| Posted: Fri Sep 10, 2010 11:42 pm Post subject: Question about G70 astig |
My barco forces me to do astig by sticking my hands up there and running magnetics.
The G70 manual seems to suggest that there are full electronic astig adjustments, even for the center of the screen. Is this the case? Because if it is, damn, that's freakin' awesome!
dvh99
| Posted: Sat Sep 11, 2010 12:28 am Post subject: |
just look if there are flare rings on the tubes, i can not imagine them not being there.
btw gratuliere with the g70.
| Posted: Sat Sep 11, 2010 1:36 am Post subject: |
| dvh99 wrote: | just look if there are flare rings on the tubes, i can not imagine them not being there.
btw gratuliere with the g70. |
I haven't got it yet, so don't count chickens. I'm trying to learn a bit before I pick it up. The Barco seems to have been a model of simplicity compared to the Sony... Adjust green focus? ADJ->RANDOM ACCESS->FOCUS->GREEN->(alter focus with +/- at center/top/bottom/sides). Changes save automatically.
The Sony appears to require a process akin to docking an oil tanker to perform the same operation...
| Posted: Sat Sep 11, 2010 2:13 am Post subject: |
| Nashou66 wrote: | The Barco doesn't have Zone Astig? Zone Focus? Etc?
Athanasios |
Zone focus center/top/bottom/right/left; zone astig top/bottom left/right and in each corner - but not in the center. You have to run the magnetics on the tube neck to do ANY kind of adjustment of astig *overall*. It's a massive pain, particularly since there are two rings that each slide around and affect each other, and each has a knob which alters its own state and that of the other (depending on its knob). And on my red tube, for example, the optimal (?) position of one of the rings puts it right next to a cluster of other stuff in there that prevents it from moving or you from adjusting the knob.
That's one of the things on the Barco I really won't be sorry to see go - it's been murder on my PQ, along with my second massive peeve: Scheimpflug that adjusts *corner to corner* rather than *top to bottom and left to right*. Again, with that kind of setup, everything f*cking interacts with itself; if you don't change the two adjustments in *PRECISE* opposition to each other, any adjustment you do adjusts top-bottom focus as well as corner-to-corner focus. I long ago gave up on resolving anything more than 720p in the corners of my image... I just haven't got that kind of time.
| Posted: Tue Sep 14, 2010 3:07 pm Post subject: |
Between the astig and the scheimpflug, you'll love the G70, Perisoft... I love the electronic controls. I still have never mastered the astig, but it still looks awesome. My machine is damn near as sharp in the corners as it is in the center; that's not an exaggeration. I think you'll be impressed.
| Posted: Tue Sep 14, 2010 3:49 pm Post subject: |
The G70 does have ferrous flare magnets on the tube, but you probably don't need to bother with them as they are usually set up well enough from the factory. The G70 does have center astig and two-pole electronic adjustments to make up for any slight misalignment in the flare magnets.
If you find that you need a lot of electronic 2-pole or astig correction you should adjust the ferrous magnets on the tube necks. To do this, you center out all electronic 2-pole and astig correction and then adjust at ferrous magnets at the center as you would any other projector. Get them as good as you can and then touch up with the electronic adjustments in the service menu. But like I said, you really will probably not have to bother.
The G70 and G90 are supper sweet because you almost never have to even open the case on a G70 to do a calibration, and you never have to open the case on the G90 (unless you want to adjust DY coil pitch). Also the G70 and G90 have an electronic 2-pole adjustment for every scan rate so they can be optimized not just for one... likewise on the astig. For what it's worth, the G90 also has 6-pole electronic at the center and nine zones for true refinement
I brought this up in another thread, but on the G70 don't forget about the pincushion and keystone balance adjustments either. Many folks don't even realize they are there. So if you are adjusting keystone, press the keystone button a second time to get to keystone balance. Also for what it's worth the G90 doesn't have this balance because Sony took it to an even higher level with separate key and pin adjustments for all four sides on all three colors...
