Everything you want to know about Frankenyokes in one shot!
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 35, 36, 37  Next
zGman
Posted: Wed Sep 05, 2007 2:47 pm    Post subject: Focus coil polarity
Lots of nice work guys! here's something you may find interesting as well.....
The BG808S with KF-3205 and 1208S/2 with KF-3203 both use a "reversed"
coil on green (KF-3205G and KF-3203G). This is easily verified by repulsion/attraction.
I installed an extra "G" coil onto the red tube just for experiment's sake a year ago,
there was no improvement in focus, but the geometry&convergence for the Green and Blue
were seriously affected by the reversed "G" coil placed on Red.
My conclusion was that Barco had reversed the green magnetic field in order to balance
the overall field in the chassis, possibly helping with geometry/convergence/linearity issues.
Cheers,
Galen
Posted: Wed Sep 05, 2007 4:51 pm    Post subject:
I was wondering about that possibility but wasn't ready to risk pulling the beam right off the phosphor face and burning a hole in the neck of the tube. If Barco was willing to take that chance, then I'm glad for it.
Reversing the middle coil's magnetic polarity seems like it would be good for balancing the overall magnetic field.
This might result in simpler alignment, too, as I have noticed a SLIGHT bit of interactivity...I think. Move the red focus coil
and the green image moves just a little bit. Or so that's what I THOUGHT I saw.
CJ
Posted: Wed Sep 05, 2007 4:59 pm    Post subject:
antorsae wrote:
What this means is that you:
1) no longer need to open the frankenyokes.
Don't you still have to open the KF22-22 (or KF22-11 in my case) to move the coil over to a Thompson shell? Or can you just slide the 22-22 or 22-11 right onto the Marquee tube without mechanical modification?? I assume you still do need to do the rewiring step.
Joust
TV/Projector: Marquee 8501LC
Posted: Wed Sep 05, 2007 5:35 pm    Post subject:
No you don't.
you can leave them in the DK housing. I turn them, I haven't tried it but Chris Nuttal told me he could not get them to focus properly if not turned. it could be that the dynamic coil is at one end of the assembly and needs to be closer to teh bell. just guessing. My point is that we need to turn the yoke inside the housing for it to work in the marquee.
on another note. the Sony part number of the yoke is 1-452-811-11
i have seen many yokes with the Kxxx numbers and there seems to be no ryhme or reason to then. they are NEVER the same on two sets and in fact often mixed within the same chassis. perhaps they are build date codes. my point is i have never seen a 22-22 number, ever.
Posted: Wed Sep 05, 2007 5:55 pm    Post subject:
No you don't have to move them to a Thompson shell, but yes you DO have to change the wiring?
When you say you "turn" them -- do you mean you flip the unopened shell front-to-back, or you open the shell and flip the coil inside front-to-back, or you rotate the shell on the tube, or...?
I just looked at my KF22-11's. I don't see any mechanism to move the coil on the tube neck for raster centering. I haven't tried slipping it onto a tube but it looks like it just fits snugly and has no centering movement. Am I missing something?
Joust
Posted: Wed Sep 05, 2007 6:16 pm    Post subject:
you can flip the entire thing but you can get it much closer to the front by rotating it inside the shell.
Yes you do have to make a new harness. I simply replaced the ends on the stock Sony harness I'll take some pictures of Gino's new harness tonight.
You are correct, there is no centering mechanism as found on the thompson but it is not needed. the DK yokes are made much better and do not require it. my old thompsons could not move enough to center the beam on my red tube. I put on the DK yoke and the beam was smack dab in the middle.
BTW, I just got a reply from Sony Canada. the Good news is the yokes are available new from them. the bad news is that they are $415 each. so for a mere $1245.00 plus 14% tax, you can have a set.
antorsae
Posted: Thu Sep 06, 2007 12:04 pm    Post subject:
IMPORTANT UPDATE: You DO NEED to reverse the polarity inside the shell. Once I installed the 3 focus coils in their original polarity the image on all 3 rasters was rotated around 30 degrees. I took the precaution of turning contrast down to 10 before turning on the PJ, so it did not make any damage.
Maybe the magnetic field is different and it affects the deflection coils, I don't know, but I took everything apart again, reversed the polarities (to match the original stock Thompson polarity) and voila... rasters are horizontal again.
