A question about HD 8M lens
seamaide
Posted: Wed Jan 12, 2011 9:13 pm    Post subject: A question about HD 8M lens
I tried the lens sticky but the relevant links were dead, so I thought I'd ask it here.
I'm a university student working on an astronomical optics project hoping to use a cannibalized Delta HD 8M lens. But first I have to characterize the lens and find it's optimum performance using ZEMAX to see if it is suitable for the project. I need to know it's technical specifications, things like radii of curvature, refractive index, spacing etc. for the lens elements.
I know that there is 2 patents related to the lens, reading through the convoluted legal-ese of them, it's hard to tell what exactly is in the lens, and I won't be able to take it apart for the moment to find out what is there.
Would anyone happen to have any of these specifications, or indeed know of any issues or aberrations with these lens?
Thanks!
Posted: Thu Jan 13, 2011 3:36 am    Post subject:
Hi Guys, I led this Person here in hopes some one might have an answer for them.
Anyone?
Posted: Thu Jan 13, 2011 5:02 am    Post subject:
Never heard of an HD-8M lens. Is this the same as an HD-8 revision B ?
What are you planning on using if for....... Astronomical ?
kschmit2
Posted: Thu Jan 13, 2011 10:40 am    Post subject:
Let's see if any of this will help, but I fear there is not enough info in those documents for you
Kai
HD-144 pdf 1.pdf
HD144 NEC confidential - do not post
 Filename:  HD-144 pdf 1.pdf
 Filesize:  1.35 MB
 Downloaded:  405 Time(s)
Home Theater Lenses.pdf
 Filename:  Home Theater Lenses.pdf
 Filesize:  73.04 KB
 Downloaded:  424 Time(s)
HD145 Specs.pdf
 Filename:  HD145 Specs.pdf
 Filesize:  20.17 KB
 Downloaded:  823 Time(s)
HD145 Drawing.pdf
 Filename:  HD145 Drawing.pdf
 Filesize:  91.85 KB
 Downloaded:  433 Time(s)
HD10E Drawing.pdf
 Filename:  HD10E Drawing.pdf
 Filesize:  101.05 KB
 Downloaded:  375 Time(s)
HD10 Specs.pdf
 Filename:  HD10 Specs.pdf
 Filesize:  12.53 KB
 Downloaded:  513 Time(s)
HD8B Specs.pdf
 Filename:  HD8B Specs.pdf
 Filesize:  48.1 KB
 Downloaded:  434 Time(s)
HD8B drawing.pdf
 Filename:  HD8B drawing.pdf
 Filesize:  79.29 KB
 Downloaded:  436 Time(s)
seamaide
Posted: Thu Jan 13, 2011 2:10 pm    Post subject:
Thanks for the pdfs! From the little I've been able to find, I think the 'M' refers to a multi-layer coating, so the 8B may be similar lens with a different coating?
I don't have access to a camera at this moment, so here is the other details on the sticker.
Delta HD - 8M
Patent no:4300817/4776681
Part no.: 4-047-750-01
The AR gives the lens a purple and orange shade to the lens. It has a plastic housing, connected to an Al(?) base at the CRT end.
Got the ok from my supervisor to talk about the project. He is involved in neutron star research, and there are these theoretical flashes of light from a certain type. My project is to design a wide-field imaging system, that could look at a large section of sky and look for these flashes. The plan is to hope to use the lens in reverse, coupled with a high-spec cameras to image the sky. But to see if the lens is at all suitable, I need to know the specs in details. See what the aberrations are, and if they can be corrected by adding more elements.
kschmit2
Posted: Thu Jan 13, 2011 2:51 pm    Post subject:
probably an old version (series "A") with ML coating.
That would point to 3 types of HD-8 lenses:
HD-8 (possibly w/o coating, though that would be unlikely)
HD-8M (with multilayer coating)
HD-8 Rev. B (upgraded, and with multilayer coating)
similar to the HD-6 series, that was followed by a HD-6C ML, and then HD-C ML color-filtered lenses
kschmit2
Posted: Thu Jan 13, 2011 2:53 pm    Post subject:
HD-145 and HD-144 would be optically superior to any of the HD-8 series lenses btw, and have similar resolution to the better versions of HD-10 lenses.