The D50, G70, and G90 are a dream to set up. Once you get the hang of it the adjustments go wicked fast and there is an adjustment for pretty much anything you could imagine. On the G70 and G90 you don't even have to get your hands dirty
| Posted: Tue Sep 14, 2010 4:01 pm Post subject: |
Awesome info, Craig! Thank you, thank you, thank you! I'd like to highjack the thread and pick your brain for a second though if you don't mind... A couple of questions:
1) When you do a scratch setup on the G70 on a 16:9 screen, do you set up with the internal 31khz oscillator per the manual, then tweak from there? Or, do you use a different method (and no, I don't expect you to articulate your method - I'm just curious if do something different).
1a) If you do use the internal pattern, do you push the pattern out beyond the screen border? I had a lot of trouble with ringing and raster distortion (at 1080p) when I did my first couple of setups, and ended up doing a setup where the corners were well off the screen border. I assume it has to do with effectively making the raster larger in relation to the active area to give the beam more time to stabilize before it starts lighting up the raster on the left side.
2) Can you get the geometry perfect on a ~96" wide screen? I've always had a very subtle wave at the 1/4 and 3/4 screen width points that I've never been able to get rid of.
I know I can get this machine better... I got it so damn good the last time, I haven't messed with it in ages, but I know I can get it better. I think I'll do another setup once the weather gets crappy here. I've been close to hiring you a couple of times, but then I remember how I like to fiddle-dee-fart around with things and I realize that probably wouldn't be a wise investment.
Thanks!!!
| Posted: Tue Sep 14, 2010 4:32 pm Post subject: |
| ecrabb wrote: |
1a) If you do use the internal pattern, do you push the pattern out beyond the screen border? I had a lot of trouble with ringing and raster distortion (at 1080p) when I did my first couple of setups, and ended up doing a setup where the corners were well off the screen border. I assume it has to do with effectively making the raster larger in relation to the active area to give the beam more time to stabilize before it starts lighting up the raster on the left side. |
Are you using an HTPC/VP? I had the same issue with my Barco, but solved it by messing with the porches on the output. It does essentially the same thing - though since I never ever use the on-board Barco patterns (which are huge and fat, and all double-pixeled horizontally; WTF?) it could be I was doing the exact same thing from a different direction.
Another question: How fine are the convergence adjustments? At 1920x1080, the Barco's fine convergence seems to adjust in about 1/3rd pixel steps, which makes perfect convergence a matter of luck. I'd love to hear that the G70's adjustments are less granular...
Christ, I gotta find a space on the floor and fire this damn thing up.
| Posted: Tue Sep 14, 2010 5:50 pm Post subject: |
| ecrabb wrote: | | Awesome info, Craig! Thank you, thank you, thank you! I'd like to highjack the thread and pick your brain for a second though if you don't mind... A couple of questions: |
No problem.
No I don't. I usually use 1080p 60Hz (or whatever real world scan rate you like) and make that the base scan rate. I don't use any of the internal patterns or frequency generators for anything calibration wise. On G70's I usually set up both 1080p 60Hz and 1080i 60Hz and let the client decide which he (or rarely she) likes better. For DYI people you can also consider 720p for OTA that are broadcast at 720p. I usually offer this to clients as an option, but usually suggest that it isn't worth it because I charge per scan rate and there isn't much 720p left.
If you have a VP, set up 800x1920 at 60Hz or 72Hz as well for 2.35~2.50. But you will basically use your first scan rate as the base scan rate. You may also want 2x480p for SD material (960x1440p).
These days on G70's I use 1080p as the base. For raster image positioning I run an overscan pattern. Then turn down the contrast to something around level 0~5 and turn the brightness up to 100. Usually on the G70 and G90 you can then even see the image and raster on the screen (or you can look directly into the tube). Place the image to the bottom right side of the raster (when viewed on screen) by using the "SHIFT" parameter. This way you will position the image as far away as possible from the leading raster boarder and reduce or eliminate the raster ringing. Then position the picture on the screen using the "CENT" adjustment.
