_in_peace_
| Posted: Tue Dec 14, 2010 7:17 pm Post subject: ASTIG on a tv |
Hi! is there easy to do astig on a Sony Trinitron 100hz 29"?
The red color is a little bit of on the left side
| Posted: Tue Dec 14, 2010 8:39 pm Post subject: |
The set doesn't need astig, it probably needs degaussing. the Degaussing thermistors die often on those Sonys.
I'd go talk to the local TV repair store to see if you can rent their degaussing tool... if they still have one.
_in_peace_
| Posted: Tue Dec 14, 2010 9:21 pm Post subject: |
oh sorry! i meant to align the thee colors over each other
_in_peace_
| Posted: Sat Dec 18, 2010 1:16 am Post subject: |
is it worth opening it? may i find the screws for the red color? (zone adjustment)
| Posted: Sat Dec 18, 2010 1:30 am Post subject: |
On the Sonys they are all done on the yoke/neck of the tube with magnets. That's the Trinitron design. No convergence board in those sets.
_in_peace_
| Posted: Tue Feb 15, 2011 12:16 am Post subject: |
Is there any way to adjust the screen size in those?
its about 10% out of the frame (in height) when feeding with RGB
| Posted: Tue Feb 15, 2011 1:17 am Post subject: |
Where's Macgyver to answer this one?
_in_peace_
| Posted: Tue Feb 15, 2011 10:58 am Post subject: |
hehe
| Posted: Tue Feb 15, 2011 2:53 pm Post subject: |
I need a model number.
_in_peace_
| Posted: Tue Feb 15, 2011 5:02 pm Post subject: |
Okay it's a Sony KV-29X2E
Screenshot of pure scan lines in 220p! As you can se the screen size is a little bit of (to narrow and to high)
| Posted: Tue Feb 15, 2011 5:18 pm Post subject: |
Do you have the original remote?
_in_peace_
| Posted: Tue Feb 15, 2011 5:26 pm Post subject: |
To bad not, i have a Remotec multi remote
| Posted: Tue Feb 15, 2011 5:30 pm Post subject: |
Then you may be SOL. Does that remote have a display button and if it does, does it function on the tv?
_in_peace_
| Posted: Tue Feb 15, 2011 5:45 pm Post subject: |
I can do a lot in the menu. "leaning the image" is the closest that i find to size adjustments in the meny
| Posted: Tue Feb 15, 2011 5:59 pm Post subject: |
Thats not what I meant. The adjustments your looking for are in the service menu. But you need the original remote to get into the service menu. Sometimes an aftermarket remote will work if it has similar working buttons. And one that is needed is the display button.
A Rogers
| Posted: Tue Feb 15, 2011 6:08 pm Post subject: |
| macgyver655 wrote: | | Thats not what I meant. The adjustments your looking for are in the service menu. But you need the original remote to get into the service menu. Sometimes an aftermarket remote will work if it has similar working buttons. And one that is needed is the display button. |
I've had luck using aftermarket remotes to enter service mode on newer(relative) XBRs. That said, this guide was helpful to be prior to the death of my sony.
http://myweb.accessus.net/~090/sonyadj.html
_in_peace_
| Posted: Tue Feb 15, 2011 6:45 pm Post subject: |
Aha ok. It's like this then:
[PWR OFF] - [DISP], [5], [VOL+], [PWR ON]
-or-
[PWR OFF] - [DISP], [5], [PWR ON]
But i can't figure out wich [DISP] - botton will be on this remote. Perhaps thats the one who is missing.. By the way the TV starts up on [ 5 ]
| Posted: Tue Feb 15, 2011 6:48 pm Post subject: |
disp is for display. Do you have a button that when you push it the on screen display comes up? Not the menu.
_in_peace_
| Posted: Tue Feb 15, 2011 7:06 pm Post subject: |
I think so, the channel in green comes up.
I tried it but it seems not to work
| Posted: Tue Feb 15, 2011 7:30 pm Post subject: |
If it is correct, this is the sequence for your model.
With the tv in standby, press: display, 5, volume +, tv(or power maybe) and the tv should turn on and it should have TT in the upper right corner.
You can try different buttons for "display" and/or "tv" until you get the TT.
