comparison between 9500lc and Epson dlp 8350 projector
dvh99
Posted: Tue Nov 30, 2010 8:02 pm    Post subject:
dturco wrote:
dvh99 wrote:
problem with blending is that its best that the 2 pjs are identical.
where are you gonna get another set of pt22 tubes or 2 sets of lcps (that would be my choice) and lets not forget the blending hardware and of course the upgraded vim and neckboards for the 2nd pj which makes the blending not so attractive costwise.
Minor details. Small potatoes.
Don't pee on my parade yet.... you just never know what can be found out there Wink
http://www.imdb.com/title/tt0751205/
very funny episode of the x files Mr. Green
donaldk
Posted: Sat Dec 04, 2010 4:41 am    Post subject:
CRT. BIG HEAVY GOOD! Thumbs Up
Yeah, and Barco still rulez the 100 Kg+ category. Though those split pack 30K Roadies are not to be sneezed at either.
If we keep comparing top of the roost projectors, CRT hasn't any real advantages anymore, with 'Digitals' contrast now specced at over 10 million to one by the folks down south (that would be Belgium;-)). And the Zeiss digital has better blacks than any CRT planetariums put in in the past.
Now hope you get lucky and find a free big boy projector;-).
donaldk
Posted: Sat Dec 04, 2010 4:49 am    Post subject:
Well we got to leak somewhere now our local wateringhole has been down for the week, and there being no sign of it getting back online. drip, drip...
Mr. Green
Posted: Sat Dec 04, 2010 8:46 am    Post subject:
Well, I can't remember which Epson it was (1080p - 8200 or something), but I put it up against my NEC 9PG+. The Epson within 5 minutes was sharper and brighter, but (IMHO) the image wasn't as film like (probably because it was razor sharp and since we weren't using too much CGI for reference, it seemed fake).
Having said that, my Marquee 9501lc is way better than the PG+. I think the pg+ was probably able to be sharper with the colored lenses it had, but the picture quality (especially the scanlines at 1080i on the PG+ vs. 1080p & no scanlines on the 9501) makes a huge difference. You are talking entry level CRT vs. top end. I did the jump from barely medium to high end CRT and the difference is staggering (not to mention the marquee is 25 times easier to set up than the nec). I'd also like to mention that the friend with that digital has changed bulbs once in the 2 yrs he's had it and bulb # 2 is already noticably more dim after 590 hrs. He still says he couldn't take the time I did to set up and maintain a CRT, but he's pretty annoyed with his bulbs.
Honestly, New, out of box digitals are close if not on par for the most part with decent CRT from the ones I've seen, which has been quite a few.
You simply need to decide if you want your projector to be a hobby or "plug-n-play". If you are tired of tweaking, go digital.
My personal opinion is if you got the marquee, you'll have a projector that will make you happy until digitals- either LED or Laser that will last as long as CRT are the norm and have a reasonable lifespan. I personally wouldn't bother with a bulb digital. 2 of 3 people I know with $2000-$3000 digitals are thinking about the next upgrade after only 2 years. IMHO- That is a waste of $$. I'd rather tweak a marquee and get 5-10 yrs out of it myself. Having said that every time (like right now) when it breaks down, I wish it wasn't as high maintenance... then it gets fixed and the world is right again.
It's a tough call that only you can make in the end. I still think digital needs a few more years to perfect itself. I'd try to talk the marquee guy down. If you decide to go digital, PM Dave (Dturco) the sellers info. He looks like he wants to play with a blender. Wink
PS: Another few final notes, I find spending that kind of money on something that is disposable (either impossible, hard or expensive to repair) a waste of $$. The marquee (with exception of tubes) can be repaired for a couple hundred $$. Curt has parts to swap or can fix yours and return it (or less $ if you have the bean bag to try repairs yourself as many on this forum do). Try that with a current digital. I do feel that once they replace bulbs with something less hot and longer lived, CRT will really be only for the true die-hard extremists. I personally think were still 3-5 years off having a digital that will draw all but the most serious CRT-ers. If you are willing to put some work into a CRT you'll have a sense of pride that you can't get from plug-n-play digitals. It might not be the sharpest or brightest, but I still wow people with the old beast, especially anything like the BR - LOTR that has great cinematics. When the picture goes dark, so does the room... sorry, I WAS trying to be neutral and as far as maintenance/setup I am, but I still haven't found a sub $5k CDN digital that I'd be willing to take my marquee down for. If it has a bulb, I'm not biting.
