3D... It's working :)
Goto page Previous  1, 2, 3, 4, 5 ... 16, 17, 18  Next
David_Web
Posted: Wed Sep 29, 2010 8:55 pm    Post subject:
Stool sample? Laughing
*edit* aargh too bad it got on a new page. Oh well.
Posted: Fri Oct 01, 2010 4:04 am    Post subject:
I had to go to sears to get a couple new tires so I had 45 minutes to browse at a couple 3D models for the first time. I looked at a Sony and samsung with LED back lights. I liked the Sony best..
Being the first time I've seen 3D I was a bit surprised at how well it could work sometimes ! Shocked
It would be fun to see it on an 8ft screen ! Smile
Posted: Fri Oct 01, 2010 4:13 am    Post subject:
I'll be interested to see what other people think, but after seeing a LOT of 3D setups at CEDIA, I'm pretty convinced that while 3D is pretty fun on a nice bright direct-view set like a LED-lit LCD, 3D on front projection just leaves me pretty disinterested. The brightness just isn't there to begin with, and putting the glasses on really kills both color and contrast. The picture just loses a whole bunch of its life.
If I look over the top of the glasses while I'm watching 3D, it makes me think, "Yeah, there's the picture I want to see!" (minus the double-image of course). Even with the giant Barco and DPI machines that were probably cranking out 20+fL, I just wasn't crazy about the picture compared to with the glasses off... Unfortunately, that means 3D on CRT will be even less interesting to me given how dim it is to begin with.
I don't mean to be a buzz-kill... I'll be continuing to watch this thread because I'm interested... I'm just not very optimistic.
Posted: Fri Oct 01, 2010 12:58 pm    Post subject:
Not a buzz-kill SC, you just speak reality. These are all good points.
However, hear me out on this. This is FACT: Show a human two identically calibrated monitors sitting next to each other with ONLY one difference between them. One monitor has a higher white level (brighter) picture than the other. Next ask the person to pick which has a "better" picture. The person will ALWAYS choose the brighter monitor even though both are perfectly calibrated.
Now take the same experiment, but place the two monitors behind curtains. Open the curtains in front of either monitor first and let the person watch for five minutes a demo. Close the curtain. Wait about one minute and open the other curtain in front of the other monitor and show the same demo. Now ask, "which monitor has a better picture?" The answer will be 50/50 for either monitor.
The human eye is draw towards a brighter picture and we think brighter by comparison is better. However our eye has no memory for brightness and without comparison the brightness does not effect our perception of the image.
I find this all the time when I calibrate. Lets take a 96"x54" screen that is white with a 1.3 gain for the following. On a G90 I can usually get around 13 flt and that is what I am used to because I see it every day. With a Sim2 C3 I get about 40 flt. On an NEC XG I get around 7 flt. On a Marquee 9500LC ultra I get around 9 flt, and on an RS20 I get around 7.5 flt. And at the end of the day, when I am in the client's home working on the projector they all appear to me to have the same brightness pretty much. (Exceptions are ultra bright and very dim projectors TITAN verses D50 80 flt versus 4.5 flt).
In any event, it's not a fair experiment for you to peer over the glasses and check the brightness in comparison to the 3D through the glasses. When you do this, you reset your brain and the brighter image becomes a reference of comparison. At that point you WILL be disappointed with the brightness of the 3D through the glasses. I can do the same thing to myself and my clients projectors if I crank up the white level, watch for two minutes, and then turn the white level back down to the calibrated level. Immediately after turning the white level back down to where it should be I am disappointed with the picture. But five minutes later it looks good again after I re-acclimate to the correct white level.
If you want to get a good perspective on how you will actually perceive the 3D you need to look through the glasses the entire time and not make a comparison between white level with the glasses on and off. You have to just watch the image and allow your brain to get used to the dynamic range of the image on the projector.
There is of course a threshold and it can get too dim, but as long as your projector is above that it should look good once you watch it for a few minutes with the glasses on.
Oh yeah, there are also calibration techniques being developed now so that we can do a setup with the meter looking through the glasses to get everything back where it should be. I don't think the calibration for 3D will ever be as good as without the glasses, but it is getting better with better techniques.
virusc
Posted: Fri Oct 01, 2010 5:43 pm    Post subject:
This might have been already asked but would it be possible to use 2 CRT projectors for 3d with one of those new 3D processors made to use duel projectors? What refresh do they work on, 60hz?
Posted: Sat Oct 02, 2010 12:48 am    Post subject:
CIR Engineering wrote:
overclkr wrote:
Craig,
Since I'm upgrading my system soon it would be nice to add 3D capability to it as well. What resolution are you running at 96hz? Are you able to get 120hz working?
