G90- green '30' error code
Posted: Mon Sep 19, 2011 10:58 pm    Post subject:
From what I've seen, there's no direct way to get power to the Dallas chip, at least to the internal battery. Long ago I tried measuring the pins of an ECP Dallas chip, and the battery is 'in' the chip, somewhere deep, so that the battery voltage never comes out to the pins of the chip. Sad
Good idea though.
Although, pressing the RAM button on the YA board resets but also dumps the memory, so to get the set to fire up again, you need to nuke the memory.
Posted: Mon Sep 19, 2011 11:00 pm    Post subject:
Oh, and last question on this: I am ASSUMING that a blank Dallas chip with a good battery will fire up the G90, it just has no memory setting? (and hour/serial number, etc), or does the firmware in the G90 software need to be loaded onto the G90 before it will work?
Posted: Mon Sep 19, 2011 11:11 pm    Post subject:
The procedure that I outlined and you followed earlier writes the necessary data from a nonvolatile backup chip onto the Dallas chip. With a blank Dallas chip you will get error code 30 upon power up and you will need to rerun the procedure. A good new chip will however hold the data so that will be the last time and you won't get anymore green 30's.
The Dallas chip needs to be volatile because it stores dynamic data. The backup that you wrote to the Dallas with the procedure is just a generic set of values that all G90's can use. The Dallas chip does not hold any firmware information.
Posted: Tue Sep 20, 2011 12:03 am    Post subject:
OK, got it, thanks! Sorry, I know this has been posted at avs, but I never needed the info until now. Smile
So the guy a while back that was selling 'programmed' Dallas chips for $150 on ebay probably just put some generic data on the chip, so the buyer wouldn't get the 30 error at powerup, right?
Posted: Tue Sep 20, 2011 12:14 am    Post subject:
I thought he was offering to copy your original chip, IIRC.
Posted: Tue Sep 20, 2011 12:25 am    Post subject:
But now that I've reset it, there's no point...
Posted: Tue Sep 20, 2011 12:27 am    Post subject:
What?
Posted: Tue Sep 20, 2011 1:07 am    Post subject:
In order to get the set working so I could make sure it's OK before I ordered a new LUG for it, I had to initialize the RAM, as per Craig's instructions above. That worked. That also wiped out the RAM, serial number and hour counter, so it's completely blank now, no info is stored in it.
Posted: Tue Sep 20, 2011 4:16 am    Post subject:
Well no Curt. You got error 30 because your Dallas chip was either totally blank due to a dead battery or corrupt. There was nothing left to copy, you had no usable data on the Dallas chip. When you followed the procedure I outlined you wrote new data to the Dallas chip over the blank / corrupt data. There was no possible way for you to have retained your serial as it was already gone.
If you take a good Dallas chip out of a working G90, you can copy the data off it and transfer it onto a new blank Dallas chip. This retains all your calibration settings, serial number, and hour readings. This must be done in advance of the failure leading to code 30. Once you get error 30 there is nothing left and there is no way to retain your serial or hour counter without manually editing the Dallas chip with a binary editor on a PC.
Posted: Tue Sep 20, 2011 5:31 am    Post subject:
OK, got it now. I think I was sorta trying to say that, but said it incorrectly. Smile
Anyways, I got it now. Again, since this is a new installation, copying the data from another good Dallas chip isn't going to do anything in this case. I agree though for any G90 owner reading this. If you've got a good setup, esp, if it's ISF calibrated, copy the existing Dallas data onto your computer in case your Dallas chip dies. Then at least you have a backup.
barclay66
Posted: Tue Sep 20, 2011 10:31 am    Post subject:
just some additional information (I learned about it as I had to repair PC motherboards):
The Dallas chips and alike are memory technology from the stone age. Instead of using flash memory as nowadays (which is non-volatile per design) they use a low power static RAM plus real time clock circuitry (depending on model). On top of this they glue a lithium battery which supplies the RAM if there's no supply from the board it is plugged onto. If this battery fails the memory content becomes corrupt and can't be corrected. It is still possible to rewrite the RAM but it will lose its data when powering off.
