mr_ro_co
Joined: 08 May 2006 Posts: 1643 Location: Santa Fe NM
| Posted: Sat Dec 18, 2010 10:27 pm Post subject: Is this a horizontal deflection or a convergence problem? |
Fired up the set today and this is what I saw. Big glitch on the red in the center of the screen, but all 3 colors are together with a strange geometry deviation in the right bottom corner. I forced both issues back into shape with the convergence, but I'm guessing this is a patch for what's a more serious problem.
Any Marquee users seen this before?
TIA
Steve
| Description: |
| Filesize: |
43.77 KB |
| Viewed: |
6819 Time(s) |
| Description: |
| Filesize: |
23.15 KB |
| Viewed: |
6819 Time(s) |
| Description: |
| note big deviation in center bottom on the red, and all three doing something strange in bottom right corner. |
| Filesize: |
45.84 KB |
| Viewed: |
6819 Time(s) |
_________________ Not only is there no god, try finding a plumber on Sunday!
| Posted: Sat Dec 18, 2010 10:43 pm Post subject: |
Hello
Try unplugging the red convergence yoke, see if that takes the bend out.
dvh99
| Posted: Sat Dec 18, 2010 11:08 pm Post subject: |
dpb, take it off clean the contacts and put back on, clean the contacts on the main clm too, use ethanol.
mr_ro_co
| Posted: Sun Dec 19, 2010 2:01 am Post subject: |
Tim, I would try disconnecting the convergence yoke if I hadn't already made the mistake of dialing this out today via convergence! Dammit, I don't know how I can reverse those steps now. Any ideas?
Athanasios, I'm pretty sure I have the CLM board currently out of the set.
dvh99, what is the "dpb?"
Much thanks,
Steve
dturco
| Posted: Sun Dec 19, 2010 2:08 am Post subject: |
| mr_ro_co wrote: | Tim, I would try disconnecting the convergence yoke if I hadn't already made the mistake of dialing this out today via convergence! Dammit, I don't know how I can reverse those steps now. Any ideas?
Much thanks,
Steve |
Nah if the CLM was out your machine would not work. The DPB is on the CLM.
http://www.curtpalme.com/Marquee_Teardown5.shtm
Can you see that second little board with the screw in it? That's the DPB.
Just thought of this, you don't have you CMM in. {Contrast modulation Module} The machine will run without that.
http://www.hulu.com/firefly
mr_ro_co
| Posted: Sun Dec 19, 2010 2:16 am Post subject: |
| dturco wrote: | | mr_ro_co wrote: | Tim, I would try disconnecting the convergence yoke if I hadn't already made the mistake of dialing this out today via convergence! Dammit, I don't know how I can reverse those steps now. Any ideas?
Much thanks,
Steve |
Just thought of this, you don't have you CMM in. {Contrast modulation Module} The machine will run without that. |
Ah, that's it, the CMM is the one that is out, thanks.
Thanks for the link to that DPB board!
Steve
| Posted: Sun Dec 19, 2010 2:20 am Post subject: |
Much thanks,
Steve |
No way to reverse the steps. Only way is if you saved the settings to your PC vie the Marquee Loader program
from the RS 232 ports. I suggest to everyone to save their settings after each adjustment or set up just incase you do something like this. It could easily be just a corrupt memory. An Initialization might fix it but then you'll loose all settings.
You could save all settings to the Marquee loader program, initialize the set and then reload the settings, it might fix that issue. Even if it still looks off try to converge that area and it might work.
But first do as Tim said and pull the red's convergence cable from the Convergence Amp and fire it up, if the bend is gone then you may have a bad CVA ,if its still there try my idea and see if its s till there or can be adjusted out. If not then it is a bad CLM.
dturco
| Posted: Sun Dec 19, 2010 2:25 am Post subject: |
I'm hesitent to say this but... you can go into the menu 9, 0910, and go to diagnostics where it gives an option to see the last 25? key presses. I think.
I don't know if you can undo anything from there, but maybe.
But even then you might hose everything and need a complete initialization anyway.
mr_ro_co
| Posted: Sun Dec 19, 2010 2:51 am Post subject: |
| Nashou66 wrote: | | mr_ro_co wrote: | Tim, I would try disconnecting the convergence yoke if I hadn't already made the mistake of dialing this out today via convergence! Dammit, I don't know how I can reverse those steps now. Any ideas?
