David_Web
| Posted: Sat Sep 25, 2010 9:15 am Post subject: |
| Nashou66 wrote: |
Yeah I'm nerdy, I measured grey scale as soon as I turned it on and then again after 15 minutes and then after 30, then after an hour. no change from 15 to 30 and very slight from 15 to 1 hour.
So i just do everything after 15 minutes, and I use the lumagen warm up function test pattern, its a full field 50% white pattern.
Nashou |
Could you do the same but without using a warm up pattern. To compare how much the phosphor is really affecting things?
_________________ SNR of people are ridiculously low.
Electrogeek
Joined: 03 Aug 2007 Posts: 104 Location: Hamilton New Zealand
| Posted: Mon Sep 27, 2010 12:24 pm Post subject: |
mine is good to go as soon as i turn it on, good 'ol sony, although, if it is really cold <10 oC the image is green with bright lines till it warms up
_________________ I have found a use for compact fluorescents hehe
dturco
| Posted: Mon Sep 27, 2010 1:02 pm Post subject: |
I just turn it on. Then I go to get a drink and some snacks from down stairs, then watch the 20 minutes of trailers, at that point it's ready/stabilized for critical viewing.
http://www.hulu.com/firefly
kal Forum Administrator
| Posted: Mon Sep 27, 2010 8:05 pm Post subject: |
| kal wrote: | I don't do anything special for warm-up. Convergence is pretty much bang-on from the moment I start it up. It takes about 5 mins for the contrast to maximize and for black levels to rise to the right point.
Kal |
Same here...
AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Tue Sep 28, 2010 1:00 am Post subject: |
| Tom.W wrote: | | kal wrote: | I don't do anything special for warm-up. Convergence is pretty much bang-on from the moment I start it up. It takes about 5 mins for the contrast to maximize and for black levels to rise to the right point.
Kal |
Same here... |
ditto!