On PC motherboards this typically would result in an error 'CMOS Checksum error'. You would then be able to restore at least default data coming from the BIOS ROM and continue working for that day. Next day the message would reappear until you replaced the Dallas chip.
Regards,
barclay66
Posted: Tue Sep 20, 2011 12:32 pm    Post subject:
Yes exactly.
On my own G90 I actually keep my Dallas chip in a ZIF socket that I installed on my YA board. I back it up periodically and I also back it up if I am going to perform an experiment on the G90 that requires tweaking the setup calibration.
For example the other day I wanted to try a P43 green tube but wasn't sure I wanted to keep it in the setup in case I didn't like it. So I pulled the original green LUG from my G90 and left the magnetics on the tube. I also copied the Dallas chip.
I took the new green P43 tube and mounted a different set of magnetics on it and installed the tube. I did a ground up setup and did decide that I hated the P43 and wanted to go back to the old green tube.
So,I just pulled the P43 back out, put my original green back in, and rewrote the old Dallas and wallah, all I needed was a quick convergence. Since I didn't move the magnetics on the original tube all the focus, registration, graysclare... were still perfect.
Posted: Tue Sep 20, 2011 1:53 pm    Post subject:
My response was to your question about the guy on Ebay selling for 150 bucks. Not to your situation.
Are you speed reading again..... Laughing
Posted: Tue Sep 20, 2011 2:06 pm    Post subject:
<smacks forehead>.. I thought 'he' you were referring to was Craig. Smile
I can't remember the ad, but I think the guy just loaded in some firmware so that you didn't get the 30 error when powering up with the new chip. Was he offering to copy existing data? I didn't see the ad when I looked for it yesterday on eBay..
Posted: Tue Sep 20, 2011 2:09 pm    Post subject:
I remember running into that ad a few times and I think he said he would copy your old chip if you sent it to him. But it's been awhile since I saw it. I think Tim started a thread on it some where here.
HaydnG90
Posted: Tue Sep 20, 2011 2:30 pm    Post subject:
He sold 2 chips through that Ebay ad. Its gone now though. IIRC he did offer to copy the data from the old chip to the new one. Personally I'd feel more confident having this service performed by someone like Craig. He could then keep a copy of the file on his PC in case it was ever needed in the future. This is what FrankD did for me a couple of years ago when I started to get paranoid about the longevity of my Dallas chip.
As Curt said, if you have a nice calibration especially if performed by one of the experts it makes sense to protect that investment and maintain a copy somewhere safe.
Posted: Tue Sep 20, 2011 4:10 pm    Post subject:
What he said Smile
Posted: Fri Sep 23, 2011 2:54 am    Post subject:
New Dallas chip came in, inserted it, got green 30 error like Craig said, reset it, 30 error went away and set now turns on.
Thanks for the info guys.
FYI, this Dallas chip lasted 11 years, it was made in 2000. Sooo nice to see a new Dallas chip with '11' as the first 2 numbers in the date code. Smile
For those that don't know, most chips have a date code on it, as in 0211.
That means the chip was made in the 11th week of 2002. FYI.
wallace123456
Posted: Fri Sep 23, 2011 3:28 am    Post subject:
Mine (projector) has a date of Sept. 2000. Thankfully, Craig will be out here soon and replacing mine.
I do wonder, what makes some chips last longer than other. From what I understand, the battery in the chip is not reliant on external power to keep it "charged". So, unless I am wrong, the chips (battery) should be going bad within a few years/months of each other depending on the year the chip was made. No?
wallace
Posted: Fri Sep 23, 2011 3:56 am    Post subject:
wallace
The Chip is supposed to have a 10 year life span so that is about right Curt's went at 11 Smile
I ALWAYS keep my G90's plugged in any way whether it helps or not. I figure it's a good luck charm! Thumbs Up
Page 2 of 3
