zGman
| Posted: Wed Nov 28, 2007 7:48 pm Post subject: |
frt centering clamp is co-axial, ie not for beam centering, just physical.
Chuchuf
| Posted: Wed Nov 28, 2007 8:55 pm Post subject: |
| garyfritz wrote: | Anyone? Anyone?? Do I have it right now?
Also, something occurred to me -- one of the reported major benefits of the Fyokes is the ability to run at much higher contrast levels without blooming. But you still have the basic limit of the blue's ability to emit light before overloading. If you run at higher contrasts, won't you have to run the blue even more defocused in order to compensate for the hotter red and green? |
In the testing of the KD22-22 focus yokes one of the first things that we noticed (along with a measured smaller dot and one that would hold together tighter over a wider contrast range) was that the distribution of the beam energy over a line or dot when focused was much more even than the Thompson focus coils. In other words, if you were to go from one edge of a small line to the other instead of it being a bell curve (if plotting light intensity across a line or dot) it would be more like a digital function (ie it comes on on the edge, stays the same across the line, and then drops off at the other side.
I personally believe that if the resolution and optical focus are optimized so that these "lines" are touching each other you will have two distinct improvements. First the focus will be much omproved, and second there will be more light output for a given contrast setting.
I've built 4 9500's now with the KD22-22's and helped Galen with his towards the end and all appear to be brighter than stock.
This mod IMO is the single biggest improvement that can be made to the Marquees short of MP's mods. The KD22-22's are a big improvement to the stock tubes as well. I just finished up one with "stock" P19LCP07 (barco) tubes and the picture is nothing short of spectacular.
Terry
| Posted: Wed Nov 28, 2007 11:44 pm Post subject: |
Well hopefully the KD22-11's do almost as well!
zGman
| Posted: Thu Nov 29, 2007 1:03 am Post subject: |
Greetings,
Another thing I spent a lot of time on was adjusting the convergence yokes
so that the axis of adjustment coincided with the V-H axis on the screen, eg
so that there was no diagonal movement during convergence adjustments - maybe the wrong
thread, but I would like to ask if there are others who have noticed any correlation
between "banding" and stability and making this somewhat tedious adjustment???
Older Marquee's just used hot glue between the deflection and convergence yokes -
later models seem to have "superglue" locking them together - thus making
the process of freeing up the adjustment somewhat nerve-wracking....hohohoho!
Galen
| Posted: Thu Nov 29, 2007 1:11 am Post subject: |
At the factory, the convergence yoke is hot-melt glued to the deflection yoke after the alignment is done. There's a certain degree of
built-in rotational adjustment between the two yokes. Any time any yokes or the tubes are changed, it may be necessary to remove
the hot melt glue and readjust the convergence yoke.
Always make sure the convergence adjustments work properly. Sideways adjustments should not move vertically, or vice versa. It's probably the single simplest adjustment you can make on a Marquee's magnetics, and as the voltages on the convergence yoke are very
low, only about 20 volts at most, this is an adjustment that doesn't present its own safety issues. But be careful of that nearby deflection
yoke and its exposed pins!
CJ
zGman
| Posted: Thu Nov 29, 2007 2:07 am Post subject: |
Hi Chris,
When you get into the late model Ultra's (my two are 2002/3), you will discover that the conv yokes are
actually "superglued" to the deflection yokes, not too easy to separate! The glue is actually internal
to the mechanical joint, and not an externally applied bead as on the earlier models....
But yes, considerable care should be taken adjusting while running - personally, when too much effort
was required I depowered the set. My feeling was that the adjustment would reduce the load on the
conv board and possibly reduce the chance of "banding". etc.....
G
| Posted: Thu Nov 29, 2007 4:55 am Post subject: |
| tse wrote: | | Best position would be with static focus at 50, both picture menu and service menu, slide magnet back and forth on neck for best focus. You can leave the CPC magnets off until this is determined. If mag ends up against the yoke or 1/2" back then you are good to go. |
OK, I tried a coil on the red. I left the CPCs off and set FOCUS and RGB FOCUS (center) to 50. Focus was clearest with the focus coil all the way up against the yoke. However that wasn't enough. I had to run the FOCUS up to 80-100 to get the sharpest focus. (This was approximate because I don't have the projector in a place where I can project onto a screen. I was looking at the tube face with a magnifying glass.)