In addition, I have also found that once installed; I needed to rotated the focus coil 180 degrees around the neck to get the raster centered on the tube face (that is, the cables would come out from the bottom of the tube). That got me some mechanical rastering centering so hopefully I can avoid static convergence (specially concerning on green).
BR - Andres
Posted: Thu Sep 06, 2007 2:06 pm    Post subject:
Frankenyokes do require about a 30 degree raster rotation via the deflection yokes. This is normal. Nothing to worry about.
What's important is that the beam stays on the phosphor face or at least doesn't get past the silvering. That's a troublesome
condition if it happens.
CJ
Joust
Posted: Thu Sep 06, 2007 2:16 pm    Post subject:
I did NOT have to turn my raster.
CJ,
perhaps you were running into the problem that Antorsae described as a result of not turning the yokes inside the shell?
IIRC Chris Nuttal did have to rotate his deflection coil a bit but no where near 30deg. He said 10 or so. Mine were about 2-5 deg and i adjusted it out without issue.
antorsae
Posted: Thu Sep 06, 2007 5:55 pm    Post subject:
Same over here, with the reversed polarity (vs. the stock 22-22/G90 yokes) there is no need to tilt the deflection yokes.
I was able to do mechanical raster centering by turning the focus coil around the tube neck. Just finished with one projector. I have NEVER seen my projector this sharp. I am running contrast 80. Amazing.
Posted: Thu Sep 06, 2007 6:20 pm    Post subject:
OK. So with my KF22-11's, I should be able to:
* Use the current shells, and not transfer into Thompson shells.
* Open them up and reverse the coil.
* Wire up a connector as described in the FYoke I writeups.
* Slip them onto the necks (as far forward as possible?) and hope they center the rasters properly.
* If they don't, I can move the coils into Thompson shells to regain centering adjustments.
* Level rasters if necessary.
* Adjust my CPC tabs to shape blobs in the center as round as possible, because I won't have any electronic astig adjustment; with luck I won't miss it.
Am I missing anything?
Gary
Joust
Posted: Thu Sep 06, 2007 7:20 pm    Post subject:
Gary
even if you transfer them to Thompson housings you still cannot "center" them because the DK bobbins are the same size as the neck. There is NEVER a need to transfer.
there is an infinitesimal amount of play and you could shim with paper if you felt the need but that will buy you very little.
Posted: Thu Sep 06, 2007 7:27 pm    Post subject:
Ah -- OK, thanks for that clarification. So either they work without centering, or they don't work very well at all. (Because you'd have to use too much electronic centering and your stability would probably suffer.)
This project gets simpler all the time! Smile I guess the only thing I need to worry about is to make sure I wire it up right.
Joust
Posted: Thu Sep 06, 2007 7:31 pm    Post subject:
correct.
It will be interesting to see why CZEDDIE has his not working correctly. i have not seen a set that have not worked yet. buts that is only 4 sets ...
antorsae
Posted: Thu Sep 06, 2007 7:38 pm    Post subject:
Try to rotate the focus coil around the neck to see if you can move the raster. It has worked for me. I've been able to center the raster that way.
Best - Andres.
Posted: Thu Sep 06, 2007 7:43 pm    Post subject:
Just to make sure I'm not making some dumb assumption: by focus coil, you mean the 22-11 itself, right? I remove the Thompson focus coil (the one with centering abilities), replace it with the reversed and rewired 22-11, and possibly rotate the 22-11 around the neck to tweak centering? I want to make sure I'm not getting confused by the apparently equivalent "focus coil," "focus yoke," etc terminology.
antorsae
Posted: Thu Sep 06, 2007 7:46 pm    Post subject:
Yes.
I use focus coil and focus yokes interchangeably. I don't know which one is the correct term.
Joust
Posted: Thu Sep 06, 2007 7:51 pm    Post subject:
antorsae wrote:
Yes.
same same
Joust
Posted: Fri Sep 07, 2007 12:41 am    Post subject:
here is one of Gino's new yoke harnesses.
 Filesize:  52.07 KB
 Viewed:  6960 Time(s)
CZ Eddie
Posted: Fri Sep 07, 2007 1:04 am    Post subject:
I may have an unrelated problem that quietly surfaced during one of my "marquee maintenence" threads. I just haven't had time to chase it down, due to a busy work/personal schedule lately.
And a freakin major lack of decent beater 8500's on the used market... where have they all gone lately?!?!
Page 12 of 37
