I blew up my BG808s... please help
Posted: Mon Aug 23, 2010 8:14 pm    Post subject:
If you look at the numbers on the tubes are they all the same ? Also Curt is correct as he can fix it but send him the boards he requires.
You started with one problem that has turned into possibly many...
Daddy
Posted: Mon Aug 23, 2010 9:29 pm    Post subject:
Hi Tom,
The numbers on the tubes are as follows:
P16LXV03RJA (red)
P16LXV03BMB (blue)
PT18-244GD (green)
They were all fitted with identical (at least I think so..) 120 MHz neckboards and prior to me taking the retro chassis apart.... I was able to see a 1080p movie (just to check I had a working PJ, I did not do a setup at that time). Particularly the green image was so sharp that with a screen width of roughly 2.4 meters with 1080 scan lines I could still easily see the individual scan lines.
That is quite different from my trusty old Sony 1251QM.
Do you have any idea what kind of tube a P18-244GD is?
The retro was pulled from a 3D VR system.
It has a different (bigger) lens than is fitted on the red and blue tubes.
