A/C Line conditioners, surge protecters. Worth investing in?
stereodave70
Posted: Sun Nov 06, 2011 7:53 pm    Post subject: A/C Line conditioners, surge protecters. Worth investing in?
Been looking at a few different power supplies/surge protectors, and I've noticed huge variations. Some cheep and some VERY expensive. Was looking at "Monster Power 3600 MKIII"...but found some bad reviews stating it has no line conditioning. I have cheap surge protectors on all my gear, but I'm sure they're just that...CHEAP. Is line conditioning a big help?...or is it all hype like spending thousands on interconnects????
I'm also planning on adding new amps to the rack, so I will most likely install a sub panel behind the rack for all the power needed. My point is, with separate circuits for more available power...means multiple power supplies. At least 2 to begin with. This gets expensive very fast.
Curious about your ideas on these???
Be carefull what you wish for...sometimes you just might get it !!!
Posted: Sun Nov 06, 2011 10:57 pm    Post subject:
Nashou OOOOHHHHH NASHOOOOOO! Where are you Wink
Posted: Sun Nov 06, 2011 11:29 pm    Post subject:
Those things suck!!
Get an Isolation Transformer, look on E-bay for one to feed your sub panel.
I have a thread in the home theater construction forum here. How to add an Isolation transformer ...... Ignore the arguing at the end.
My system works great and the power is clean.
Posted: Mon Nov 07, 2011 12:00 am    Post subject:
What you get really depends on how your power is, and if you get a lot of lightning strikes every year.
There were a couple of really good and informative threads in the high end section of avs, that actually ended up changing my mind about power conditioning, etc.
If you have limited power outages or brownouts and surges, along with little or no lightning strikes, I'd say it's all a waste of money. Keep in mind that a pretty direct lightning hit will blow the crap out of any protection as the amount of joules coming down the line way exceeds whatever filtering/conditioning you have.
If you expect lightning, the best protection is to unplug the power, cable, satellite wiring and telephone line if applicable.
If you get power surges or some lightning strikes, get an electrician to put a brute force surge protector right at the breaker panel. That's whole house protection.
I'd UPS any computer in the house, that's saved me some crashes. Around my place, we get 3-4 outages every year. I have no protection save for two UPSs, and nothing has blown in 10 years, and a lot of equipment here is on 24/7.
Monster Cable is the last place I'd start to look though. See if you can find the thread on the high end avs, it was really good and had a lot of good and differing opinions.
Sparky015
Posted: Mon Nov 07, 2011 12:06 am    Post subject:
Nash's solution is great. I use a Panamax. I use it to act like a switch to turn off all of my gear, including my pj when not in use. I didnt want to hear the whir of fans, nor did I want to keep power to my expensive tubes I invested so much in. Long story short, I had more than power conditioning needs when I chose the Panamax.
I am not a fan of Monster gear. Inferior product that you basically are paying for a name. Thats my opinion.
~Paul
stereodave70
Posted: Mon Nov 07, 2011 3:21 am    Post subject:
Those things suck!!
I did find your thread on this and it sounds exactly like what I want/need....more of want, to do !!
Ebay doesn't have alot on this right now....way overkill...or not enough ....unless you see something I'm missing.
Where else should I look for something like this?
Posted: Mon Nov 07, 2011 4:10 am    Post subject:
Yeah you have to keep looking, id go no lower than a 3kv , that will handle close to 30 Amps. Mine is a 5kva and goes up to about 45 amps. some are shielded between windings whih are better, but almost any Iso will ahve cleaner power.
Mine has 220 in and 120 out.
be patient , one will come up. Also if you just want a plug and play type with no sub panel the triplite rack mount units will be great
as well.
Athanansios
stereodave70
Posted: Sat Nov 12, 2011 12:05 am    Post subject:
Hey Nash!
Would this work for a plug and play solution?...save me the expense of another panel and breakers.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150681217273#vi-content
I could easily run a 220v 50amp circuit to behind the rack. UHH! 215lbs...I guess I'll need a new rack.
Still waiting on a shipping quote....could be a deal breaker.
Posted: Sat Nov 12, 2011 12:10 am    Post subject:
I was going to suggest that and tell you to get the tripwire power bar for more outlets.
stereodave70
Posted: Sat Nov 12, 2011 12:58 am    Post subject:
Got a link for that powerbar? All my search brings up is nutrition bars and supplements.
BTW, it might be Monday 'till get a shipping quote.
Posted: Sat Nov 12, 2011 1:21 am    Post subject:
Trippwire power bar perhaps?
http://www.tripplite.com/en/products/surge-suppressors.cfm
Posted: Sat Nov 12, 2011 1:51 am    Post subject:
Something like this.
http://www.tripplite.com/en/products/model.cfm?txtSeriesID=754&txtModelID=2652
stereodave70
Posted: Mon Nov 21, 2011 11:22 pm    Post subject:
OK, I thought I was all set. I bought an SURT003, just like in the add, but from another seller. Today I got an E-mail to confirm because it is an "international item and may not work in United States". This is good customer service, avoid a problem before it begins, as they offered full refund.
I know there is a difference in our (USA) a/c and overseas a/c. My question is how is overseas 200+v attained? Is it the same way we attain 220volts... 2 legs of 110 and a ground?...If so... then this unit will still work for me, right? OR, is there something else completely different that I can't use this?
Posted: Mon Nov 21, 2011 11:57 pm    Post subject:
This isn't plug and play but its an awesome unit.
Watch it, if it doesn't sell he might re-list it lower.
But even at 500 bucks its a deal those go into the thousands for 5kv.
Plus you'll have fun hooking it up! Very Happy
Posted: Tue Nov 22, 2011 1:13 am    Post subject:
Very Happy
Which nipple does the black wire go on? Laughing
stereodave70
Posted: Tue Nov 22, 2011 1:17 am    Post subject:
Well...The one I bought was for $178.00 + $207.00 shipping, great deal agreed, But, can you or anyone from overseas verify that it will work here (US) with 2 legs of 110 volts
stereodave70
Posted: Tue Nov 22, 2011 1:19 am    Post subject:
Very Happy
Black ALWAYS goes on left ....unless coupled directly to nipple rings! Mr. Green
trebortaergeht
Posted: Tue Nov 22, 2011 1:59 am    Post subject:
Most of Europe is straight 240v or whatever the local voltage is meaning one leg is the neutral at zero volts and the other is full line voltage. In the states it is 110-120v differential meaning one leg is positive while the other is negative(cycling back and forth) giving a total of 220-240 between them and 110-120 from each leg to ground. As long as the transformer doesn't have one leg of the primary grounded it should work fine. Most of the 240v appliances I've worked on don't use the neutral at all.
Boilermaker
Posted: Tue Nov 29, 2011 7:06 pm    Post subject:
Sorry to be so late with this post, but if you use this transformer you will get about 138 volts on the output, so beware!
Notice that the listed primary side voltage in the specs is 208, which is the phase to phase voltage used in three phase systems mostly in healthcare.
You can still use it and it will work perfectly but you will need to use a little "buck-boost" transformer in series with the primary to get 240 volts. If you go this way, let me know and I will spec a buck-boost that will probably be about $30-40.
It will work just as well - I have used one for 20 years on my system and I saved some money as I paid only $5 for my 5KVA iso at a local auction. BTW, to show how reliable they are, this transformer has been energized for over 50 years!
Bob
Boilermaker
Posted: Thu Dec 01, 2011 1:40 pm    Post subject:
Doesn't Europe use 50 Hz instead of 60 Hz? If so, it should still work but you might have to downgrade its power capability.
Bob