So next I put the CPCs on, set FOCUS to 50, and ran the R FOCUS up to 100. Even then I think the focus was a bit sharper with the FOCUS up around 60-70 or so.
Is that a concern? Is this going to work properly if the focus circuit has to work that hard?
Interestingly, pulling the focus coil away from the yoke not only affected the focus -- it also rotated the raster slightly. Not sure if that's expected or not.
(BTW I really **HATE** the VNB socket. If you get any pins bent just a little, it is a colossal PITA to get the board back on. You can't see what you're doing and you can't get in there to straighten out the pins. I fought with the red VNB for over half an hour, urghghgh...)
1031
| Posted: Thu Nov 29, 2007 5:56 pm Post subject: |
If the focus isn't sharpest near the optimal adjustment range of 40 to 60, then most likely the field strength of the permanent
magnets in the focus yoke isn't optimal. Tse has the ability to readjust the magnet strength of Thomson yokes but I don't know
if he's able to do this on the K-D yokes. Nor am I suggesting that you ask him to do that. In fact, I would ask you NOT to ask
him for that as he doesn't OWN the magnetizing jig. He just works there. Perhaps a deal can be worked out, in time, which
allows you to send your yokes to VDC for magnetic optimization for a REASONABLE cost.
CJ
| Posted: Thu Nov 29, 2007 6:36 pm Post subject: |
Hm. So at least for this coil I've tested, the magnets are not the right strength for the tube, so it is not usable without re-magnetization? That's a major bummer.
I assume if it doesn't work with the red, it won't work with the other tubes either? So it's not worth the hassle to test this coil on the B & G?
I will go ahead and test the other coils. If for some reason one is bad but the others work OK, would it be reasonable to e.g. use KF2211's on R & G, and use Thompson on B where focus is less critical? Or is it a bad idea to mix coils?
zGman
| Posted: Thu Nov 29, 2007 9:40 pm Post subject: |
Hi Gary,
There's a big difference between "not optimal" and 'won't work'.....!
One thing you may want to bear in mind is that the focus is
extremely dependant on the cpc magnet setup.....
and if you have an 8000, then that's really all you have
to work with to control flare/stig....
I would encourage you not to give up just yet...
Cheers,
Galen
tse
| Posted: Fri Nov 30, 2007 1:18 am Post subject: |
| garyfritz wrote: | | tse wrote: | | Best position would be with static focus at 50, both picture menu and service menu, slide magnet back and forth on neck for best focus. You can leave the CPC magnets off until this is determined. If mag ends up against the yoke or 1/2" back then you are good to go. |
It helps to set the CPCs to null by overlapping the tabs, like the yellow tabs in the attachment, before aligning the magnetics.
If it works, it works. Only downside is it makes it harder to set the stig CPC rings if it isn't defocussed enough.
That is normal.
(BTW I really **HATE** the VNB socket. If you get any pins bent just a little, it is a colossal PITA to get the board back on. You can't see what you're doing and you can't get in there to straighten out the pins. I fought with the red VNB for over half an hour, urghghgh...) |
The pin sockets are a PITA but they are very good for bandwidth.
Scott
| Description: |
| Filesize: |
58.92 KB |
| Viewed: |
8352 Time(s) |
Thomas Jefferson
| Posted: Fri Nov 30, 2007 1:36 am Post subject: |
| tse wrote: | | It helps to set the CPCs to null by overlapping the tabs, like the yellow tabs in the attachment, before aligning the magnetics. |
They were. Not 100% perfectly overlapped, but close enough to almost touch.
| Quote: | | If it works, it works. Only downside is it makes it harder to set the stig CPC rings if it isn't defocussed enough. |
Well, if that's the worst problem, I can live with that.
| Quote: | | The pin sockets are a PITA but they are very good for bandwidth. |
I wish they'd just flare the opening a bit so there was a bit bigger target to hit... whine whine
Thanks Scott!
| Posted: Sat Dec 08, 2007 9:16 pm Post subject: |
OK, I finally got the other KF2211's installed, but I'm not sure this is going to work.
