All about lenses (specs/datasheets/pictures/etc.)
Goto page Previous  1, 2, 3 ... 6, 7, 8 ... 10, 11, 12  Next
Posted: Wed Jan 21, 2009 7:22 pm    Post subject:
Thanks Kai,
Download as much as possible to you hard drive as a lot of CRT related links are disappearing lately !
kschmit2
Posted: Wed Jan 21, 2009 7:27 pm    Post subject:
Tom.W wrote:
Thanks Kai,
I have a huge archive, and I'm counting on Kal to back up everything on this site that I don't have Smile
kschmit2
Posted: Wed Jan 21, 2009 7:32 pm    Post subject:
Btw Tom,
feel free to add my rapidshare like to the opening post. It's in a premium account and should not expire.
Also found another pretty comprehensive list of USPL lenses which I attached here, and which may also be nice for the opening post.
(just for future reference:
the WayBackMachine still has working links to the USPL/3M Projection Optics White Paper:
http://web.archive.org/web/20050426195122/http://cms.3m.com/cms/US/en/0-78/ceiuzFA/viewimage.jhtml
http://web.archive.org/web/20041103002740/http://cms.3m.com/cms/US/en/0-78/ceiuzFA/viewimage.jhtml
http://web.archive.org/web/20040901154300/http://cms.3m.com/cms/US/en/0-78/ceiuzFA/viewimage.jhtml)
USPL Projection Lens Line.doc
 Filename:  USPL Projection Lens Line.doc
 Filesize:  148.5 KB
 Downloaded:  1058 Time(s)
kschmit2
Posted: Wed Jan 21, 2009 7:36 pm    Post subject:
and here's a working link you can use to replace the "3M lenses link ... ":
Code:
http://web.archive.org/web/*/http://cms.3m.com/cms/US/en/2-187/kkrcFFR/view.jhtml
(although I have also attached that table to the end of the DOC in my previous post)
Posted: Wed Jan 21, 2009 7:42 pm    Post subject:
Looks like PDF's are limited to 3 MB.
Posted: Wed Jan 21, 2009 7:48 pm    Post subject:
kschmit2 wrote:
Btw Tom,
Done Wink
kschmit2
Posted: Wed Jan 21, 2009 7:49 pm    Post subject:
Just add my link then. It's definitely better than nothing.
kschmit2
Posted: Wed Jan 21, 2009 8:48 pm    Post subject:
Looks like a guy in France is trying to build an anamorphic squeeze (Panamorph-like) lens for his CRT PJ:
http://www.cinetson.org/phpBB3/tritubes-f7/photos-site-archeologique-allemagne-ailleurs-t13842-105.html#p457727
Gerbrand
Posted: Wed Jan 21, 2009 9:04 pm    Post subject:
Thanks guys! Plenty of stuff to read Smile I was quite impressed when I saw the quality of the HD10-GT17 (HD120) on my "new" BG1209s and I was wondering how these lenses compare to current standards. Just from looking at them, I guess it would probably still cost several 1000$ each to have those made from scratch (and only in volume).
Gerbrand
Posted: Thu Jan 22, 2009 12:35 am    Post subject:
Now THAT's what I wanna get my hands on. Let's go to production with this!
bbfarmht
Posted: Thu Jan 22, 2009 12:44 am    Post subject:
I talked about trying to do that a few months ago.
I just got the "Men in white coats are here for you" look!!! Shocked
Adam
Benjamin Franklin
Posted: Thu Jan 22, 2009 1:24 am    Post subject:
I get those looks all the time. Very Happy
kschmit2
Posted: Thu Jan 22, 2009 7:54 am    Post subject:
well, as you can see the results for the anamorphic lens are very poor so far, and the lens is already too large.
Gerbrand
Posted: Thu Jan 22, 2009 8:46 pm    Post subject:
By the looks of it, he is trying to build an anamorphic lens using two compensating cylindrical lenses (the first type: http://www.panamorph.com/Technology.html). For a CRT projector it may actually be better to build an anamorphic lens using the two prism system (like here: http://www.panamorph.com/Technology.html). One of the main distadvantages of the latter (chromatic aberrations) should be much less, because each CRT is essentially monochromatic and you could correct the distortions per color using the projector's convergence controls.
Gerbrand
Posted: Thu Jan 22, 2009 8:59 pm    Post subject:
It be easier to blend for scope than use those lens's ,now try to move them for 16x9 content Shocked, and your still not useing allthe phosphor if he made them with use for a 16x9 raster, if he's using it on a 4x3 raster then it might be worth it, but i doubt you could compensate for all the geometric distortions you'd get.
Posted: Fri Jan 23, 2009 12:51 am    Post subject:
How about one wide lens? ( get the white coat ready )
kschmit2
Posted: Fri Jan 23, 2009 9:01 am    Post subject:
I don't think it could work with one lens only due to lens toe-in.
Posted: Fri Jan 23, 2009 6:29 pm    Post subject:
Hmmm yes maybe a 3 angles lens \_/ less pronounced in angle. I think you would run into a fixed throw distance problem with a givin angle with no wiggle room.
Posted: Wed Feb 18, 2009 11:23 pm    Post subject:
ok here is a previous post i had about my scratched HD-10GT17's
here are some pics water and lightly pulling a tissue wont cut it i think Sad
Lens 1
Lens 2
Sucks huh !
I tried some fine cut car polish by hand on one it didn't do any good but it didn't do any harm either as you can see it looked the same as when i got them, the third lens isn't as bad and i think it will be fine these are another story, what do you think?
Are the HD10 lenses that same I have a set of those I could try to remove these and swap them? Is it possible?
Well I was reading to posts on the C-elements and if its possible to have them tinted...I then began thinking of my poor useless HD10Gt17's and decided to take off the bottom lens or at least see if its possible with just regular tools......here are the results. Very Happy Now i am going to look at the HD 10's and see how close they are, maybe a swap will fix them? Or i am sending them out to that Optics place i mentioned in the other thread. The lens is still in a smaller aluminum ring but That I don,t want to attempt to remove. Maybe the coating place can add the coating with the Ring attached?
I put Cellophane over the lens so it wont get any dust inside.
yeah i was Bored.......
waterlily
Posted: Fri Mar 20, 2009 3:13 am    Post subject:
Hi Nashou, Smile
Did you ever find if the outer lens you removed is the same across the different HD10s ?
I have a scratched outer lens on one of the HD10s and was curious if the outer lens could be interchanged between the different HD10 flavors Question
Page 7 of 12
