Everything you want to know about Frankenyokes in one shot!
Goto page Previous  1, 2, 3 ... , 35, 36, 37  Next
redfox001
Posted: Thu Apr 09, 2015 11:48 am    Post subject:
I am trying the focus yoke of my 909 in my 9500 and have the following problem.
The static focus vertical needs to be set 100 and it still is not focussed.
The dynamic focus horizontal seems to be in focus right away.
I moved the yoke as much forward as possible moving it backward made the focus worse.
When I measured the resistance of the static vertical yoke I measured less than 1 Ohm while the Thomson measured 41,3 Ohm. I tend to conclude this Barco 909 yoke is not compatible at all. Am I doing something wrong?
The dynamic horizontal windings also measure less than 1 Ohm.
The image was turnes 45 degrees. Could reversing the magnet in the house be a solution?
redfox001
Posted: Thu Apr 09, 2015 12:14 pm    Post subject:
This is how the pins are related:
Now because static focus is vertical and dynamic focus is horizontal I came on the following pin mapping.
I came to these pin numbers by looking in the schematics and a little number is written next to the connector symbol on the Marquee docs for focus and astig. With the Barco there was a layout of the motherboard.
marquee: barco 909
focus
p101
pin1 = R-DYN-H pin7
pin2 = R-DYN-L pin9
pin3 = R-STAT-H pin3
pin4 = R-STAT-L pin5
pin5 = R-TEMP-L earth pin1 ?
pin6 = R-TEMP-H
astig
p2
pin1 = RY-STIG-L pin2
pin2 = RY-STIG-H pin4
pin3 = RX-STIG-H pin8
pin4 = RX-STIG-L pin6
barco cine9:
focus and astig
J155
pin1 = earth
pin2 = 4PYL-R
pin4 = 4PYH-R
pin6 = 4PXL-R
pin8 = 4PXH-R
pin3 = FVH-R
pin5 = FVL-R
pin7 = FHH-R
pin9 = FHL-R
pin10 = 6P
pin11 = 6P
pin12 = 6P
pin13 = 6P
barclay66
Posted: Thu Apr 09, 2015 12:58 pm    Post subject:
What makes You think that this is the case?
This is what the Marquee circuit description says:
"The Focus Module supplies the magnetic focus coils of each CRT with current waveforms which create a magnetic field within each CRT neck allowing control of the diameter of the electron beam as it lands on the CRT face plate.
Each focus coil assembly consists of a permanent magnet, a static focus coil and a dynamic focus coil. The permanent magnet approximately focuses the beam in the center of the faceplate. A current through the static focus coil provides for tolerance correction of this focusing field.
The current is modulated at the vertical scan rate by a waveform from the VDM to correct for the change in focal length as the beam sweeps from the top of the raster to the bottom. Similarly, the dynamic focus coil receives a horizontal rate waveform from the CLM to correct for the focal length change as the beam is swept horizontally for each raster line. The red, green and blue CRT focus coils are driven by identical but separate amplifier circuits which each receive their own independently controlled modulation waveforms."
So there is a vertical/horizontal influence to the static/dynamic coils but I wouldn't assign them strictly to each other...
Regards,
barclay66
redfox001
Posted: Thu Apr 09, 2015 1:08 pm    Post subject:
Ok but I can not get the center focussed.
The strange thing is that I now try the sony 1292 coils and they measure something like 52 Ohm but still I need to go to 100 in the global focus and not sharp.
I must be doing something wrong perhaps turn the coils in the housing?
redfox001
Posted: Thu Apr 09, 2015 1:23 pm    Post subject:
My mistake. I had the high and low pins reversed. I compared with the doc that was posted here. Perhaps there is a reason to reverse the pins so you do not have to tunr the inside of the coil? Or are the schematics just wrong? Goog thing these Molex pins can be changed easily Smile
I had
1 = 7 2 = 9
below
2=7 1=9
etc.
barclay66
Posted: Thu Apr 09, 2015 1:24 pm    Post subject:
There are lots of possible variables:
- Positioning of the static magnet
- Strength of the static magnet
- Static Voltages too high/too low for static winding
- Inductance of stating winding
- Coil orientation/winding direction
And this is the static stuff only...
I know why I would never touch this area...
Regards,
barclay66
redfox001
Posted: Thu Apr 09, 2015 1:26 pm    Post subject:
He seems fixed.
The grid is turned 45 degrees with the coil and that seems to be because the permanent magnet is reversed. Anash advises to leave it this way but probable reverses the pins on the coils.
I wonder if I will simple reverse the inside of the coils as I already opened it. Any advise someone?
redfox001
Posted: Sat Apr 11, 2015 7:25 am    Post subject:
Ok results so far. The 909green yoke works but he others have to weak magnets.
The 1292 yokes work better again not completely the same. The result is that I now have the contrast lower and still have the punch or more light. The control over the beam feels better and without centering problems I find it easier. I had the green astig done in half an houre and see now the different lines in the 1:1 pattern very clearly.
Seems the longer yoke diffuses the beam less as there is more concentrated light. About blooming I did not see that much before with the mp boards do not see much after certainly not at 70 maybe at 90.
redfox001
Posted: Sat Apr 11, 2015 9:21 am    Post subject:
One question for CMJohnson.
