New Tubes Installed!! :D
Jeremy112
Posted: Fri Jul 08, 2011 2:36 am    Post subject: New Tubes Installed!! :D
Thanks to Greg I have finally got new tubes for the XG1100 (new to me that is Smile )!!
They are fully installed and ready for testing, will do that in the morning when Im not so worn out Smile
For now, heres some pics Mr. Green
Tube Comparison
 Filesize:  250.28 KB
 Viewed:  8506 Time(s)
dvh99
Posted: Fri Jul 08, 2011 2:43 am    Post subject:
are you sure you didn`t put the old worn red back in?
Jeremy112
Posted: Fri Jul 08, 2011 2:45 am    Post subject:
on NECs its backwards, your actually looking at (from left to right) Red Green Blue. The "new" blue tube has wear thats pretty close to what my old blue tube had, but my old blue tube has screen burn from the xbox 360 dashboard, plus the new blue tube has a larger wear pattern on the phosphor.
So to answer your question, Im 100% sure Smile Razz
Posted: Fri Jul 08, 2011 8:42 am    Post subject:
Backwards compared to what? My Sony and NEC are both the same way in terms of colour order.
Jeremy112
Posted: Fri Jul 08, 2011 4:05 pm    Post subject:
NEC arranges their tubes differently than other CRT projectors, most are Blue, Green, Red from left to right when facing the tubes, NEC does it as Red Green Blue..
I don't quite remember what Sonys tube order is, but I know for instance that the Marquees are Blue Green Red...
Jeremy112
Posted: Fri Jul 08, 2011 4:06 pm    Post subject:
Heres the new tubes working! Mr. Green
Now I just need to get the Yolks all straightened out and start astigmation and so forth. Talk about fun Mr. Green !!!
Tubes working!!
 Filesize:  178.05 KB
 Viewed:  10332 Time(s)
dvh99
Posted: Fri Jul 08, 2011 4:41 pm    Post subject:
do the necs project their image diagonal instead of horizontal like other pjs Mr. Green .
just kidding, make you don`t kill thyself when twisting the deflection yoke.
Jeremy112
Posted: Fri Jul 08, 2011 4:44 pm    Post subject:
Hahaha, You know honestly if this is the way I would have bought the projector, without knowing what I know... I would probably assume that they are projecting correctly Embarassed Laughing
ill make sure, I never ground myself to the chassis, always one hand behind my back while operating these puppies with the hood open.
I also rearranged the HV wires so I can safely work in the projector without getting near them Smile
Oh... And if anyone is wondering, I did bleed all the new tubes, the red and green wasn't too bad, but when I stuck the needle into the blue I had glycol squirting into my face Very Happy
They are all depressurized at least Smile
dvh99
Posted: Fri Jul 08, 2011 5:07 pm    Post subject:
i mean the live solder connections on the deflection yoke (the 1 closest to the tube bell).
it`s these connections that carry lethal voltages.
in newer marquees there is a plastic cap over them that prevents you from touching those connections.
Jeremy112
Posted: Fri Jul 08, 2011 5:16 pm    Post subject:
Ahh interesting, thanks for pointing that out to me, ill be sure to be careful Smile
dvh99
Posted: Fri Jul 08, 2011 5:25 pm    Post subject:
http://www.etechvideo.com/images/Tip9/Tip9_01.jpg
picture of live connections on the deflection yoke.
picture is from tims website.
dvh99
Posted: Fri Jul 08, 2011 5:27 pm    Post subject:
did you put the groundstrap back on the tubes?
Jeremy112
Posted: Fri Jul 08, 2011 6:25 pm    Post subject:
Yep on all 3 of them. Mr. Green
Jeremy112
Posted: Fri Jul 08, 2011 6:42 pm    Post subject:
Also heres a pic from when I first bought the XG and set it up, it shows the wear on the tubes (on screen). The picture isn't great so its a bit hard to point out, so I put nice colorful arrows and text on the image Smile
EDIT: I should note that it was a very quick setup, thats why the convergence does not look so good, and if I remember correctly the edge focus and astig needed some work too
 Filesize:  164.39 KB
 Viewed:  10272 Time(s)
Posted: Sat Jul 09, 2011 8:25 am    Post subject:
Here is some pics....
Sony....
NEC PG...
I reckon ive seen more this way than the other, Ive seen a couple Barcos, a DWIN, and a Marquee with them the other way, but then ive seen a Vision One with them the same as above too...
holdenkicks
Posted: Sun Jul 10, 2011 10:29 pm    Post subject:
come to think of it, my sony 1271 has the tubes as Blue, Green, Red when looking at the tubes.
Barco Graphics 808s, ceiling mounted front projection,
Posted: Sun Jul 10, 2011 11:23 pm    Post subject:
Yes when it's on the floor. The NEC's are backwards
greg_mitch
Posted: Mon Jul 11, 2011 3:25 am    Post subject:
Congrats on the new tubes! You worked pretty fast getting those puppies installed.
Great to hear about bleeding the tubes and the blue tube for sure. It is by far the oldest out of the three tubes. Some day you may be able to find a new(er) blue tube without much wear. I had my projector so close to such a large screen that I could actually see about a 2" line on the right side of wear from the blue. I didn't want to make the image any smaller at the risk of ruining the brand new green and newer red tube.
Either way...you at least have a backup blue now with about as much wear. They should last you through that green and red.
Jeremy112
Posted: Mon Jul 11, 2011 5:42 am    Post subject:
I figured that I got them, may as well get them installed right away. the blue tube being older explains the squirting of the glycol, wasn't expecting that, but I had a good laugh from it.
Got them setup a bit further now, honestly I've been spending more time using the projector than working on it, but I'll take a few hours from using it to get the magnetics and other settings more dialed in. I spent the weekend working on it, mainly getting the colors back to normal. I can't beleive how much more punchy the colors look with these tubes!
I have to say for my first complete retubing experience it has been quite interesting and enjoyable, but I do hope it will be a while, or at least, like you said, find a good blue tube to throw in, before I do the retubing thing again.
Thanks again Greg!! Mr. Green
Posted: Mon Jul 11, 2011 7:37 am    Post subject:
At the risk of repeating myself, "compared to what?"
Have a look at my pics, the Sony i have is exactly the same way as the NEC. Im not saying they all are, but when you say backwards, it seems there is just as many that have them this way around as there is the other way around. Ampros are bloody backwards.... Laughing
