Focus problems on green tube again
AVphile
Posted: Fri Nov 25, 2011 3:59 pm    Post subject:
Look into the lens with sunglasses. THat sounds like a Scheimpflug issue, not an electronic one. It's optical focusing. If the tube image is clear on the tube face in that corner, it's not electronics.
OK, when I look into the lens that same corner is more out of focus than the others.
AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
Posted: Fri Nov 25, 2011 4:38 pm    Post subject:
OK, so it is an electronics issue. YOu're not too close to the tube phosphor edge? If not, then I'd check focus and astig settings at 100% contrast. The edge controls of each have far less effect than on say a Marquee, but they should do something. You might have a bad focus or astig board. I've got lots here if you need one.
Posted: Sat Nov 26, 2011 3:37 am    Post subject:
CasetheCorvetteman wrote:
In my case it was certainly not a focus issue.
Cut out the beer before hand. Laughing
Hahaha!! I generally stick with scotch to get best focus Wink