Hope that helps. Wink
Posted: Sat Dec 04, 2010 11:26 am    Post subject:
Spanky Ham wrote:
Speak for yourself, Curtie! Mr. Green
To add to what Curt said and I have mentioned it numerous times, CRT wins in on/off cr and motion resolution. If those don't matter to you then go digital. The Epson is LCD and I would spend teh extra money to get the LCOS pjs.
One thing that doesn't get enough exposure is motion resolution. I don't understand why this doesn't bother people. I was watching my dlp tonight and kept thinking - Wow, how do people not see the lack of motion resolution?.
I would amend those to say 'if those don't matter to you or you cannot afford a well setup 9500LC then ...
The unit Curt has is $7500 and that is by no means in the same $ market as the Epson 8350. FYI, its LCD not DLP. Epic fail to the poster for not even knowing the difference. Mr. Green
BTW, comparing a $1300 new disposable to a $7500 used industrial-grade product is silly.
donaldk
Posted: Sat Dec 04, 2010 6:02 pm    Post subject:
AT the lower end the long lifetime has already arrived, with the LG HS201 nd its replacement the HX300 LED units.
TheVerge
Posted: Sat Dec 04, 2010 8:53 pm    Post subject:
Gone round and round with people about this, just because the light lasts for 30,000 hours doesn't mean the rest of the unit will. What is the 201 like, 400 bucks. I'm sure it's full of high quality electronics.
Also, we are all figuring out that LEDs don't last near as long as people think(aquarium people already know this)
donaldk
Posted: Sat Dec 04, 2010 11:06 pm    Post subject:
Yes, I did catch that busted led posts in one of the LG LED threads over at AVS, his problem was lacking/delayed local availability drove him to order from Asia, so LG USA wouldn't honor any warranty, and the thing was too cheap for him to ship it back and forth.
The Casio Hybrids on the other hand offer 3 year warranties (or 6000 hours), so that's a plus.
BTW, the LEDs themselves are generally specced up to 100,000 hours (for the PT 120/120, don't care too re-check the PT-54 spec), so half the 30K spec for the hs201 should be attainable, the 300 drives the same LEDs harder, so its spec is limited to 20K hours. 10-15K hours still should provide comparitavely good value, as even a 300$/€ budget LCD projector plus one lamp would be as or more expensive.
If you wan't something that doesn't draw too much power because the kids leave it on all day, or are drilled to switch off lights and TVs when they leave the room, you want to look into an LED, as that way you don't burn bulbs like crazy. If you want a good 1080P image for limited money, for HT use, get the Epson TW2900, while it lasts, it has been clearing for under €900, for a while now, but the 3200 is still not available locally (most likely exactly the same machine as the upcoming 3600, except considerably cheaper, as was the 2900 to the 3500, as the 3600 measured the same as the 2900). The US/Canadian version, 8350, is well received over at AVS.
skypuppy
Posted: Mon Dec 06, 2010 7:18 am    Post subject:
On the crt's, have the <censored> <censored> <censored> channel bugs caused any <censored> burn-ins?
What mankind needs is a manned mission to Mars.
Born free. Legislated to death.
benareeno
Posted: Mon Dec 06, 2010 8:15 pm    Post subject:
pure image quality is a wash...digital does some things better, and some things worse.
Practicality is so far tilted in favor of the digital, that's it's not even a debate.
TheVerge
Posted: Mon Dec 06, 2010 9:07 pm    Post subject:
But what is the light output at 100,000 hours? 90% maybe 40%... how about 2%. Do they state that?
Posted: Mon Dec 06, 2010 9:09 pm    Post subject:
Not picking on any one but who ever thinks eventually digital chassis will ever last as long as a CRT's chassis is not understanding the new business model of these large consumer companies. They purposely make their products to fail after a certain length of time. This way those who missed out on the latest greatest by a month because they just bought their new tv can get the latest greatest when thier current one fails. Before it was after 15 years or so, now this cycle happens every 3-5 years.
I like things to last. And now the saying you get what you pay for no longer has any merit in CE.
So i'll pay for a re tube before a new Digital is in my theater. Well, that could be a long time considering all the spares i have Smile I might be dead before then Wink
Posted: Mon Dec 06, 2010 9:48 pm    Post subject:
I hope VDC doesn't make their digitals to fail after a certain period of time.Smile
