AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Sun Sep 12, 2010 4:58 pm Post subject: |
| perisoft wrote: |
That's full scale, with correctly calibrated radio shack meter. So, that doesn't seem so bad. The question is, what's it SUPPOSED to be... Unfortunately I don't have EQ detailed enough to distinguish 50 from 40 from 30hz, which is really what I need. |
Do you have RS meter calibration corrections applied below 10Hz?
I would ignore anything below 10Hz. The RS meter is decent but not that accurate at the low and high ends even with correction tables.
http://www.hometheatershack.com/forums/rew-forum/86-interesting-info-rs-spl-meter-correction-values.html
| perisoft wrote: | | Unfortunately I don't have EQ detailed enough to distinguish 50 from 40 from 30hz, which is really what I need. |
What are you looking for? I'm not sure I understand.