Cliff
However, as I look at 3D on my G90 now, I see very little difference in flicker with 96Hz compared to 120Hz. So right now with the little testing I have done I am leaning towards 96Hz as the best option. 120Hz will also be dimmer because the shutter glasses will be closed slightly longer blocking more light. 120Hz will also have more ghosting problems than 96Hz due to phosphor decay rates.
I would like to see 3D on your G90 stack sometime Cliff. With two G90 projectors 3D should look really nice. I am tempted to throw another G90 on the ceiling here (but I swore I would never run a CRT stack or blend in my own setup). Another nice option for a stack or blend is that you could reduce the contrast setting to reduce ghosting problems. The lower the white level the less ghosting we should see.
96hz sounds just fine to me Craig. I'm looking foward to seeing the results! Looks like my VP50 is gonna have to take a dump this year huh? Very Happy
After seeing this in IMAX, I cant WAIT to see it on the stack. Too Cool. I'm sure it will wear off after a while, but why not? Thumbs Up
Damn, I forgot about my Dallas chips too. LOL I'm still on the originals! I'll tell ya though, the only real failure I have had was that DF board. These twins have been EXTREMELY reliable (knock on wood).
Cliff
Posted: Sat Oct 02, 2010 1:15 pm    Post subject:
I just saw 3-D for the first time at BB. Quite frankly was not that impressed. I would not be jumping through hoops to see it on a crt projector. I might be tempted to buy a pair of cheapo glasses and try it on a 3-D ready flat screen.
If you don't already have the equipment that will support it, I think you will be sorry you spent the extra cash to try it.
Posted: Sat Oct 02, 2010 8:00 pm    Post subject:
Cliff
I started looking at 96Hz versus 120Hz yesterday and I think 120Hz is actually a little better. 120Hz has virtually no flicker while with 96 Hz flicker is just barely perceptible. With the Radaicne PLUS we should even be able to run 720p 144Hz to avoid 3:2 pulldown like with 96Hz, so my new goal will be 144Hz on the PLUS models.
You should have dumped that VP50 before you got it... those things are pieces of...
If you want me to do you Dallas chips let me know ASAP because I am ordering more on Monday. I have a line on the newer chips. I got a batch or the older ones several months back and every one had a dead backup battery and I had to trash them all Twisted Evil
Posted: Sat Oct 02, 2010 8:01 pm    Post subject:
Now that's what I call pissing on the parade Confused
Posted: Sat Oct 02, 2010 8:06 pm    Post subject:
Lumagen plans to support dual projector 3D with each projector being fed by the dual outputs of the Radiance. However, for CRT this won't really help in terms of bandwidth. You will still need to run both projectors at the high refresh rate above 96Hz. This is because both projectors will need to stay in sync with the video. It's just that one frame for the left eye will be sent to the left projector and the frame for the right eye will be sent to the right projector. When the projector is not being used for its given eye, it will show a black screen for that frame. But it will still have to be running 96Hz+ to stay in sync.
The only way to increase the resolution would be with a blend CRT setup... just like with 2D.
The two projector idea is for a polarized screen with polarized glasses that don't need LCD shutters.
Posted: Sat Oct 02, 2010 11:14 pm    Post subject:
I just got off the phone with Jim Peterson of Lumagen. He wanted to discuss wiring options for the IR transmitter output on the Radiance processors to drive 3D glasses for CRT. It is starting to look like all existing Radiance processors will all support 3D shutter glasses outputs. Earlier, Lumagen though shutter glasses support was going to be for the XE and XD only, but Jim is considering adding support for the XS as well. When and if this is released, you will ship your processor back to Lumagen and they will add a plug (probably 3-pin mini-din VESA) for direct tie into 3D glasses that use TTL. This will support industry standard 3D IR transmitters.
There is a bigger demand for CRT 3D support than Lumagen initially expected. European and Asian dealers are all chiming in for 3D CRT support so this may push use closer to the top of the queue than I had hoped Smile
Initial CRT 3D release will probably support 3D bluray only and with a 96Hz 720p output to the projector. Later we can expect 120Hz 720p, support for side-by-side 3D input signals, support for frame stacked like Comcast and DTV (have you seen 3D football yet it is cool), 144Hz 720p for the PLUS models to avoid 3:2 pulldown, and even customizable output resolutions at 96Hz, 120Hz, and 144Hz.
Posted: Sat Oct 02, 2010 11:17 pm    Post subject:
Sorry you feel that way. It was not my intension.
You are bringing this subject up in a forum that thrives at "keeping up with the Jonse's" at any cost and buy things solely based on anticipation.
I'd just like them to think twice before they put that new video processor on their credit card.
Back to my observation at BB. The display had a A/B switch. Regular HD was nice, bright and sharp. 3-D was dim (quite dim) by comparison and did not seem to be at as high a resolution as std HD. If that percentage of decrease in contrast
and sharpness follows over to CRT projection, I would not find it enjoyable to watch.
