checked that fuse and itīs fine
friedwart
Joined: 07 Jul 2010 Posts: 54 Location: Earth, Europe, Germany @ N 51°43'10.73'' E 14°39'05.52''
| Posted: Sun Nov 13, 2011 4:43 pm Post subject: Re: Marquee 8500LC .. trouble again.. no picture |
| Bodi79 wrote: | Hi to all !
Thanx again
Ronald
P.S.: I found a older thread were a other user had to change the HVPS Fuse... i checked that fuse and itīs fine |
Any LEDs on the LVPS? Check the CLM and its connections and the boards on it.
cheers
Bodi79
| Posted: Sun Nov 13, 2011 4:51 pm Post subject: |
@friedwart
Nope.. no leds at all on the LVPS.
Connections are 100% okay.. i reseated almost everything 5 times.
I am clueless !
Cheers
Ronald
Bodi79
| Posted: Sun Nov 13, 2011 6:32 pm Post subject: |
Hey Nashou !
I thought so aswell, are the any known resistors which i could check?
Thanx in advance
Cheers
Ronald
| Posted: Sun Nov 13, 2011 7:02 pm Post subject: |
Guys
Shorting the input does nothing, maybe the vim front panel is bent and the board does not seat right?
Bodi79
| Posted: Sun Nov 13, 2011 7:06 pm Post subject: |
@nashou
You are right again.. one of the Green Fuses are blown.
Will check if i have something similar aroung.. 3Amps i guess at least itīs printed on.
@Tim in Phoenix
Checked the Front panel yesterday.. looks fine to me. (Chassis is in parts so i can see how it connects with a flashlight)
Thanx again for your Tips !
Ronald
Bodi79
| Posted: Sun Nov 13, 2011 7:57 pm Post subject: |
@nashou
You are my hero !
Replaced the Fuse and the VIM runs again !
Thanx again.. i really owe you !
Cheers
Ronald
Bodi79
| Posted: Sun Nov 13, 2011 10:13 pm Post subject: |
Well.. fun didnīt last long... again
It ran for about an hour, i changed the Input Frequency via Menu to a higher settings.. and I heard a pop and the picture was gone.
Checked all boards after that if i could see anything visually broken.. nope.
Now i tried to start it again.. i get a ticking noise in the Region of the VNB of the Red tube.
And no picture.
So i tried without the Red HV Line and the Marquee starts normally again.
But the ticking sounds return even than.
If i try again with the Red HV Line in it starts but only ticks and no picture at all.
The Tubes are all glowing aswell ... I checked.
I really think i will salvage this machine for parts cause everyday a new issue pops up.
Sad thing is i put so much effort in cleaning the machine and changing the glycol and so on.
Would have been better to let it run for a few days as some guys here suggested.
Really just wanted to align it one time correctly and watch a movie just to see what I can expect
from the Marquee in general cause i never had an CRT before that.
So itīs a real bummer for me..
Thanx again for your advice...
Ronald
Bodi79
| Posted: Sun Nov 13, 2011 11:17 pm Post subject: |
@nashou
Removed the Black cord as you told me. Ticking still
Even if i remove the Red HV Lead and the Black Cord itīs ticking.
I just noticed a strong smell in the Front of the Red Tube. Canīt see any arcing anyway....
Any suggestions?
Cheers
Ronald
Bodi79
| Posted: Mon Nov 14, 2011 11:00 am Post subject: |
@nashou
Pulled the HVPS didnīt smell anything there.. will take it apart today in check if i can see visible damage.
Cheers
Ronald
Bodi79
| Posted: Mon Nov 14, 2011 2:39 pm Post subject: |
@Nashou
Nope.. i really donīt know anybody in the home theater scene who has a crt .. all digitalos now
But I am in contact with an other user for Germany who will eventually help me out with test boards.
Are your really sure it can be the HVPS??
Cause if i pull the HV Line of Red, the Green / Blue Tube are working normally and show a stable menu.
Thanx again
Ronald
| Posted: Mon Nov 14, 2011 3:07 pm Post subject: |
IF so, it sounds like your red tube cracked. Fortunately it's the red tube, they are cheap. I've got some if you need one.
Bodi79
| Posted: Mon Nov 14, 2011 4:18 pm Post subject: |
Hey Curt !
Is there anyway i can check if the Red Tube has cracked?
Be so good and send me a pm with pricing for the tube + shipping to austria...
Thanx
Ronald
| Posted: Mon Nov 14, 2011 5:03 pm Post subject: |
| Bodi79 wrote: | Hey Curt !
Thanx
Ronald |
Take the covers off the top of the tube and look around, look into the lens also.
Bodi79
| Posted: Mon Nov 14, 2011 6:14 pm Post subject: |
@ Tim
Cover was off since yesterday cause i checked for arcing..
No cracks around the front of the tube.. or visible on the phosphor..
Checked the Neck of the Tube aswell... nada .. no cracks visible.
Cheers
Ronald
