| Posted: Wed Nov 09, 2011 10:16 pm Post subject: |
| Spanky Ham wrote: | | He would still need a red element. Of course, the stock G90 green element isn't spot on either. | no, the marquee green is the correct one, it's the G90 which comes with the crappy green C. Red's are hard to find but not impossible and it's not like the set would be unwatchable without it while you waited
| Posted: Wed Nov 09, 2011 11:13 pm Post subject: |
That is what I meant. Your probably going to need elements either way. Red for 9500 or Green for G90.
HaydnG90
| Posted: Wed Nov 09, 2011 11:33 pm Post subject: |
IMO the non-optimal green on a G90 is less noticeable than the corrected red on say a Barco, which is my only personal reference point. The orange-reds on the BG808S were really bad.
haireez
| Posted: Thu Nov 10, 2011 11:43 am Post subject: |
I had experience with both projectors. My advise is to go with 9500LC. After having 9500LC, I realized the big different between 8" VS 9". Resolution between 2500 X 2000 vs 1700 X 1200 does count on big screen.
_________________ 2 White Vision 1
derik736
| Posted: Thu Nov 10, 2011 1:32 pm Post subject: |
well, the problem is, where i live (Poland in Europe) i have absolutely NO SERVIVE OR TECHNICIAN at all. The closest one is in Germany so i tend to buy as much plug and play PJ as possible. Any kind of tube swap or tuning whatsoever is pretty complicated and expensive...so should i or should i not???
friedwart
Joined: 07 Jul 2010 Posts: 54 Location: Earth, Europe, Germany @ N 51°43'10.73'' E 14°39'05.52''
| Posted: Thu Nov 10, 2011 1:44 pm Post subject: |
| derik736 wrote: | | well, the problem is, where i live (Poland in Europe) i have absolutely NO SERVIVE OR TECHNICIAN at all. The closest one is in Germany so i tend to buy as much plug and play PJ as possible. Any kind of tube swap or tuning whatsoever is pretty complicated and expensive...so should i or should i not??? |
I think you should. If you want to see a Marquee (8500) in action before you buy one, I live maximally close to you on the border to Poland.
cheers
derik736
| Posted: Thu Nov 10, 2011 3:50 pm Post subject: |
friedwart thanks for you offer, where exactly do you live???i go to Germany next week, although i have to decide until the end of this week if iīll take it or not.
Anyone knows wher can i find refurbished tubes for g70 or get my tubes refurbished?? Just in case...
friedwart
| Posted: Thu Nov 10, 2011 3:56 pm Post subject: |
| derik736 wrote: | | friedwart thanks for you offer, where exactly do you live???i go to Germany next week, although i have to decide until the end of this week if iīll take it or not. |
As my footprint says: Earth, Europe, Germany @ N 51°43'10.73'' E 14°39'05.52''
This is in Forst nearby Zary.
cheers
derik736
| Posted: Thu Nov 10, 2011 4:02 pm Post subject: |
du hast PM
| Posted: Thu Nov 10, 2011 4:47 pm Post subject: |
| derik736 wrote: | | Anyone knows wher can i find refurbished tubes for g70 or get my tubes refurbished?? Just in case... | VDC in Florida has new G70 tubes for $650. each .
http://vdcds.com/products/accessories/crts.html
derik736
| Posted: Thu Nov 10, 2011 5:03 pm Post subject: |
Thanks draganm, thatīs what iīve been looking for
friedwart
| Posted: Thu Nov 10, 2011 7:25 pm Post subject: |
| derik736 wrote: | du hast PM  |
I already read it but was busy.
cheers
| Posted: Fri Nov 11, 2011 3:42 am Post subject: |
I thought the price was more than that. Where do you see the pricing?
derik736
| Posted: Fri Nov 18, 2011 3:44 pm Post subject: |
i thought i have some defective blue tube since itīs blury on the right side of the screen and canīt be focused properly. I disconnected my htcp and tried to set the convergance and geometry. Imagine my shock as i figured out that without any source connected to my g70 i can set everything without problem, which is not the case if i connect my htpc or bluray. So i guess some board must be defect. I also canīt set the geometry which means the pincunsion and keystone (the uppest and the lowest lines are not streight). What do you think might be the problem???
| Posted: Fri Nov 18, 2011 4:30 pm Post subject: |
| Spanky Ham wrote: |
I thought the price was more than that. Where do you see the pricing? | that was the last time I called and spoke to them, prolly 3 years ago. $650. was for a bare glass tube. If you wanted it mounted in the LC chamber with the HV lead attached and such it was $850.
Current prices might be higher, I don't know.