Also Craig, have no fear, no one listens to me anyway. Sad
Posted: Sun Oct 03, 2010 12:09 am    Post subject:
No problem. I was actually kinda referencing SC's post from the other day when he said he "didn't want to piss on my parade but..."
My response to that is above somewhere.
Posted: Sun Oct 03, 2010 12:17 am    Post subject:
the_maniac wrote:
edit: found one version here http://www.int03.co.uk/crema/hardware/stereo/
I built this circuit yesterday to test it and it works perfectly to supply the 50% duty cycle TTL for smart glasses and IR transmitter. I would suggest adding a 47 uf cap across the +5 rail. Be sure to use a fuse if you want to get five volts off the projector. I connected it to a regular VESA plug IR transmitter like the ones on eBay item number 160431950220 works well. You can use a PC with a VGA port and watch 3D samples downloaded from the web. They don't look anywhere close to bluray, but you can see 3D.
Frank D
Posted: Sun Oct 03, 2010 1:35 am    Post subject:
Things appear to be moving well for CRT 3D.
Exiting stuff! Thumbs Up
mhalsan
Posted: Tue Oct 05, 2010 4:30 am    Post subject:
Responding to virusc:
I've got a passive-polarized setup, and it works very well- once everything is set up. Matching two CRT projectors is very time-consuming!!!!
The gamer crowd has been doing this for at least several years with digitals (see mtbs3d.com and others). I tried Nvidia's 3DVision last February and found the ghosting and dim picture to be a disappointment.
I use polarizing filters and glasses from Berezin, Harkness' Spectral240 3D screen, and IZ3D's driver, the license for which they charge $50. Yes, that limits me to PC, however that really hasn't been a problem- probably 80% of my theater time is gaming anyway. Refresh rate is 60Hz. There is a selection of alternate-field DVDs available, and various 3D trailers; these work fine as-is, although the resolution of the alternate-field method is poor.
As for 3D Blu-Ray, IZ3D has promised compatibility in their next driver update (believe it when you see it). I'm also watching to see what Lumagen does; as mentioned above, they may support this method. Also, Doremi Labs has a 3D format converter that is HDMI 1.4 / frame-packing compatible. This converter is apparently available only to the professional market, although that obstacle can often be overcome. It uses HD-SDI for left and right outputs, so a pair of SDI to HDMI converters would be needed.
Thanks, Mark
Sigh. We are getting aggravated (yes, we are....)
Posted: Tue Oct 05, 2010 9:52 am    Post subject:
Thanks, Mark
Well now, that is the right way to do it. Passive-polarized is top end for sure and you get around the resolution limitations imposed onto single CRT when using the shutter glasses method. You make what I am doing look like child's play Smile I'd love to see the rig sometime if you are willing?
3D Bluray is really a whole nother level though so I hope IZ3D winds up providing support for you. The Lumagen Radiance may help you as you have noted, but dual projector support is the last configuration that they plan to work out if they ever even get to do it. I don't think Lumagen has gotten too many requests for this feature. However, they are still planning to add in dual projector support at this time.
mhalsan
Posted: Sun Oct 10, 2010 5:16 am    Post subject:
Craigr- thanks for the compliment- I appreciate it! If you're going to be in NW Oregon let me know.
I'm still dissatisfied with light output, which is diminished by the polarizing filters and glasses. However, the ghosting problem is absolutely gone.
I'll be watching what Lumagen and IZ3D do on blu-ray support- and there's a chance neither will happen. In that unfortunate case- moving to digital w/shutterglasses would be the path forward. Speaking of which- the press releases for 3D Digital projectors have the comment that screen size will be limited to 100". What knucklehead made that decision? This is surely false.
Thanks, Mark
David_Web
Posted: Sun Oct 10, 2010 8:06 am    Post subject:
I guess the problem now is finding good quality glasses that is not expensive.
Ill probably never go the VP route as I tie in exclusively with a HTPC. Have you thought about a kit with ether glasses or glasses + sync thingie?
I am more and more happy that I am going to run a 1.5m wide screen. For an 8" Marquee I should still be able to get an OK picture.
BTW have you looked at the Teensy? http://www.pjrc.com/teensy/index.html
Might be hard doing any advanced sync circuit for cheaper. And you can use it for anything else.
If you want it might even be possible to tie it in with the computer to tap sync directly (or get eye order reliably)
It does support both USB and RS232.
Posted: Sun Oct 10, 2010 12:29 pm    Post subject:
Thanks, Mark
I get up your way every now and then. You'll probably hear from me in the future for a demo request Wink
It looks like a 99.99% chance that Lumagne will be successful with CRT 3D at this point. Digital projection 3D beta releases should be available in less than two weeks. CRT beta 3D releases may become available before December.
I have not seen anything regarding a max screen size on 3D digital. I know the bluray players I have here allowed me to type in 100" for my screen size with no trouble.
Page 4 of 18
