Tube pinout question
Goto page 1, 2, 3, 4, 5  Next
Posted: Mon Jan 31, 2011 6:27 pm    Post subject: Tube pinout question
I've got a bunch of BG808s CRT neck boards out of a Barco (these are the high bandwidth ones from the sets with the Sony tubes).
Is the pinout of the Sony 8" tubes the same as the 9"MX?
I've got a customer that wants to use the BArco 1200 Sony tubes in an 8" set...
TbX
Posted: Mon Jan 31, 2011 6:41 pm    Post subject:
yes it is the same pinout, but it will not work without modifying the base card
//Tomas
TbX
Posted: Mon Jan 31, 2011 6:50 pm    Post subject:
I seem to remember that it is pin 3 and pin 8 to be bridged together
look at the pins on the tube and you'll see which one is cut off
Posted: Mon Jan 31, 2011 6:58 pm    Post subject:
OK thanks! Before I sell them, I'll set them up here to confirm.
Posted: Mon Jan 31, 2011 11:17 pm    Post subject:
Well here is me thinking all Sony pinouts are the same!! I am sure there are people how have simply dropped these tubes into sets with no mods but hey perhaps they did change things!!
TbX
Posted: Mon Jan 31, 2011 11:35 pm    Post subject:
It is the same pin-out barco just cut two pins for grid 1 on the tube in BG1200
Posted: Tue Feb 01, 2011 2:59 am    Post subject:
Are the neck boards in the 1200 the big black box type because the bg808s has a different neck board if this matters.
What does this mean if you use this type of tube sourced from a non Barco environment eg Sony 1292?
TbX
Posted: Tue Feb 01, 2011 8:13 am    Post subject:
I had mixed bg 1200 and Sony 1292 tubes in my bg808 without problems
if I remember correctly it was a pin cut on the 1292 tubes also
Posted: Tue Feb 01, 2011 8:31 am    Post subject:
So did you have to modify the neckboards in that case
TbX
Posted: Tue Feb 01, 2011 8:44 am    Post subject:
G1 comes in pin8 in a 808 I think also the pin is missing on 1200 tube so you can connect it to pin 3
TbX
Posted: Tue Feb 01, 2011 8:46 am    Post subject:
I check this for tomorrow
Posted: Tue Feb 01, 2011 10:46 pm    Post subject:
So Curt how did this work out?
Posted: Sun Jun 19, 2011 9:58 am    Post subject:
Did you manage to check and confirm this?
Decibel
Posted: Sat Jun 25, 2011 11:59 pm    Post subject: another tube pinout question
Can I use panasonic 180dvb22 or P16LNP/LNQ neckboards simply by rotating them 180 degrees in P19LCP07's/LPB's and Lug's?
The socket is rotate but pinout is the same.
 Filesize:  93.34 KB
 Viewed:  33799 Time(s)
Domenico (Barco fan!)
Posted: Sun Jun 26, 2011 1:50 am    Post subject:
No one seems keen to answer these questions.
TbX
Posted: Sun Jun 26, 2011 10:23 am    Post subject:
to use bg1200 tubes in bg808s just connect pin 8 to pin 3 and it vill work
and on p16 to p19 yes you can
Decibel
Posted: Sun Jun 26, 2011 10:38 am    Post subject:
Thank you Thumbs Up
Posted: Sun Jun 26, 2011 9:57 pm    Post subject:
Discovered that but thanks for confirmation.
Decibel
Posted: Tue Jun 28, 2011 1:54 pm    Post subject:
I am very confused.
In this document I found the pinout of the tubes 9".
The order of the pins is described in a clockwise direction.
I take photo of the socket of a neck 9"
I see that the real number is counterclockwise
Posted: Tue Jun 28, 2011 2:20 pm    Post subject:
You cant always go by the socket id. What model projector is that neckboard from?
Page 1 of 5
