What is the Marquee C element made of?
mr_ro_co
Posted: Tue Oct 04, 2011 7:16 pm    Post subject: What is the Marquee C element made of?
Acrylic or Polycarbonate?
Those of us who are using the new glycerin based coolant need a definitive answer. It's important!
Steve
zGman
Posted: Tue Oct 04, 2011 7:47 pm    Post subject:
My information was that it is acrylic - that is the material used in the rest of the lens.
(Disclaimer- -but if your life depends on it then better find out for yourself...!)
G
Posted: Tue Oct 04, 2011 9:07 pm    Post subject: Re: What is the Marquee C element made of?
Steve
umm, this sounds ominous. What's the wrong answer? Confused
mr_ro_co
Posted: Tue Oct 04, 2011 9:20 pm    Post subject: Re: What is the Marquee C element made of?
Steve
Acrylic is the wrong answer. It is NOT compatible with glycerin, which is what the Orison coolant is based on.
Steve
dvh99
Posted: Tue Oct 04, 2011 10:15 pm    Post subject:
is this a guessing contest?
how about fluorite.
some light reading Smile.
http://en.wikipedia.org/wiki/Abbe_number
dvh99
Posted: Tue Oct 04, 2011 10:23 pm    Post subject:
for what it is worth, i mailed 3m and asked them.
expect 2 days for an answer, so they told me.
mr_ro_co
Posted: Tue Oct 04, 2011 11:16 pm    Post subject:
Thanks! Someone should know. I think I kept the clam shell packaging for one of mine and it might say on the label.
Steve
zGman
Posted: Wed Oct 05, 2011 12:46 am    Post subject:
Index of refraction of polycarbonate seems too high at 1.586...
I am betting on acrylic
G
mr_ro_co
Posted: Wed Oct 05, 2011 2:58 am    Post subject:
G
I'm pretty sure it's acrylic, but need to verify. Unfortunately, it's not compatible with the new glycerin based coolant.
Curt? Tim? Mike? Athanasios? Surely you guys know what the C-element is made of.
Steve
nidi
Posted: Wed Oct 05, 2011 12:06 pm    Post subject: Re: What is the Marquee C element made of?
mr_ro_co wrote:
Steve
Steve
do you have a spare one that you don't have to use, like a clear one?
put a flame at the edge , burn a bit and smell the gases.
what does it smell like?
here's a link:
http://www.boedeker.com/burntest.htm
Michael
HaydnG90
Posted: Wed Oct 05, 2011 1:32 pm    Post subject:
VDC must know the answer. My money's on acrylic for the reason Galen gave. Plus optical grade PC is a more expensive and is often used as a substitute for acrylic in high impact applications, which is clearly not the case here.
nidi
Posted: Wed Oct 05, 2011 2:25 pm    Post subject:
well, they cost alot, so money would be no issue there.
plastic parts in this size do not cost more than $20 to produce.
try the burn test and smell it, then we know what it is.
Michael
or find out what plastic polymers 3M produces then we know it
transparent plastics:
PC Polycarbonate Lexan (GE) , Makrolon (Bayer)
PMMA Polymethylacrylate Plexiglas (Evonik)
PA12 Polyamide (Grilamid TR-55) (EMS)
Polyester
PSU Polysulfon (Udel)
PPA Polyphtalamide
COC Cyclo Polyolefine Co-Polymer Topas (Celanese Ticona)
HaydnG90
Posted: Wed Oct 05, 2011 3:51 pm    Post subject:
Regular plastic maybe but optical quality material I would say is more expensive. Eyeglass lenses in PC are almost 2x the price of regular plastic, which I assume is acrylic or something similar.
nidi
Posted: Wed Oct 05, 2011 4:10 pm    Post subject:
yes, but how much did 3M charge for a C-Element $60 , $80 ??
and the weight of the element is 163 grams with the black ring.
so, It doesn't really matter how much the plastic costs, when you charge $50 and more for the element
Michael
nidi
Posted: Wed Oct 05, 2011 4:14 pm    Post subject:
my company , who manufactured the moulds for the injection moulding of DVD,DVD-R, BluRay
got the optical grade PC for less than $4 a kilo , and in the best days we used more than 200 kilos a day
just for testing of the moulds.
Michael
Posted: Wed Oct 05, 2011 4:51 pm    Post subject: Re: What is the Marquee C element made of?
Steve
Considering MP has had this in his machine for 2 years I'm not worried about it. This happened at the fill line of a leaky original tube with CRT coolant in it so the Orlson stuff can't possibly be worse than.
mr_ro_co
Posted: Thu Oct 06, 2011 2:30 pm    Post subject: Re: What is the Marquee C element made of?
draganm wrote:
Steve
I am worried about it because you can't get red C-elements anymore and they are rare. And I'd rather not have one crack one day and start leaking and make a big mess. Or have one start becoming cloudy. Just because Mike's had it in his machine for two years and nothing bad has happened yet doesn't mean much in the context of plastic degradation. I could bury an underground cooling tower line made from PVC and run propylene gylcol in it for two years and nothing would happen either. Many plastic degradation/embrittlment problems due to a chemical incompatibility with a working fluid take years to fully manifest themselves.
The guy at Orison who is responsible for establishing the compliance of their product with ASTM standards was also concerned. When he asked what all the materials that the fluid was coming in contact with were made and I got to the C-element, telling him I was pretty sure it was made from acrylic, he said "that's a problem." He said acrylic is not compatible with glycerin. So if the C-element is made from acrylic we probably shoudn't be using this stuff.
I do not know what the compatibility is between ethylene glycol and acrylic. Maybe Tim or Curt could chime in on what they've seen as far as longevity of C-elements in the field.
The stuff I've found on the web indicates there is no chemical incompatibility problem between acrylic and glycerin, so maybe the Orison guy is wrong.
http://www.keyinstruments.com/technical-support/chemical-compatibility-charts/acrylic
Best,
Steve
HaydnG90
Posted: Thu Oct 06, 2011 2:36 pm    Post subject:
Maybe I missed the thread but why are people people substituting glycerin for the usual material, glycol?
From what I can see in the literature both glycol and glycerin(glycerol) are compatible with clear acrylic plastic
http://microadvances.com/chemicals1.htm
I would be looking elsewhere for the source of this problem. Maybe there's an additive in this product that reacts with the aluminum or plastic. If the fluid was attacking the C-element there would certainly be evidence such as pitting or crazing. That crud is coming from somewhere. Wipe down the c-element and check for surface changes.
Posted: Thu Oct 06, 2011 4:17 pm    Post subject:
The usual mix is 70% glycol to 30% glycerin. I was thinking the c elements were made of polycarbonate but it's not clear enough and normally has a slight green tint.
http://www.boedeker.com/polyc_p.htm
Posted: Thu Oct 06, 2011 4:41 pm    Post subject:
I work with both Polycarb and Polyacrolate (acrylic) . PolyC. has a bluish/purple tint to it when you look at the material on-edge. IF you take the clear c-element and look at the side of the mounting flangle you'll see it.
PolyA. has a Gray or (if it's old) yellowish tint and is much more brittle than PolyC. It also has a tendency to exhibit crazing when exposed to alchohol or even water depending on how it was manufactured. The extruded stuff is the worst.
I highly doubt they used PolyA in the C-element, it would have been a disaster me thinks in the long run.
 Filesize:  223.98 KB
 Viewed:  8189 Time(s)