EDIT:
When you position the image to the bottom left of the raster you should look at a cross hatch or circle hatch patter. As you move the image to the right, at some point you will notice a nonlinearity start to develop on the right side of the image (you will see the hatches and circles start to get squished). When you notice this, back off and shift the image back towards the left of the raster until the nonlinearity goes away. Once the linearity is ok, go one or two more cliecks back to the left just to make sure. Also, don't put the image all the was at the bottom of the raster. Leave at least two clicks between the image and the bottom of the raster.
Hmm, nothing is ever "perfect" but that doesn't sound normal either. I know the G90 does have some internal trimmers that can be used to make all kinds of weird geometry corrections. I bet the G70 has these as well, but I have never looked. If you try and adjust these ever, mark their original position with a sharpie pen so that you can put them back if you don't like the results...
...the G70 doesn't have a green LIN Balance adjustment does it? The G90 does, but only when "Simulation Mode" is enabled.
Where are you located again? Maybe if you just need some basic help and I happen to be in the area I could cut you a good deal?
Last edited by CIR Engineering on Fri Sep 17, 2010 3:18 pm; edited 1 time in total
| Posted: Tue Sep 14, 2010 5:51 pm Post subject: |
| perisoft wrote: | | ecrabb wrote: |
Christ, I gotta find a space on the floor and fire this damn thing up. |
Pretty fine, but perfect convergence on a G70 at all points is not usually doable.
dvh99
| Posted: Tue Sep 14, 2010 5:54 pm Post subject: |
i managed to get my pj perfect on the screen but did so by cheating, using the convergence on green to get the faint waves out and getting the active picture perfect in the corners.
if the deflection coil isnt perfect on the neck you can have this minor problem or if the pj isnt physically set up right.
btw i used the porch setting too for fine tuning .
| Posted: Tue Sep 14, 2010 6:01 pm Post subject: |
| dvh99 wrote: | | i managed to get my pj perfect on the screen but did so by cheating, using the convergence on green to get the faint waves out and getting the active picture perfect in the corners. |
Good idea... there is no such thing as cheating as long as the end results are good
| Posted: Tue Sep 14, 2010 7:29 pm Post subject: |
| perisoft wrote: | | Are you using an HTPC/VP? I had the same issue with my Barco, but solved it by messing with the porches on the output. It does essentially the same thing - though since I never ever use the on-board Barco patterns (which are huge and fat, and all double-pixeled horizontally; WTF?) it could be I was doing the exact same thing from a different direction. |
No, not using a HTPC as a primary playback device... Too many other sources I like to use... PS3, 360, DirecTV... I probably need to break down and get a processor. I keep putting it off, but I probably just need to suck it up. Especially now that I have iRule and can eliminate most of the usability issues... I could do active area scanning for scope really easily, then... A couple of buttons to switch between 1.78 and 2.40.
Craig, I think I've asked this before, but what's the cheapest VP I could get into (used) that would crop to do active area scanning? HDMI input/output is preferable, and not sure if I really need 1080/24 input, but I'm guessing that would better than doing ITC to derive the 24p.
| perisoft wrote: | | Another question: How fine are the convergence adjustments? At 1920x1080, the Barco's fine convergence seems to adjust in about 1/3rd pixel steps, which makes perfect convergence a matter of luck. I'd love to hear that the G70's adjustments are less granular... |
Unless I stand RIGHT at the screen, the granularity is fine. It would be nice to be able to do a half-click occasionally, but most of the time, I can nail it to within 95% of where I'd like to be... I'm talking about being really anal.
| perisoft wrote: | | Christ, I gotta find a space on the floor and fire this damn thing up. |
Hell yes, you do!!!
Thanks, guys!!!