Do you have the equipment to magnetise focus yokes?
My center focus vallues are 28R 31G 28B These are somewhat low. If remagnetising would make them 40 that would be nice.
Posted: Fri Apr 17, 2015 5:11 am    Post subject:
Tse is the ONLY person who visits this forum who currently has access to the only known (that I am aware of) magnetizing rig for focus yokes.
I would suggest you contact him and see if he is willing to adjust your focus yokes to an optimal magnetic strength value.
redfox001
Posted: Fri Apr 17, 2015 8:18 am    Post subject:
Thanks for the info!
One other question. Yesterday I tried the focus as good as possible and found out I have to little range at the static bottom side.
My midpoint focus is around 20 on that one and 0 is to high at the bottom. The other 2 just have enough.
Did you experiment with removing the ring from the convergence yoke to get the focus yoke more forward?
I am now thinking of setting this one on blue.
koldby
TV/Projector: GJAKY modded VDC marquee 9500lc ultra
Posted: Sat May 23, 2015 10:04 am    Post subject:
Aparently all the pictures of the original frankenyoke MKI and MKII are missing...
Can this be fixed??
Koldby
What is home theater without good sound?
koldby
Posted: Sat Jul 18, 2015 9:56 pm    Post subject:
Has anybody tried yokes from Barco 1209s?
redfox001
Posted: Sun Jul 19, 2015 7:40 pm    Post subject:
I have tried 809 those did not work.
nidi
Posted: Wed Jul 22, 2015 8:01 pm    Post subject: G90 yokes
I've been running G90 yokes for the last 6 years in my 9500 ultra.
even tough the electronic settings won't have the same range as with the Tompson yokes,
the final result in so much better.
they can be tuned in manually almost perfect.
Michael
Posted: Wed Jul 22, 2015 8:43 pm    Post subject:
If anyone is interested, I do have at least one set of G90 yokes in stock that I'd sell cheap.
redfox001
Posted: Wed Jul 22, 2015 10:17 pm    Post subject: Re: G90 yokes
Michael
How do you tune them manually? You mean taking of windings?
jbmeyer13
Posted: Thu Jul 23, 2015 5:35 pm    Post subject: Re: G90 yokes
Michael
He means physically adjusting the placement of the yokes as they sit on the tube.
redfox001
Posted: Thu Jul 23, 2015 5:48 pm    Post subject:
Taking them backward? How odd all yokes I have tried needed more forward.
Posted: Sat Jul 25, 2015 12:54 pm    Post subject:
No, I can't do anything about the broken photo links early in this thread. Those photos are gone, lost in my OLD computer which has long since been retired.
Just to review a few basics about yokes, to help with your diagnostics:
Install a stock Thomson yoke on your green tube if you don't already have one. Disconnect all plugs on it and see how well focused your picture is.
What you get is due to the static magnetic field only. It should not be perfectly focused. But it shouldn't be THAT far off.
Now, disconnect a dynamic winding from the focus yoke. Pull one of the pins out of the connector with the aid of a very small screwdriver.
The two central pins are for static focus, so you'll remove (sorry, I forget the color code) one of the two lead going to the dynamic coil.
Now plug the focus coil back in and adjust your focus setting until it looks the SAME as when you unplug the coil. Make note of this value.
Now adjust for best central sharpness, and make note of that value.
Reconnect the dynamic winding and now adjust dynamic focus for best results. Note the values.
Ideally, the "same as unplugged" value should be between 40 and 60. (I'm thinking 60 is what TSE said is optimal.)
Plugged in, it should take an adjustment of no more than 10 to achieve sharpest center focus. With a yoke that has optimal parameters.
Now, run the focus range from 0 to 100 and back to best focus and make note of how much this affected the size of the grid lines.
You can repeat this process with the astig windings as well, but do CPC ring astig adjustments first.
In order to evaluate an alternative focus yoke, repeat the above test and make note of the values you get.
The first thing this series of tests will tell you is if the strenght of the permanent magnets in your candidate yoke is even appropriate for the application.
The second thing this will tell you is if the static windings are effective and if they have adequate range or if they have too much range. You don't really want them to have more range than stock yoke static windings do. With too much range you'll lose fineness of adjustment when you're nearing the range of best focus.
The third thing this will tell you is if the static windings are effective and have adequate range. Same rules appliy as to the static windings. Use the Thomson yoke focus range and values as your general target.
And of course, the fourth thing you'll learn from this is how well the electronic astig windings work.
If passive magnetic focus isn't in the right range, static focus won't fix that. If static focus can't make it right, dynamic focus is irrelevant. And if it's still wroing, who cares about astig?
The path to optimizing a yoke for a Marquee is to first check and adjust passive focus which usually requires magnet strength adjustments. Unfortunately,
very few people have the capability to do that. With passive focus being in the right range, then the static focus coil needs to be evaluated, and if it has too much focus capacity, take a few winds off it. If it lacks enough capacity, carefully unwind it and count how many turns are on it, and then rewind it with new wire and add on extra turns, retest, and repeat as needed. Then address dynamic focus in the same way.
Odds are that due to the way the astig windings are made, yoou won't mess with them. They'll probably do the job in any event.
Page 36 of 37