Posted: Thu Jan 13, 2011 3:38 pm    Post subject:
You might also consider an Aero Ektar...
http://www.bnphoto.org/bnphoto/KodakAeroEktarGall.htm
http://www.johndesq.com/graflex/aeroektar.htm
Posted: Thu Jan 13, 2011 3:51 pm    Post subject:
That's very true. Also, I don't know that any CRT projector lens is going to be very high-resolution compared to a lot of photography lenses. If a large projection is what's important, and resolution is also important, then I would think a view camera lens for a 4x5 or 8x10 camera would be far superior to most any CRT projection lens.
Posted: Thu Jan 13, 2011 4:30 pm    Post subject:
You should right Ecrabb, the velvia 50 color film (one of the best photo film ever made) has 160 line/mm resolution Wink
zGman
Posted: Thu Jan 13, 2011 4:34 pm    Post subject:
The older HD8 lenses had pretty darn poor focus, and probably aren't worth the effort.
I have lots of of the later version here if you want to pay shipping for two or three.
You can then take one apart to access the components. However, as has been mentioned,
these are not likely to be to be as suitable as a camera lens for your purpose, either in
quality or design. Consider that the image in a projector is only a few millimeters from
the lens....
G
Posted: Thu Jan 13, 2011 4:39 pm    Post subject:
How does that compare to most of our CRT projector lenses, gjaky? Aren't CRT lenses in teh 10-20 lp/mm ballpark?
I don't know all the numbers... I'm just going by the fact that at the bare minimum, a good 4x5 lens would be capable of projecting resolution well in excess of 16,000 x 20,000 lines - about ten times the resolution any CRT projector lens was ever designed to project.
Posted: Thu Jan 13, 2011 4:47 pm    Post subject:
OK, I checked the sticky and it looks like HD-10's were rated about 10 line pairs/mm... HD-8's (any flavor) have to be much, much worse than that... So again, I would think a 4x5 view camera lens would be much better for this kind of research. But, then I guess it depends on the resolution and size of the imaging sensor.
Posted: Thu Jan 13, 2011 4:52 pm    Post subject:
Yeah, the gloryous HD145 has 10 lp/mm Thumbs Up
Anyway who heard digital projector owners talking about lens resolution?
But these lenses have much better f numbers than most stock photographic lens which is a big advantage at night.
Posted: Thu Jan 13, 2011 6:38 pm    Post subject:
I made a wide field telescope out of one of these....
Quote : A 24-inch f /6 Aero Ektar reported to give 142 lines/mm at f /6 with excellent achromatic correction.
Posted: Thu Jan 13, 2011 6:52 pm    Post subject:
Get a Minolta DLP zoom lens, 1.5-3x. I made a small telescope out of one of those, with a custom machined adapter and a helical focuser,
and aside from a SLIGHT amount of chromatic aberration, it delivers outstanding results. I'd like to get the resulting telescope fully
characterized for competitive analysis. The images it delivers are bright and clear without visible coma or smearing at the edges of the visual field.
It qualifies as a very high performance short throw refractor, about f/4 with a 4" objective lens, and based on the cost of the Minolta lens
alone, it should be in the elite class for telescopes featuring similar basic parameters.
I need to make a new adapter assembly for it. The original one was just thrown together for basic testing. I need to spend a day or
two in my machine shop and do the job right.
CJ
Posted: Thu Jan 13, 2011 7:23 pm    Post subject:
If I understand the need correctly the lens needs to to have a very low F #. The 7 inch (177.8mm) Aero Ektar is F 2.5
Posted: Thu Jan 13, 2011 7:30 pm    Post subject:
It's astro work, so I can the requirement for fast glass. The HD-144 is something like and f/1.1 or f/1.2 lens. But, what about the size requirement? Why does it need to be so big? What sort of imager will be used that requires a 5" image circle? If we're talking about the size of most types of imagers, then there would be a large pool of 35mm lenses from which to choose that would be nearly as fast and would be far superior to any CRT glass.
Posted: Thu Jan 13, 2011 7:32 pm    Post subject:
hm not bad Smile
There is one up on ebay located in England!
http://cgi.ebay.com/KODAK-AERO-EKTAR-7-178mm-f-2-5-LENS-5X5-FORMAT-/120671152158?pt=UK_CamerasPhoto_CameraAccessories_CameraLensesFilters_JN&hash=item1c188fa81e
9days left... I think the prices would go up a bit :/
Posted: Thu Jan 13, 2011 8:25 pm    Post subject:
It can get expensive though...
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2150/AF-S-VR-NIKKOR-200mm-f%252F2G-IF-ED.html
Shocked Shocked Shocked