I'm definitely adding this thread to the G70 Owner's Thread if I haven't already!!!
| Posted: Tue Sep 14, 2010 7:32 pm Post subject: |
Holy crap... Thanks, Craig. Between that last post and a couple of the others you just made, you just eliminated most of the last 10% or so bit of uncertainty I had about setting up my machine. I'll be much more confident about going after it this time. Thank you so much.
| CIR Engineering wrote: | | On G70's I usually set up both 1080p 60Hz and 1080i 60Hz and let the client decide which he (or rarely she) likes better. For DYI people you can also consider 720p for OTA that are broadcast at 720p. I usually offer this to clients as an option, but usually suggest that it isn't worth it because I charge per scan rate and there isn't much 720p left. |
This is exactly what I've done... 1080i/60, 1080p/60, 720p/60 and 480p. I set up 720p because a lot of PS3 games default to that... If somebody has a PS3 and wants to game at all, you'll definitely want to set up a 720p slot, because if you don't and disable 720p, the PS3 will default to 480p because it won't upscale games to 1080i or 1080p. Thanks, Sony.
| CIR Engineering wrote: | | Where are you located again? Maybe if you just need some basic help and I happen to be in the area I could cut you a good deal? |
Des Moines, IA - pretty much the middle of nowhere. I'm not far from I-35/I-80. I guess if you were driving to Denver, Omaha or Kansas City from Chicago, you might be pass through my neck of the woods... Wouldn't be too far out of the way if you visited the folks at SpectraCal, either. If you ever are going to pass through for any reason, let's talk. Even if I can just buy dinner and a tank of gas and pick your brain for an hour while you take a break from the car, that would be awesome.
Thanks again, Craig!!!
| Posted: Tue Sep 14, 2010 7:54 pm Post subject: |
| ecrabb wrote: |
Craig, I think I've asked this before, but what's the cheapest VP I could get into (used) that would crop to do active area scanning? HDMI input/output is preferable, and not sure if I really need 1080/24 input, but I'm guessing that would better than doing ITC to derive the 24p. |
Get a Lumagen HDP... I think there is even one listed now for sale on the forum for like $200.
The HDP has a physical DVI input connection, but you can set the input to accept HDMI color spaces including YCbCr 422 and 444. It also supports 1080p 24Hz on the input as well as 1080i (but not 1080p 60Hz on the input).
This is your cheapest option with good video quality. You can even output 817x1920 at 72Hz or 60Hz with it was well as 1080p 60Hz on the output.
The only downside to the HDP is that the DVI output only support RGB, not YCbCr so no 10-bit color on the output. There is a difference, but it is only slight. It also does not support 1080p 60Hz on the input, but this is not much of a problem with BD supporting 1080p 24Hz now.
| Posted: Tue Sep 14, 2010 8:20 pm Post subject: |
| ecrabb wrote: |
SC |
I used to get through that way about once a year, but it has been at least a few years since the last trip. Sooner or later I am sure, but right now it looks like later rather than sooner
| Posted: Tue Sep 14, 2010 9:10 pm Post subject: |
| CIR Engineering wrote: | | The only downside to the HDP is that the DVI output only support RGB, not YCbCr so no 10-bit color on the output. There is a difference, but it is only slight. It also does not support 1080p 60Hz on the input, but this is not much of a problem with BD supporting 1080p 24Hz now. |
Hmmm... I'm not so worried about the lack of 10-bit color - I'm still using the old HD Fury as my D/A converter... I am concerned about the lack of support for 1080p/60 on the input, though... Do you know what it does when it sees a 1080p/60 signal input? Does it just pass the scaler (i.e. no processing), or does it go black or something? I'm just trying to figure out where the hell I'd put it in the signal chain if it won't accept 1080p/60... I guess I could get a dedicated BD player and put it behind that, but then all of a sudden I'm spending some real money. Hmm...
| CIR Engineering wrote: | I used to get through that way about once a year, but it has been at least a few years since the last trip. Sooner or later I am sure, but right now it looks like later rather than sooner |
I'm surprised you went through even once a year. NOBODY ever goes through here!
dvh99
| Posted: Tue Sep 14, 2010 9:20 pm Post subject: |
some games are scaled up to 1080p when you disable 720p in the menu.
uncharted and gta4 are certainly scaled up.
dvh99
| Posted: Tue Sep 14, 2010 9:25 pm Post subject: |
[/quote]
SC[/quote]
did they shoot twin peaks at that location??