I reset the projector (I have a new CLM in it anyway) and made sure all the CPC rings were neutralized. All three focus coils are butted up against the front yoke.
* As I mentioned, I put the red in before. FOCUS has very little effect on this color. Sweeping FOCUS from 0 to 100 makes a noticeable change, but just barely. I had to set the Red Focus to 100 to focus the red with FOCUS at 68. I can't get a sharp focus with FOCUS at 50.
* The green is dramatically different. It gets hugely affected by FOCUS, more like I would expect. (Except there is some raster distortion as you sweep FOCUS -- the vertical lines don't stay quite straight. Not sure if that's normal. The raster also moves left-to-right a fair amount as I sweep FOCUS.) With the FOCUS at 68, the focus is sharpest with Green Focus at 32 or so. So the green would probably focus just fine with FOCUS = 50 and Green Focus = 50 or so.
* I must have a bad connection in the blue yoke, or a bad coil. Blue is out of focus and FOCUS doesn't affect it at all.
The R and G yokes are identical -- the ones with the "+10" sticker on them.
If all 3 colors worked like the G, I'd be in good shape. But the R doesn't seem to be affected much by focus adjustments, and the B isn't working yet. The R is nicely centered, but the B and G rasters are off to the left slightly. And, of course, I don't have any Thompson centering adjustment. I can improve the G centering a bit by rotating the coil about 180°, so the wire/socket is on the bottom, but it's still not perfect. Maybe half a square off in the RGB Focus pattern. Blue is about the same. I assume I should be able to correct this with the convergence adjustments, though that's not ideal.
Any ideas why the R acts so differently from the G? If I could get the R working like the G, and fix the B, then maybe this would work. Maybe it will work OK with the R not focusing much, but...
Gary
tse
| Posted: Sun Dec 09, 2007 12:40 am Post subject: |
It's alot of work but try each of the mags on the green tube and see if the mags are different or if the projector color circuits/wiring are causing the different responses.
Scott
Thomas Jefferson
| Posted: Sat Dec 15, 2007 8:22 am Post subject: |
Well I got word back in late november from the coil winding place just before i left for my trip here to Greece. they said the magnets they can not do but they can rewind the coils . but i they want an engineering fee of about 250-500 to set up and test the wind and they said this is the standard one time fee. i havnt thought of it much except for the last few days. But if enough people want to have thier coild re-wound to the correct specs and maybe TSE can work out a deal with VDC to use the magnet gauser at his work we can still use the barco focus magnets . Or maybe there is a way to magnetize them in the manner that Chris Johnson did with the CPC magnets? The latter would take alot of trial and error with magnetizing each ring and then putting it all back together for testing, ect.
TSE are you able to use that deivice at work?
tse
| Posted: Sun Dec 16, 2007 6:19 pm Post subject: |
Bad news about the magnets. That would have been a good thing. Winding the bobbins should not be a big deal. Any transformer, motor rewinding type place should have no trouble rewinding the coils. You can do it by hand if you can rig up some kind of hand crank device. The magnets are the right gauss if you put them on the tube without the wires connected and the tube is close to focus. Leave the CPC mags off for this test.
Scott
Thomas Jefferson
| Posted: Sun Dec 16, 2007 6:48 pm Post subject: |
I think i have a test pattern showing the focus of the magnets alone somewhere, i'll post back and let me know if it is adequate. also on the winding of the coils, does it really matter for each wind to be perfectly right next to each other row after row or can they kinda be randomly wound as long as you keep the wind even across the bobbin with no major high or low spots? I wound the one to 30mh but never had a chance to test it as i was in the process of sending them to the winding place.
ok found the link to my first test of just magnets.
tse
| Posted: Sun Dec 16, 2007 7:52 pm Post subject: |
That focus looks good enough. A little current through the static winding should bring it in. The windings don't have to be real neat. Though if they are too rough it might be hard to get enough turns on to the bobbin.
Scott
Thomas Jefferson
