Chuchuf
| Posted: Thu Sep 20, 2007 2:29 pm Post subject: |
| Gino wrote: | | Chuchuf wrote: | Our measures experiments were done on a VDC Marquee Ultra and only on the G tube. Measuring the G lines with a micrometer, we found that the width or the line reduced in size from 20% (at low contrast) to 50% (at 100% contrast).
Terry, do you forsee and problems running a marquee at contrast 70-80? ie. other than wearing the tubes faster, will there be any detrimental effect to the rest of the projector? |
Gino,
IMO as long as you have the color balance (grey scale) set for it I don't think it should be a problem.
Terry
| Posted: Fri Sep 21, 2007 1:59 am Post subject: |
Earlier in this topic the electrical parameters of the various yokes are listed, and comments on their performance are also in there as well,
and if they were cut and pasted into a single reference sheet it would be handy. I do know that some people have found yokes that
are physically very similar to the 2211s but gave unsatisfactory performance as their designed magnetic and inductive parameters were
clearly way different.
All KD magnetics taken from EM focus AmPros are good candidates for mods WITHOUT astig.
Sony 1292 yokes are candidates for all Marquees WITH astig. These are KD 22-22 types, or similar.
I have found that the inductance value of the dynamic winding really isn't all that critical. I rewound ONE yoke in a set of three
to match the electrical parameters that Scott gave me, and frankly I can't tell which one is the rewound yoke in the projector.
Yet its original value was a THIRD of that inductance value.
CJ
CZ Eddie
| Posted: Fri Sep 21, 2007 10:53 am Post subject: |
I have the 22-22 equivalent yokes. Same model # as what Gino recently got. Maybe I should go back through the thead and see if there is a how-to on checking it's values to make sure these yokes are still top performers.
When a yoke gets near another magnetic device even for just a short while, it can have a permanent effect on it's values from what I have read.
_________________ Back after a digital sabatical.
| Posted: Fri Sep 21, 2007 11:50 pm Post subject: |
Permanent if you don't have a way to remagnetize them, that is....
When I get a spare day during the week, I HOPE that I'll be able to ask Scott to check out the mag field strength of my 1292 yokes
and see if they're adjustable, using a spare 22-11 as a test mule. If his gadget will readjust a 22-11, it'll readjust a 22-22.
CJ
Joust
TV/Projector: Marquee 8501LC
| Posted: Fri Sep 21, 2007 11:55 pm Post subject: |
CJ
get a set of yokes from a Barco and have him check them? Of they are different see if he can readjust them.
The Barco yokes are much more plentiful.
| Posted: Thu Sep 27, 2007 4:59 pm Post subject: |
OK, since you guys didn't post a list of yokes, I've gone through all of mine, and here's what I've found.
There seem to be two distinct yoke sizes all those molded plastic KF-XXXX ones that are rivted together. Then there are yokes with astig and with no astig windings:
Small with astig windings:
KF- 1916C
I've got two sets with no markings at all, but they look like 1916Bs
Small ones without astig windings:
KF-1916B
Large ones with astig windings
KF 22-22 (I have no stock of these)
KF 3203
KF 3205
Large ones without astig windings:
KF 22-11
KF 2206
Once you guys fill me in as to whether the above will make an improvement, I'll post what I have in the for sale section.
Joust
| Posted: Thu Sep 27, 2007 5:39 pm Post subject: |
do any of those yokes have the number 1-452-811-11 on them anywhere.
if they do, i call dibs!
| Posted: Thu Sep 27, 2007 9:01 pm Post subject: |
Nope, none of those numbers at all, I can post pix of you want. I know one set came off a 1209s (no idea how, I've never scrapped one of those!), the rest are off Barco 1200, 808, 1208 and Ampros.
Joust
| Posted: Thu Sep 27, 2007 10:22 pm Post subject: |
can you take some basic resistance measurements?
are they like this?
Pin # Ohm reading
2-4 3.3ohms
3-5 0.95ohm
6-8 3.3ohms
7-9 0.95ohm
| Posted: Fri Sep 28, 2007 1:00 am Post subject: |
Guys!
I have not followed this closely but it appears that some Sony yokes are without stig (dot roundness) correction so, if you lack that, which is rather important, what have you gained?
Joust
| Posted: Fri Sep 28, 2007 1:23 am Post subject: |
Tim, those guys are using them in 8000's. no astig to begin with.
| Posted: Mon Oct 01, 2007 3:10 am Post subject: |
Not only that, but honestly, I would rather run FrankenYokes WITHOUT astig windings on an 8500 than run the STOCK yokes WITH astig windings on an 8500. I believe that you gain more in total picture quality than you lose that way.
I woudn't say that if I hadn't actually tried it.
CJ
bomrat
| Posted: Thu Oct 18, 2007 11:43 am Post subject: frankenyoke |
hi, does anybody have a cleaned up doc with pics on how to do the frankenyokes?
thanks
| Posted: Thu Oct 18, 2007 12:54 pm Post subject: |
| Tim in Phoenix wrote: | Guys!
I have not followed this closely but it appears that some Sony yokes are without stig (dot roundness) correction so, if you lack that, which is rather important, what have you gained? |
I just did the magnetics on my 8500 and got such a nice round dot with out useing the electroninc astig adjustment. so i agree with CJ you really dont need them.
Athanasios.
| Posted: Thu Oct 18, 2007 9:50 pm Post subject: |
ok Who stole the Coils from hammerhead technolgies from me!!!! i was trying to find out if they had a set . they have the tubes from a 1292 and so i asked about the focus magnets and they gave mea ebay number but the coils looked wrong? so i was in email contact sent hima pic and then i got a reply he just sold them!!! You guys are seaky!
Joust
| Posted: Thu Oct 18, 2007 10:43 pm Post subject: |
| Nashou66 wrote: | Does anyone know if the 1292 focus coils had this part number as well: 280164348437.
Athanasios |
as far as I know. No.
they are sony # 1-452-811-11 . both according to the examples I have seen and the service manual.
nomadII
| Posted: Fri Oct 19, 2007 4:06 pm Post subject: |
I think this market may get a tad less competive since I believe all members of the "Blending Posse" (8022 / & Marquee owners) that had interest have procurred VPH-1292 yokes. That was 6 complete sets!! None to my knowledge came from HammerHead.
