| Posted: Sat May 28, 2011 9:29 am Post subject: |
I believe the quad and EHT are a matched set any you must replace both at the same time. That is new quad new EHT.
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
Digitali
| Posted: Sat May 28, 2011 4:55 pm Post subject: |
Thanks..... for the answers....
I cannot open the bottom cover remove or solder a new jumper.....
Thats too special works.... i haven't enough competense for it.
Thats why iam writing here..... if i can isolate the problem it helps me
to buy only the damaged part new.....
So i can buy it without risk, and my barco runs for the next years....
| Posted: Sat May 28, 2011 6:40 pm Post subject: |
Your best bet is to find a used quad as that is the most common failure point IMO. Did you check the fuse on the EHT ?
You could try replacing the HV splitter first if your feeling lucky...Did Curt have a used quad ?
Digitali
| Posted: Sat May 28, 2011 6:52 pm Post subject: |
I don't know if curt have a used Quad....
Where can i get this information ????
Digitali
| Posted: Sat May 28, 2011 7:22 pm Post subject: |
I've just write him a PM.....
