Kardesm
| Posted: Sun Dec 19, 2010 9:12 pm Post subject: |
I Dont see the adquisition of other remote as a posibility now, 100 is a lot for my actual budget, and shipping will be an other issue.
I will try to contact the previous owner to see if he has it.
Kardesm
| Posted: Sun Dec 19, 2010 10:40 pm Post subject: |
Just called the Previous Owner, he had no idea of the existance of other remote, He told me that his dad, only used a screen very very close to the projector, because that was the only distance he managed to make it look "right"
So I`m assuming all the setings are set to have a screen close to it ..... Not so good news to me !
Also, I Found the Manuals for this equipment, they are for sale, 6us each, but They sell "Operator" and TechTraining" What should i get?
Alex
| Posted: Mon Dec 20, 2010 12:15 am Post subject: |
THE throw is 1.2 X the width of the screen for these I believe. You can set it up for approx 6' wide to 12' wide image, I'd stick to 6-7' wide. Sounds like the last owner didn't have it set up properly, and just used it the way it came from the owner before that.
Kardesm
| Posted: Mon Dec 20, 2010 12:46 am Post subject: |
Thank you Curt
Yes I think no one knew how to use it but the first owner ehehhe
Ok, I've been playing around with the screws on the lenses, and i managed to get a clear picture, but only on the middle, Is there a way to adjust the shape of the screen with any screws some where? I could live with the letters backwards .... but It's impossible to view the upper and lower areas of the screen.
| Posted: Mon Dec 20, 2010 12:56 am Post subject: |
No, you need to do convergence, with the remote. You're as good as you're going to get right now, but reverse the image with the yoke connectors.
Kardesm
| Posted: Mon Dec 20, 2010 1:01 am Post subject: |
I was looking around in the forums, and i've found this thread
https://www.curtpalme.com/forum_archived/viewtopic.php@t=13456.html
Rogers did what i did, Switched the Jumpers and now everything looks backwards and the screen Warped on the edges.
What are the YOKE connectors ?
Is there a howto on the forum? I've searched "Yoke" but it gave me tooooo many results !!
Thank you again Curt
Kardesm
| Posted: Mon Dec 20, 2010 1:26 am Post subject: |
Ok .... so after reading at the post of the guy that had the same issue as I did .... I asked to the hamster that lives in my head and pretends to be a smart brain .... DUDE If it looks good as a celing mout ..... MAKE IT A CELING MOUNT ....
So I flipped back the DARN Jumpers, and now ... Picture is CRYSTAL CLEAR
I just need to find a way to install it somewhere ...... But Now it Works
Thanks for all the help
Alex
| Posted: Mon Dec 20, 2010 1:35 am Post subject: |
Good call. Yes, the keystone and pin and other adjustments will fall into place when set back to how the set was originally installed.
There are 4 threaded inserts just forward of midpoint. That's where the mounting bracket screws in, and that's where you should hang the projector from.
Kardesm
| Posted: Mon Dec 20, 2010 2:39 pm Post subject: |
Thank you Curt ... I will make the brackets to hang the projector
Alex