Much thanks,
Steve |
Athanasios |
That is a very cool feature, the Marquee Loader program. I am very interested in that for troubleshooting benefit in particular.
If I understand you correctly, I can still disconnect the convergence cable and see if there is any bend in that region, but what about the bottom right corner, where the funny geometry distortion was, with all three colors converged?
Thanks!
Steve
mr_ro_co
| Posted: Sun Dec 19, 2010 2:52 am Post subject: |
| dturco wrote: | I'm hesitent to say this but... you can go into the menu 9, 0910, and go to diagnostics where it gives an option to see the last 25? key presses. I think.
But even then you might hose everything and need a complete initialization anyway. |
Okay, I'll see what there is to see.
Steve
| Posted: Sun Dec 19, 2010 3:21 am Post subject: |
Hi Steve, I think an initialization might fix this problem, lets hope.
The marquee Program is located on VDC's web site.
here is a direct link:
http://vdcds.com/utilities/Marquee23.zip
It has the loader program separate and also a controller Program where you can save the settings from there as well.
I like to use this program when doing greyscale, the menus do not come up on the screen . So the G2 and drive menu boxes will not contaminate the readings. you can also do convergence and Zone contrast, all geometry etc. However i think some functions depend on the software version your PJ has, so you might have to play around to see what controls you have.
JustGreg
| Posted: Sun Dec 19, 2010 7:35 am Post subject: |
I had the same issue once on my 8500, the same tube too. After a thorough cleaning of chips, sockets, card edges, etc. it went away.
You'll need to do a full reinit to recreate the problem but saving your current setup and restoring it later after it's fixed will shorten the recovery (setup) time considerably.
_________________ Greg
mr_ro_co
| Posted: Sun Dec 19, 2010 3:18 pm Post subject: |
| Nashou66 wrote: | Hi Steve, I think an initialization might fix this problem, lets hope.
Athanasios |
Very cool. I downloaded it and will see if I can try it out today.
Thanks!
Steve
mr_ro_co
| Posted: Sun Dec 19, 2010 3:23 pm Post subject: |
| JustGreg wrote: | I had the same issue once on my 8500, the same tube too. After a thorough cleaning of chips, sockets, card edges, etc. it went away.
You'll need to do a full reinit to recreate the problem but saving your current setup and restoring it later after it's fixed will shorten the recovery (setup) time considerably. |
I suspect something has worked its way loose and needs to be cleaned and reseated as you say. It's unfortunate, but my 1400 RPM front loader washer resided directly above where my projector is hung, and some days the projector really gets shaken good (don't worry, I've got a bomb proof mount). So it would make sense that something needs to be reseated.
I'm pretty excited about using loader program.
Steve
dvh99
| Posted: Sun Dec 19, 2010 3:46 pm Post subject: |
just clean those contacts its a 5 minute thing, why the delay?
mr_ro_co
| Posted: Sun Dec 19, 2010 4:53 pm Post subject: |
| dvh99 wrote: | | just clean those contacts its a 5 minute thing, why the delay? |
I was just about to ask you, why can't I use isopropyl alcohol to clean the contacts? You said to use ethanol specifically. I don't have any on hand, I'd have to go to the paint store. Would denatured (5% methyl) ethanol be okay on PC board contacts? I used to use anhydrous isopropyl (made specifically for elecronics), but I don't have any of that either.
Steve
dvh99
| Posted: Sun Dec 19, 2010 5:05 pm Post subject: |
i am very sorry for the confusing, you can use ipa of course.
its just that the oxidation layer has to come off so use plenty of it and let it dry for 15 minutes before reinstalling.
hope that will solve the problem.
i had a similair problem on the top of my picture and it was solved simply by cleaning the contacts on the dpb and clm.
have you changed out those connectors btw, just curious?
mr_ro_co
| Posted: Sun Dec 19, 2010 5:22 pm Post subject: |
| dvh99 wrote: | i am very sorry for the confusing, you can use ipa of course.
have you changed out those connectors btw, just curious? |
Okay, cool. I've got isopropyl on hand. Will clean those contacts and see what happens.
You are talking about the connectors on the VIM? Not yet - got the info saved, though, thanks for that. I'm waiting for a modified VIM to show up before I do that change on both my VIMs.
Steve
dvh99
| Posted: Sun Dec 19, 2010 5:29 pm Post subject: |
yes the vim and the vnb, or do you want to keep the mini rca on the vnb?
