3D... It's working :)
Goto page Previous  1, 2, 3 ... , 16, 17, 18  Next
cinema mad
Posted: Thu Jun 02, 2011 1:35 pm    Post subject:
mhalsan
Thanks for sharing your experience sound awesome, Id be real interested to know what the Cypress kit is worth & which
Polarized Filters from Berezin you went with..
Are you sending 1080p@60Hz to each 9500 for 3D viewing or some other rez/timing & are you running the Moome V2 full-HD internal
cards..
Thanks..
Posted: Thu Jun 02, 2011 2:32 pm    Post subject:
mhalsan wrote:
UPDATE: I received the Cypress components. The set consists of an HDMI splitter, and a pair of converters, one for left, one for right. Setup took less than an hour; no HDMI problems, and the Oppo BDP-93 recognized the devices properly. Watched Coraline and Shrek Forever After; the system works just like it should. No ghosting, lightweight glasses, and a fairly bright, immersive 3D picture.
I realize that not many people are interested in doing 3D this way, but- it does work, and pretty well! Frankly, the hard work was done last year, setting up and matching two projectors. That took longer than I would have guessed.
Thanks, Mark
Mark, that is very cool!!!
What polarized lenses did you use over the projector lenses?
mhalsan
Posted: Thu Jun 02, 2011 7:39 pm    Post subject:
The polarizing filters over the CRT lenses are 6" x 6", with 45/-45 degree polarization, and good glasses to match. See this page, about 2/3 of the way down:
http://www.berezin.com/3d/3dglasses.htm
I'm using a Harkness-Hall Spectral240 "silver" screen; a regular white screen won't work with polarized 3D setups. Yes, it "hot-spots." I'm using a large, flat screen with short-throw lenses. Using the "contrast modulation" boards helped this to a large degree, but if you put up a uniform white field- it's there. I don't consider it noticeable during regular use.
The Cypress boxes take the 3D frame-packed output from the blu-ray player at 24fps. You'll need a 1-in/2-out HDMI splitter to drive both 3D boxes. They output 1080p/60Hz to both projectors via Moome VIM-FullHD cards. Including the splitter, the pair of 3D boxes, and international shipping, figure around $550
During the conversion process, the frame rate is converted from 24 to 60Hz. What we need, but don't have, is a test disc with 3D-enabled to check for this. I have noticed rare and fleeting motion artifacts during scenes with high contrast and quick motion, probably because the left and right images are being reconstituted by independent processors, which may perform the file-to-video "pull-up" slightly differently.
Since my Oppo BDP-93 has two HDMI 1.4 outputs, I figured I'd skip the splitter- unfortunately, there's a slight delay through my audio processor that translated to one projector being 1 frame behind the other. I was better off using one port and a splitter for video, and the second port to the audio processor just for audio.
Thanks, Mark
Sigh. We are getting aggravated (yes, we are....)
cinema mad
Posted: Fri Jun 03, 2011 6:12 am    Post subject:
Thanks for providing other interested forum members your passive 3D project Mark,
Just wondering How you went about mounting your polarized filters infront of your lenses, I was thinking of some type of stand similar to the ones shown on the link you provided making for easy removal for 2D viewing ..
I may just give this a try since the financial outlay after having much of the hardware isn't significant so not A huge financial risk for me if I dont like it Shocked ..
BTW I spoke to Chris Bailey and he said that there is A delay on these units & that you have the only one Smile..
My screen is A Stewarts Lux deluxe with G1 Studio Tek 130 surface which I noted on AVS screens for 3D thread that it scores 4 in the Polarization rating so hoping while no doubt A compromize will be acceptable for passive 3D as 2D is my prefered primary concern as far as pic quality..
Jase..
mhalsan
Posted: Fri Jun 03, 2011 8:03 am    Post subject:
I built my own brackets for the polarizing filters that hinge out of the way for 2D viewing. Just a simple, home-made aluminum frame painted black. Berezin's stands are more professionally-done, but it looks like they're designed for a pair of single lens digital projectors.
I posted a couple pictures of the polarizers under "photo albums > mhalsan"
As far as screens go, I never tried polarized 3D on a white screen. While I was building the second 9500, I was also on the waiting list for Harkness' Spectral240 screen. The timing worked out just right and everything got put together about the same time. A white screen will provide better 2D picture performance, but I'm not sure how much of a 3D effect will remain, if the screen doesn't retain light polarization to a high degree.
Thanks, Mark
Posted: Mon Jun 06, 2011 4:49 pm    Post subject:
Check this out!
http://www.curtpalme.com/forum/viewtopic.php?p=307899#307899
Began
Posted: Mon Jun 13, 2011 2:14 am    Post subject:
HI Craigr,
Need some of your advise. I manage to get 3D out of my G70 @ 720p120hz but find the picture abit soft.
Can I do 3D at 1080i/120hz or any other resolutions to make the picture sharper.
Thanks, BTW 3D on CRT rock.
Began
Posted: Mon Jun 13, 2011 6:43 am    Post subject:
Began wrote:
HI Craigr,
Began
Interlaced 3D output is not supported.
Why are you running 120Hz? This is not needed by most people really. Firstly if you do not need 120 Hz drop down to 96Hz. Also yes, most progressive resolutions are supported. You could try as low a resolution as 540x960p at 96Hz / 120Hz, or 96Hz / 100Hz in Europe. I am sure the G70 would do 540x960p 120Hz with ease, but how is the brightness on the G70?
Also, with 540p you should still have at least 500 Vertical blanking lines if possible on the G70. So you would run 1040xsomething with 540 active Vpixels.
Began
Posted: Mon Jun 13, 2011 7:00 am    Post subject:
Hi Craigr,
On G70 I have to set Contrast to 90 and brightness 80 to have a reasonable picture.
OK will try other resolutions.
Cheers
Began
Posted: Mon Jun 13, 2011 7:05 am    Post subject:
Began wrote:
Hi Craigr,
Cheers
Began
But it looks reasonably bright enough?
I don't think the actual settings in the menu make much difference as long as you are not stressing the tubes and ripping through your phosphor life. The G70 in general, and depending on FW version, ABG, gain/bias can have a very wide range of required brightness and contrast settings from projector to projector...
wildchild22
Posted: Mon Jun 13, 2011 3:52 pm    Post subject:
Is 720p@96hz better for eliminating ghosting on the bottom of the screen?
I do not think 3d is possible without a radiance.
I have tried adjustable rf glasses monstervision and I can move the blue band from the top of the image out of view but then the bototm of the screen the ghosting is bad. I have a feeling I need to alter timings and the radiance is the only thing that can do that.
I am running 1280x720p@120hz at the moment on a necxg1352lc.
Posted: Mon Jun 13, 2011 11:24 pm    Post subject:
Yes 96hz is much better (ghosting) and as well the Radiance even after setting 96hz allows you to adjust the timings on the glasses to eliminate the blue band. Cool
Now if we could just upgrade our projectors to accept 1080P/96hz that would be awesome! Where is Mike Parker when you need him? Mr. Green
pezzettino
Posted: Thu Jun 23, 2011 6:19 pm    Post subject:
Dear friends this is my chaine:
[img]http://desmond.imageshack.us/Himg804/scaled.php?server=804&filename=mychainediagram.jpg&res=medium[/img]
Now I attach some image of the Radiance setup:
[img]http://desmond.imageshack.us/Himg98/scaled.php?server=98&filename=dsc1895t.jpg&res=medium[/img]
[img]http://desmond.imageshack.us/Himg38/scaled.php?server=38&filename=dsc1897b.jpg&res=medium[/img]
[img]http://desmond.imageshack.us/Himg402/scaled.php?server=402&filename=dsc1898x.jpg&res=medium[/img]
I cannot see 3D image.
Please: can anyone help me?
dvh99
Posted: Wed Jun 29, 2011 4:00 am    Post subject:
JohnHWman wrote:
I agree Tim,
P43 fast green phosphor with proper C element filter is my next step for 3D. However, 120Hz full HD 3D would also require to improve the G90 VBW to 180MHz or more.
John
300 mhz or more.
dvh99
Posted: Wed Jun 29, 2011 4:05 am    Post subject:
the glasses sold on the forum here are from bit cauldron.
are they better then other glasses?
can ghosting be eliminated when using regular tubes (lcp09).
is the picture quality better then other active glasses?
those glasses are tempting but if someone gets the same results with glasses for 1/2 price......
Erik van Voorst
Posted: Mon Oct 10, 2011 9:34 pm    Post subject:
JohnHWman wrote:
Hi
If you have not such scaler today, you may go to digital but unfortunatly, most Hi-End 3D ready decent projector (like Sony VPL-VW90ES) will cost you more than £5000 and 2D picture is not as nice as 9" CRT !
John
I beg to differ.....
I own both the 1209/s and the Sony VPL VW90ES.
Besides that 3D is state of the art (in which I am hardly interested as there are only 5 or 6 3D films interesting to watch)
The 2D films are much better on the Sony than on the Barco even though my Barco is ISF calibrated and colorfiltered and has a near perfect mechanical setup.
I was wondering if your opinion is based on a comparison...same screen....same room......same components.
i did the comparison with an Oppo 93 and the Barco did 1080P with a VP50 and HDfury.
Are there any out there who had the same experience....being Sharper picture/better focus with quick movements/better colors
I have no preference in a particular brand or exclusiveness I just want the best picture....and Sony gets all the credits.
It is a very minor to have less black it does not outweigh all the plusses.....( I will not mention all the practical advantagess since that has nothing to do with picture quality.
Just my 2 cents Very Happy
it is all about combinations
ElTopo
Posted: Wed Oct 26, 2011 8:32 pm    Post subject:
Hello,
i have read a lot in this thread, thanks to all out there, but i'm not 100% sure what is missing in my setup.
Could you please take a look, my setup:
Barco Reality 909
Oppo BDP-93
Lumagen XS (without 3D installed)
new external Moome for 3D
Gen2 emitter with Glases
Do i just need the 3D Lumagen key ? Or also the Lumagen 3D CRT driver box?
thank you
ElTopo
Barco Cine 9 the one and only
ElTopo
Posted: Thu Nov 03, 2011 6:49 pm    Post subject:
Hello,
i have set my Lumagen (with 3D key now) to output resolution 720p@120Hz and go directly into the Ext Moome V3.
But i will not get any picture on my Barco when i start a 3D Blu-Ray Crying or Very sad
The menu is visible in 2D.
Anyone does have an input for me here ?
thanks
ElTopo
ElTopo
Posted: Thu Nov 03, 2011 7:16 pm    Post subject:
Oppo and Lumagen is set to 3D = Auto
May that be the problem?
ElTopo
ElTopo
Posted: Fri Nov 04, 2011 9:51 am    Post subject:
Update: resetted PS3 for a test and it works Wink
Anyone got some experience if Samsung SSG-3700CR work with the Gen2 emitter ?
ElTopo
Page 17 of 18
